| Belt failed | |
+9stanly bikerboy micbusathens yammer GHM-PM Old Limey john grinsel toolboxjesse tinman 13 posters |
| Subject: Belt failed Thu Feb 14, 2013 8:24 am | |
| Was on another Swing forum where I saw pics of drive belt was totally disintegrated ,what a mess ,It split the casing , oil everywhere. |
Number of posts : 330 Age : 51 Location : Atlanta, GA Points : 5355 Registration date : 2011-05-13
| Subject: Re: Belt failed Thu Feb 14, 2013 8:54 am | |
| I had a failed belt on my Reflex a few years ago. I was past the recommended replacement interval and I kept saying "maybe next weekend". I got very lucky that when the belt disintegrated I just lost power on the highway with no traffic around and that the belt didn't lodge in the drive or driven pulleys and cause engine or rear wheel lockup. I now change at every interval for both bikes.
Jesse in Atlanta |
| Subject: Re: Belt failed Thu Feb 14, 2013 11:37 am | |
| With now near 300,000 miles on rubber band drive scooters...and one belt failure, probably within a few hundred miles of end of service life (Helix), just as I exited Freeway, Pulaski VA-----I continue to change at manufacturers recommend interval with only OEM parts. FEAR: worn out belt breaking/coming apart just as I need power to keep from getting run over.
Recently, my new Burgman 400 ran belt to 20,000...to see what would happen. When I took drive case off.....spun rear outer clutch bearing, worn out front pulley and rollers... All but new belt were warranty.
Based on rubber band drive scooter experience since 1990......this is a very expensive system if you ride a lot!!!! This, I am considering in my next bike/scooter purchase------plain old OEM chain on my GS500E Suzuki went 44,000 miles, just lots of oil and mess. Replacement chain and sprockets were at $100 or so. |
Old Limey Silver Wing Expert
Number of posts : 921 Age : 80 Location : BOLTON LANCASHIRE ENGLAND Points : 6296 Registration date : 2010-06-09
| Subject: Re: Belt failed Thu Feb 14, 2013 11:54 am | |
| The very thing that concerned me the most about changing from a motorcycle to a scooter, was the Belt drive. However, i changed the belt at 16000mls as advised, and now am confident in the belts reliability . I think following John Grinsel's advice is a good idea as he probably has more experiance, on scooters, than most on this site. I only depart from his advice on OEM parts, I paid half the OEM price for a belt that turned out to be the same maker as the OEM belt. |
| Subject: Re: Belt failed Fri Feb 15, 2013 7:40 am | |
| - Old Limey wrote:
- I only depart from his advice on OEM parts, I paid half the OEM price for a belt that turned out to be the same maker as the OEM belt.
Very nice! Now if you would care to share the supplier and contact info with the rest of us? Please? |
| Subject: Re: Belt failed Fri Feb 15, 2013 11:53 am | |
| www.Wemoto. com Is where i bought mine, £68 is what i paid, remember i'm in UK. |
yammer Maxi-Scooter Rider
Number of posts : 100 Age : 64 Location : Malta Points : 4354 Registration date : 2013-05-04
| Subject: Re: Belt failed Wed Jun 05, 2013 12:54 pm | |
| - Old Limey wrote:
- The very thing that concerned me the most about changing from a motorcycle to a scooter, was the Belt drive. However, i changed the belt at 16000mls as advised, and now am confident in the belts reliability . I think following John Grinsel's advice is a good idea as he probably has more experiance, on scooters, than most on this site. I only depart from his advice on OEM parts, I paid half the OEM price for a belt that turned out to be the same maker as the OEM belt.
