04 silverwing loss of power I_icon_minitimeby sonuvabug Today at 4:19 pm
04 silverwing loss of power I_icon_minitimeby sonuvabug Today at 4:17 pm
04 silverwing loss of power I_icon_minitimeby sonuvabug Today at 4:06 pm
04 silverwing loss of power I_icon_minitimeby JohnyC Yesterday at 10:04 am
04 silverwing loss of power I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
04 silverwing loss of power I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
04 silverwing loss of power I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
04 silverwing loss of power I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
04 silverwing loss of power I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
04 silverwing loss of power I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Silverwing28681
rodenbach
RArch
faranduscd
faranduscd
Number of posts : 13
Registration date : 2012-11-12
04 silverwing loss of power Empty
PostSubject: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSat Dec 01, 2012 3:39 am
here is my delima. i purchased my 04 swing used. and before i did anything i ran the hell out of it to see if she was sound. and the answer was yes. SUPER quick, top speed 115 mph and great ride. so....
I had the works done to her. new plugs, new belt, oil change, new coolant, new tires new brakes and paint job.
problem is....
IT PERFORMS WORSE NOW!
throttle response is "OK" but not body snatching fast like it was. and top speed now is between 95 and 100 mph wit 100 pushing it. any idea what the problem may be.
was not serviced by honda but by local shop.
RArch
RArch
Number of posts : 613
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSat Dec 01, 2012 4:19 am
Weird...
Might be worth letting the 'local shop' know that there is a problem but you could check the plugs to see if its burning properly.
http://www.rcmodeltalk.co.uk
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSat Dec 01, 2012 1:19 pm
problem is....
I would put the Silverwing on center stand, lift off tire and spin each tire (off the ground) to check for any noise or binding. Then check for side-to-side bearing play.
I would also suggest using fuel injector cleaner in 3-4 tankfuls.
Simple steps first.
rodenbach
rodenbach
Number of posts : 321
Registration date : 2012-08-30
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSat Dec 01, 2012 2:50 pm
Oil overfill
Sticky brake pads
Problem with belt
Silverwing28681
Silverwing28681
Number of posts : 94
Registration date : 2012-08-16
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSat Dec 01, 2012 6:50 pm
sounds like to me it is a belt or variator problem. Did they change rollers or install sliders? they could they be installed wrong ? Like honda_silver
said spin the wheels and make sure that is free, Keep us posted Thanks
wingmann
wingmann
Number of posts : 58
Registration date : 2010-08-22
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSun Dec 02, 2012 1:24 am
This is just a guess. I think you had lighter weight sliders and when you had the tune up / belt change. I think they put in new stock rollers that weighed more then the sliders did. Go back to the shop and ask them if they changed the weights / sliders or rollers in the variator. If it was not to long since you had this work done maybe you can ask the mechanic if he remebers working on your silverwing and ask about the work that was done on the variator or look at your receipt for a parts list and see if you had rollers or slider weights replaced . If so order some lighter weight sliders and try them . I hope the fix is as simple as that. Good Luck
faranduscd
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSun Dec 02, 2012 5:53 am
There was no change to variator. But didbhave new belt out on. Would lose belt cause the problem?
Silverwing28681
Silverwing28681
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSun Dec 02, 2012 6:34 am
It could if they install wrong belt, I lean more towards the variator
micbusathens
micbusathens
Number of posts : 199
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSun Dec 02, 2012 9:09 am
If the belt was worn enough is considered as a small sprocket in front and by replacing it with a new OEM is like you change front sprocket with a larger one.I mean less Rpms for the same speed.Anyway ......with brand new oem belt and rollers your rev limiter sould hit round 115 mph and that comes fairly easy.Try your top speed on your center stand....staticaly
Number of posts : 2392
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSun Dec 02, 2012 11:34 am
I had a similar problem a year or so ago.
My problem ended up being the glue on the heated grips had come unstuck and resulted in top speed being between 90 -100 mph.
So if you have heated grips, give them a looking at. Maybe simpler and cheaper than expected.
jmaslak
Number of posts : 252
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSun Dec 02, 2012 1:27 pm
Please *DON'T* accelerate to top speed with the bike on the center stand. It's not designed to do that with no load and you run a good chance of breaking something. Nevermind if the tire, as it expands in radius, catches on something, you've got an out of control 600 lbs projectile. Plus the helix/spiral in the rear pulley is going to act way different.
Use a dyno if you need to test this. Lots of motorcycle shops have them.
Before you ride it anymore though, you need to check tightness of the front and rear pulleys. Standard procedure is to loosen the front one to put the belt on. If it is just statically tightened against the belt, it's probably loose. You have to make sure the belt isn't pinched while it is tightened. That could certainly do bad things.
Are you sure your tires are OEM sized (heck, your old ones might not have been).
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSun Dec 02, 2012 3:20 pm
Me being thick - but how? Neutral
The speed pick up is on the front wheel is it not. Therefore if spinning up the rear on the centre stand how on earth will the speed be detected! scratch
micbusathens
micbusathens
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSun Dec 02, 2012 3:27 pm
Speed sensor is at the engine compartment near the back we
el
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSun Dec 02, 2012 3:48 pm
el
Okey dokey. Shows what I know!!! Laughing
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSun Dec 02, 2012 3:55 pm
Done my homework and my Service Manual shows the speed sensor below the front brake calliper!!!!
Page 23 of the FSC600 Manual.
IF I had a bike in the garage right now I would check so I am just going to have to trust Mr Honda's manual!
Just added to my total confusion.
rodenbach
rodenbach
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSun Dec 02, 2012 4:38 pm
I seems that it can be done: see it on youtube
RArch
RArch
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSun Dec 02, 2012 5:05 pm
Maybe thats the ABS speed sensor?
The speedo sensor is on the rear wheel gearbox.
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSun Dec 02, 2012 5:08 pm
Good point, you can see why I'm confused! What a Face
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSun Dec 02, 2012 5:16 pm
So far I have found a Front Wheel Speed Sensor AND a Rear Wheel Speed Sensor! (Suspect part of the ABS!)
Found it, Page 174. VEHICLE Speed Sensor! At the rear.
I'm not confused anymore - also knowledge increased. Not a bad thing. Smile
RArch
RArch
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSun Dec 02, 2012 5:25 pm
Only one more left to find... The engine speed sensor Rolling Eyes
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSun Dec 02, 2012 5:27 pm
Nooooooo - I'm sensored out! Laughing
rodenbach
rodenbach
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSun Dec 02, 2012 5:30 pm
.. wind speed sensor Wink
04 silverwing loss of power Anemometer_Animation
RArch
RArch
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSun Dec 02, 2012 6:28 pm
hmm, dont think I've got this one on my silverwing...
Razz
faranduscd
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeSun Dec 02, 2012 6:41 pm
lol yall funny as hell. imma just bite the bullet aand take it to the dealer.
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeMon Dec 03, 2012 5:34 am
Razz
It's installed under the riders seat to detect even minor flatulent emissions! Smile
RArch
RArch
PostSubject: Re: 04 silverwing loss of power   04 silverwing loss of power I_icon_minitimeMon Dec 03, 2012 5:56 am
Does it give you a minor power boost? clown
» Power mods
» IMC MIT-15 Power supply
» Power for SatNav
» Spot Light Relocation and Bracket
» more power,,,, always more
