| A sponge? That's not standard equipment! | |
Scoundrel Maxi-Scooter Rider
Number of posts : 107 Location : Western Washington State, US Points : 4356 Registration date : 2013-04-15
| Subject: A sponge? That's not standard equipment! Wed Apr 17, 2013 1:34 pm | |
| I had nearly forgotten the joys of buying a used vehicle and discovering the crazy crap that people do. I was looking for my oil filter under the bike, and I found a sponge wedged between the filter and some hoses that come to a junction there. I pulled it out and inspected it, and the sponge was not full of any fluid, so I don't think it was there to mask any leaking problems. The bottom of the engine had a bit of oil and crud on it, but it did not seem excessive. I suspect it was put there to dampen vibration noises. I personally would have used something like a bit of foam rubber and some zip ties, but this was... innovative, I guess. Can anyone else think of a reason why the previous owner would have put a sponge there? By the way, the previous owner was the kind of guy who would put a "Fox Motorsports" sticker on the muffler cover to hide some scratches from when the bike was laid down, rather than buy a new $80 cover, or just sand/paint it. - Attachments
- (136 Kb) Downloaded 142 times
Gyro Touring Scooter Rider
Number of posts : 321 Age : 72 Location : Frontenac, Ks Points : 4631 Registration date : 2013-04-07
| Subject: Re: A sponge? That's not standard equipment! Wed Apr 17, 2013 1:57 pm | |
| :not worthy: |
Number of posts : 1099 Age : 70 Location : Cleveleys, Lancashire, England Points : 6529 Registration date : 2010-03-27
| Subject: Re: A sponge? That's not standard equipment! Wed Apr 17, 2013 2:09 pm | |
| Keeps the pipe away from the filter, just using something that was to hand.
If nothing else you now have a free bath sponge, or use it for what the Romans did with sponges (on a stick).
Cheers, |
Nowun Super Scooter Rider
Number of posts : 288 Age : 71 Location : Hampshire, England Points : 4714 Registration date : 2012-10-13
| Subject: Re: A sponge? That's not standard equipment! Wed Apr 17, 2013 3:59 pm | |
| Subject: Re: A sponge? That's not standard equipment! Wed Apr 17, 2013 7:30 pm | |
| Is the water hose OEM or homemade repair---sponge is good as anything if there is rubbing-----the rubbing I am sure is not in the standard honda design. I know used sometimes has to be brought back to normal. |
| Subject: Re: A sponge? That's not standard equipment! Wed Apr 17, 2013 7:37 pm | |
| They look like OEM hoses. I'll take a closer look later and secure the hoses with a less ghetto method. |
| Subject: Re: A sponge? That's not standard equipment! Thu Apr 18, 2013 4:40 am | |
| It looks like a washing up sponge so you can put it to good use when you find an alternative solution. Personally, if there is contact between the pipe and the filter a short length of water pipe insulation should do the job. (In the UK the foam pipe lagging is grey - don't know if it is the same across the pond).
Cheers, |
| Subject: Re: A sponge? That's not standard equipment! Thu Apr 18, 2013 11:14 am | |
| Yeah, that stuff is readily available in various diameters for cheap at the local hardware store, and it is dark grey. That's not a bad idea. I used that stuff on my Polaris RZR to cover a bar I kept banging my elbow on.
I'll start with just seeing if I can just use a cable tie to keep that hose out of the way, and if that doesn't work I'll think about the foam.
Why is it a problem for the hose to be touching the filter? The only things I can think of is either vibration noise, or one of the clamps scratching a hole in the filter. |
RArch Silver Wing Expert
| Subject: Re: A sponge? That's not standard equipment! Thu Apr 18, 2013 12:52 pm | |
| I think if you loosen that top hose clip you will be able to twist the pipe away from the filter. |
| Subject: Re: A sponge? That's not standard equipment! Thu Apr 18, 2013 1:05 pm | |
| That's worth a try. Maybe I'll give it a go this afternoon. |