Just out of curiousity, are you stating that the belts from Wemoto and Honda OEM belts come from the same manufacturer? |
Number of posts : 199 Age : 63 Location : Athens Greece Points : 4843 Registration date : 2012-04-05
| Subject: Re: Belt failed Wed Jun 05, 2013 2:05 pm | |
| Just for peace of mind I prefer OEM ones since price is reasonable compared to the 68£ and I change them plus 8 k miles from honda suggestion with no significant ware.It could bare twice as much even with city use only I believe |
bikerboy Silver Wing Rider
Number of posts : 405 Age : 81 Location : Leyland England Points : 5371 Registration date : 2011-05-12
| Subject: Re: Belt failed Wed Jun 05, 2013 3:01 pm | |
| The Wemoto belt is made by Gates who make many of these things I gather (auto cam belts etc.). Does the OEM have a manufacturer's name on it other than Honda? |
stanly Scooter Rider
Number of posts : 49 Location : Eastern Washington Points : 4315 Registration date : 2013-04-05
| Subject: Re: Belt failed Wed Jun 05, 2013 8:01 pm | |
| maybe that's a price in England, but factor in shipping to US and it's higher than BBandit. link to Wemoto belt: (there's ph no if u want to quiz them) http://www.ebay.com/itm/Honda-FJS-600-2001-2007-Silverwing-Scooter-Drive-Belt-/360670964543?pt=UK_Motorcycle_Parts_13&hash=item53f9aa2b3f |
| Subject: Re: Belt failed Wed Jun 05, 2013 8:06 pm | |
| I'm sure that Honda or any of the large manufacturers don't own all the factories that make all the components that make up their cars or bikes. They choose other manufacturers that specialise in specific components so it would not be surprising that one could find the same parts with the same specs under a different brand. Although you will not be able to see anything on the label to say that it is the same part as OEM but cheaper, the label usually says that they also make OEM parts for large companies. Have a look at the Gates web site intro:
http://www.gates.com/brochure.cfm?brochure=2256&location_id=3487
BTW Gates are an asian company so I would be the least surprised if their belts are the same as OEM. |
| Subject: Re: Belt failed Wed Jun 05, 2013 8:25 pm | |
| There is a photo of a after market belt that was posted ,and it blew up gaming fibbers everywhere inside the casing .OEM belts are known to last twist as recommended replacement. I replaced mine at 32k kl and it was still in the specs.I plan to use it as a spare. My rollers were still good but I purchase Dr Pulley 24 grams sliders and will keep the rollers as pairs also. |
hotwings Silver Wing Expert
Number of posts : 876 Age : 54 Location : Ontario Points : 5566 Registration date : 2012-04-29
| Subject: Re: Belt failed Wed Jun 05, 2013 8:40 pm | |
| Gaming fibbers in tinman speak = jamming fibers! |
jmaslak Super Scooter Rider
Number of posts : 252 Location : Golden, CO, USA Points : 4810 Registration date : 2012-06-15
| Subject: Re: Belt failed Wed Jun 05, 2013 8:49 pm | |
| The OEM belt I have is a Mitsuboshi. Edit: also, Gates is headquartered in Colorado about 20 miles from my home, although, yes, they have factories in Asia (I have family members that did work for Gates). |
rollsroyce250 Scooter Rider
Number of posts : 73 Location : Florida Points : 4612 Registration date : 2012-06-21
| Subject: Re: Belt failed Thu Jun 06, 2013 12:36 am | |
| - tinman wrote:
- OEM belts are known to last twist as recommended replacement.
Could someone translate. |
| Subject: Re: Belt failed Thu Jun 06, 2013 12:52 am | |
| Subject: Re: Belt failed Thu Jun 06, 2013 5:17 am | |
| - rollsroyce250 wrote:
Could someone translate. "The OEM belt could last twice as long as the manufacturer suggests" |
Dramhunter Maxi-Scooter Rider
Number of posts : 132 Location : Northern Ireland Points : 4649 Registration date : 2012-08-15
| Subject: Re: Belt failed Fri Jun 21, 2013 10:58 am | |
| My 2010 Swing just passed 5000 miles so I've a wee while to go yet but interesting information. Before Swings I rode Beemers, loved the old air heads and maintained them with quality used parts and non OEM parts from a reliable supplier. I once needed a rectifier. A BMW ones was over £100. A non OEM one, by the SAME manufacturer as the BMW branded one, was less than half price. I work with marketeers, I know the nonsense they get up to to extract more money from ya! |
| Belt failed | |
