| Install New (different) Hand Grips | |
+6Pastor Ron exavid WingMan02 Meldrew john grinsel SylSki 10 posters |
SylSki Scooter Rider
Number of posts : 57 Location : Natrona Heights, PA Points : 4344 Registration date : 2013-03-11
| Subject: Install New (different) Hand Grips Mon Mar 18, 2013 6:48 am | |
| The factory installed "Hand Grip's" for me are too small (diameter) for my long finger's and purchased Kuryakyn 7/8's Universal ISO-Grips. Has anyone dont this & what is your opinion of doing so? These grip's are chrome and rubber pattern giving a more grip ability and of course larger in diameter. |
Number of posts : 3316 Age : 85 Points : 9471 Registration date : 2009-08-18
| Subject: Re: Install New (different) Hand Grips Mon Mar 18, 2013 7:07 am | |
| What about the chrome part when rains?? could be slippery.
"over grips" can be found in most shops that deal with off road bikes---cheap slide on...Mine have lasted over 20,000 miles.
Also you can make own from AC foam pipe insulation.
Method for removal of old----cut off and throw away. New need to make sure they won't slip. Hair Spray/Gas/grip glue seems to work. Loose grips could kill you. |
Number of posts : 4219 Location : York, North Yorkshire, England UK Points : 9450 Registration date : 2010-11-16
| Subject: Re: Install New (different) Hand Grips Mon Mar 18, 2013 7:10 am | |
| There's a page of stuff on hand grips including Kuryakin if you use Search. |
WingMan02 Super Scooter Rider
Number of posts : 287 Location : Honolulu Points : 5028 Registration date : 2012-01-19
| Subject: Re: Install New (different) Hand Grips Mon Mar 18, 2013 8:10 pm | |
| I installed the Kuryakyn flame grips, replacing the OEM grips. It is a lot wider than the factory ones. No problem with riding in the rain here in Hawaii. The grips have raised rubber. |
| Subject: Re: Install New (different) Hand Grips Sun Mar 24, 2013 4:01 pm | |
| Got the new grip's on along with the trickle charger connection. I know what the grip's are like, I had them on my X500 also and they sure are much more comfortable and grippy....if there is such a word !! Now awaiting my V46 Givi Mount Hardware due to come in tomorrow. At least the very cold weather give's me time to get all this done before the riding day's come. |
Number of posts : 2658 Age : 81 Location : Medford, Oregon Points : 8401 Registration date : 2009-07-17
| Subject: Re: Install New (different) Hand Grips Sun Mar 24, 2013 10:22 pm | |
| I've had ISO grips on two of my Goldwings and really like them over the OEM ones. It takes less grip to hold the grip if you get my meaning. I really like the throttle boss that goes on the end of the throttle side grip. The rubber extending through the metal makes for good grip even when it rains. Also the weight of the metal grip obviates the need for grip end weights. The only down side is that some Kuryakyn chrome plating sometimes pits after awhile. I had one set of grips that pitted and one that didn't. |
Pastor Ron Silver Wing Rider
Number of posts : 400 Age : 72 Location : Asheville,NC Points : 4775 Registration date : 2013-02-24
| Subject: Re: Install New (different) Hand Grips Sun Mar 24, 2013 11:31 pm | |
| The cheapest (for me) was Grip-puppies...I am not sure on the spelling. |
Number of posts : 3838 Age : 75 Location : Seaham, Co Durham, UK Points : 9710 Registration date : 2009-06-29
| Subject: Re: Install New (different) Hand Grips Mon Mar 25, 2013 3:49 am | |
| I, too, found the grips too narrow for my comfort so inatalled Grip-Puppies; they did the trick for me although they're not to everyone's 'taste'. I have bought another pair as I've failed to ask Laurie if her ex-Silverwing has them; I ordered them on Amazon uk and they arrived in two days. |
Tamjay Scooter Rider
Number of posts : 76 Age : 82 Location : Stamford, Lincolnshire Points : 5370 Registration date : 2010-06-10
| Subject: Re: Install New (different) Hand Grips Mon Mar 25, 2013 4:24 am | |
| - MikeO wrote:
- I, too, found the grips too narrow for my comfort so inatalled Grip-Puppies; they did the trick for me although they're not to everyone's 'taste'.
I have bought another pair as I've failed to ask Laurie if her ex-Silverwing has them; I ordered them on Amazon uk and they arrived in two days. I bought some but never put them on!! They're hanging around in a drawer somewhere!! |
| Subject: Re: Install New (different) Hand Grips Mon Mar 25, 2013 5:06 am | |
| If you find them I'll swap them for cash, Laurie! They don't last forever so I'll have a spare pair. |
AldusFran Super Scooter Rider
Number of posts : 210 Age : 78 Location : Tucson,AZ Points : 3691 Registration date : 2015-06-13
| Subject: Re: Install New (different) Hand Grips Tue May 14, 2019 6:13 pm | |
| I too make my own grips out of 1" dark gray pipe insulation and fasten them with two cable ties. They cut down on vibration and feels like grabbing a fat banana instead of a hot dog. |
dspevack Silver Wing Guru
Number of posts : 2008 Age : 59 Location : Miami, FL Points : 8214 Registration date : 2008-12-27
| Subject: Re: Install New (different) Hand Grips Thu May 16, 2019 8:53 am | |
| There is a company called Hotgrips The grips are: Slightly larger in diameter, Can be up to 1' wider than current and still be used on our handlebars, Heated. If you are going to spend a decent amount of money on new grips, why not add functionality for the $ ? |
