| airhawk seat | |
old fart Scooter Rider
Number of posts : 85 Age : 75 Location : Edmonton, Canada Points : 5860 Registration date : 2009-02-02
| Subject: airhawk seat Fri Aug 31, 2012 7:00 pm | |
| I have an airhawk seat. It is the only way I can do long distance rides. I can't live without it. It sprung a leak at the seam. I tried bicycle tube repair glue. No luck, it wouldn't seal. Any suggestions on how to repair. If I can fix I'll have to buy new. |
twowings Scooter Rider
Number of posts : 2 Age : 84 Location : Spring Lake, MI Points : 4926 Registration date : 2011-05-06
| Subject: Re: airhawk seat Fri Aug 31, 2012 7:33 pm | |
| I use a product called "Vinyl Liquid Patch" Try an RV dealer if you don't find it elsewhere. It mends vinyl and is strong and long lasting. |
Old Sloppy Scooter Rider
Number of posts : 33 Age : 66 Location : Atlanta, Ga. Points : 4591 Registration date : 2012-05-13
| Subject: Re: airhawk seat Fri Aug 31, 2012 9:43 pm | |
| What is an airhawk seat ? Is it adjustable pressure ?
Harry |
Number of posts : 4214 Location : York, North Yorkshire, England UK Points : 9418 Registration date : 2010-11-16
| Subject: Re: airhawk seat Sat Sep 01, 2012 12:50 pm | |
| Meldrew: If you read the full post you would have seen that it was recommended I post here. The thinking was there were smarter people here. Maybe not so much PS I used windshield adheisive and it worked well |
Number of posts : 2453 Location : Georgetown, Tx Points : 8348 Registration date : 2008-12-23
| Subject: Re: airhawk seat Sat Sep 01, 2012 4:33 pm | |
| - old fart wrote:
- I have an airhawk seat.
The original AirHawk is neoprene. Aquaseal (may want the Cotol-240) is both a sealent and an adhesive for neoprene or Aquaseal Seal Cement both are for neoprene. Make sure you thoroughly clear the area you try using bicycle tube glue. |
| Subject: Re: airhawk seat Sun Sep 16, 2012 11:08 pm | |
| - honda_silver wrote:
- The original AirHawk is neoprene.
Aquaseal (may want the Cotol-240) is both a sealent and an adhesive for neoprene or Aquaseal Seal Cement both are for neoprene. I had a small pinhole leak on the bottom on my large AirHawk that I just repaired with the Aquaseal with Cotol-240. The repair was very quick and very easy with the Aquaseal. For additional protection I added a waterproof vinyl liner from Lowe's ( I had some extra scraps left over) under the neoprene AirHawk bladder. |
| Subject: Re: airhawk seat Sun Sep 16, 2012 11:15 pm | |
| My issue was not a hole but a seperation between the top and bottom half at the seam. I ended up using some windshiel adhesive that my son had laying aroud. Been riding on it for 2 weeks and it is holding up well. |
Disturbed Scooter Rider
Number of posts : 26 Age : 67 Location : Centralia, WA USA Points : 4259 Registration date : 2013-04-14
| Subject: Re: airhawk seat Sat May 18, 2013 11:15 am | |
| Would you recommend the large size Airhawk? |
| airhawk seat | |
