| How do I fix this? | |
moosedaisy Scooter Rider
Number of posts : 84 Location : Charleston, SC Points : 4714 Registration date : 2012-05-22
| Subject: How do I fix this? Mon Sep 10, 2012 6:17 pm | |
| I'm the 2nd owner of this silver wing. The first owner, my father in law tipped it into another bike when parking it. I think he broke a plastic hook or tab on the inside. I'm guessing as I've never removed the plastic. Well the point being the plastic has pulled away and I'd like to fix it. Can anyone here offer any advice? Dom |
Number of posts : 2778 Age : 74 Location : NE Oklahoma Points : 9100 Registration date : 2008-12-28
| Subject: Re: How do I fix this? Mon Sep 10, 2012 7:08 pm | |
| Hi Dom, Give this a try. Remove the large silver Screw/Bolt in the conner of the picture. Then remove the lower screw along the egde. Open the glove box and lightly pull the top part toward the back of the of the scooter about 1/4" to 3/8". At the same time press in on the side and keep pressing in while you slide the top back in place. Hopefuly the locking taps are still there and working. Once you get it all back, reinstall the screws. |
| Subject: Re: How do I fix this? Mon Sep 10, 2012 7:15 pm | |
| Thanks, I'll give that a try tomorrow. When I pull the body plastic away from the bike. It looks like there might be some broken hooks? As I can see what looks like a bit of raw unfinished plastic. |
Number of posts : 1099 Age : 70 Location : Cleveleys, Lancashire, England Points : 6536 Registration date : 2010-03-27
| Subject: Re: How do I fix this? Tue Sep 11, 2012 7:47 am | |
| If you aren't bothered about looks and the tabs are broken drill 1/8th " holes in the top cover and the side and use small tie-wraps to bring them together. Works on mine.
Cheers, |
tankyuong Silver Wing Rider
Number of posts : 475 Age : 49 Location : Missouri Points : 6300 Registration date : 2009-07-12
| Subject: Re: How do I fix this? Tue Sep 11, 2012 12:02 pm | |
| Use packaging tape to pull parts together use expanding foam inside |
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7560 Registration date : 2010-02-03
| Subject: Re: How do I fix this? Tue Sep 11, 2012 12:15 pm | |
| How would you get the expanding foam inside ? I guess you could drill a hole in the inside of the left glove box to put the foam in. |
| Subject: Re: How do I fix this? Tue Sep 11, 2012 12:18 pm | |
| Subject: Re: How do I fix this? Tue Sep 11, 2012 2:50 pm | |
| It is a vary big job to remove the right box, the left one comes out easy but not the right one. |
hotwings Silver Wing Expert
Number of posts : 876 Age : 54 Location : Ontario Points : 5568 Registration date : 2012-04-29
| Subject: Re: How do I fix this? Tue Sep 11, 2012 9:33 pm | |
| - model28a wrote:
- It is a vary big job to remove the right box, the left one comes out easy but not the right one.
its actually the other way around!! left is difficult, right is easy! |
| Subject: Re: How do I fix this? Tue Sep 11, 2012 10:01 pm | |
| Think you hotwings that's what I meant to type. That's my dyslexic fingers. Looking at the picture it is the left side that is in need of repair. |
