| Subject: applei tunes to mp3 Sat Jun 20, 2009 1:41 pm | |
| hi all need a little help with two things first i have a garmin zumo and a blank sd card how do i take tracks fron i tunes convert to mp3 and then place then on the sd card ,second i was talking to honda uk the silverwing gt will not come here next year there is no market for it so i ship one from the u s a if i want one ,also anyone know of a cam that i can place on the wing please |
Opalsboy Silver Wing Guru
Number of posts : 1288 Age : 80 Location : Rison, Arkansas Points : 7267 Registration date : 2009-01-10
| Subject: Re: applei tunes to mp3 Sat Jun 20, 2009 4:14 pm | |
| [quote="adammetselaar"]hi all need a little help with two things first i have a garmin zumo and a blank sd card how do i take tracks fron i tunes convert to mp3 and then place then on the sd card ,/quote]
Record your tunes to your PC (or MAC). You will need a USB card reader that will read your SD card. Copy the files to your SD card as MP3 format. Then you can install the SD card to your GPS and play. You can find USP Card readers on Ebay and at retailers everywhere. Get one for less than $10.00 ( http://shop.ebay.com/items/usb%20card%20readers?_dmd=1&_sop=12 ) There are many many places to get one.
If you have more questions, post or send me private message.
Gary |
| Subject: problem i have Sat Jun 20, 2009 4:38 pm | |
| how do i get i tunes into mp3 format as its acc thats my problem |
| Subject: MP3... Sat Jun 20, 2009 4:48 pm | |
| Give me a minute... I will have to look at this a few... I don't use Itunes... Be back... Gary |
Number of posts : 2778 Age : 74 Location : NE Oklahoma Points : 9094 Registration date : 2008-12-28
| Subject: Re: applei tunes to mp3 Sat Jun 20, 2009 4:50 pm | |
| Subject: Re: applei tunes to mp3 Sat Jun 20, 2009 5:20 pm | |
| I did a search in Itunes Help.. for MP3 ... I got a list with the following suggestion among the list. Kinda jumbled up, but I did figure it out and converted on of my original Itune files to MP3 .. If I can do it, you can. Let me know where you get to if you still need more help. You can do this. Gary
Saving a copy of a song in a new file format
You can convert a song to a different file format while keeping a copy of the original. For example, you can save a copy of a compressed song file such as MP3 or AAC in an uncompressed song format (AIFF or WAV). When converting from a compressed to uncompressed file format (for example, from MP3 to AIFF), you shouldn't notice any reduction in sound quality. However, when converting between compressed formats (for example, MP3 and AAC), you may notice a reduction in the sound quality. For the best results, if you want your music encoded in a different file format, import the music again from the original source using the new encoding format. Important:Except for iTunes Plus songs, you can't convert iTunes Store purchases.
[b]To convert a song's file format: Choose Edit > Preferences, click General, and then click Import Settings.
In the Import Using pop-up menu, choose the format you want to convert the song to, ( you wanted MP3) and then click OK to save the settings.
Right-click a song and choose one of the choices is "Create MP3 Version"
The song in its original format and the newly converted song appear in your library.[/b] Then you should be able to copy to your SD card for using in your GPS. Hope this helps.
Gary |
