- MadDog wrote:
- I suppose its the Insurance companies who would not like to much of a change of wheel size.
I had thought about going to the Dark-Side on the back wheel ,just for the mileage on the Sumito ? tyre but it seems they are not available in the UK and I can't find an equivalent one . If anyone knows of one I'd be interested , not being a speed merchant the negatives of riding on one from what I have read don't worry me .But what bugs me is the mileage on bike tyres surely harder compounds would bw an advantage to the riders ,but its all about profits.
MadDog
Had nothing when I started and still got some left
- Tom G wrote:
Yes, MadDog, it is, always has been, and always will be about money.
And, I suspect altering the tire size on the Silver Wing would be more trouble & money that it would be worth.
For Meldrew & others:
First, not all members keep current consistently. In fact, most do not but there are a number of
more regular posters. So the comment about the OP not having posted in a long time is not really
being fair. In fact, I had signed up here, forgot that I had and after some time when I came back
had to explain why I did not post an intro message and why I had not posted any messages during
that long initial absence.
Secondly, it is a valid question to ask why the OP would want to use a taller wheel. When clarifying
a question one would be better able to give an appropriate and meaningful answer. But, it does seem
apparent that the OP does not know (according to info given by others here) that even when swapping
out the wheel for a taller one, that when using standard bike tires, the overall diameter would still be
about the same. However if the OP wanted a larger overall diameter, then simply using a car tire with
a larger diameter would get him there. However, I am not sure of availability of standard bike tires
that would get him get a larger diameter using bike rims of any particular size that would fit correctly
on the Silverwing. There might be problems beyond just a taller wheel fitting onto the Silverwing. The
matter of brake disk size and placement could be a concern and if ABS brake equipped, ABS pulser ring
size, fitment and sensor placement could also be problematic.
MadDog: Last I knew, car tyres on bikes in your country were/are forbidden.
For MadDog & others: Re bike tires; No, it's not about the money, never was. I explain that among a great
many other things about using a car tire on a scooter here:
http://mcdarksiders.forumotion.com/t7188-for-maxi-scooters-the-darkside-according-to-bandito2-part-1-2
This; from that message:
> Motorcycle tire manufacturers make the best tires they can for bikes and car tire
> manufacturers make the best tires they can for cars. There is no conspiracy of motorcycle
> tire manufacturers making tires that don't last just so that they can sell more bike tires
> to a captive market. It is the rounded profile design of bike tires and the way they are
> used that limits their usable lifetime. They could use an even harder tire compound to make
> them last longer, but in doing so, they would have less grip. They could make a bike tire
> that could last maybe near as long as a car tire and have it fit onto the bike rim as a
> motorcycle tire would......... but it likely would look an awful lot like a car tire. (wide
> center tread) And it would probably exhibit many of the same handling peculiarities of a car
> tire on a bike. The rounded profile of a bike tire that makes it so smooth and consistent in
> turns is the very thing that dooms it to a shorter life than a car tire.
BTW, car tire compound is softer than that used for bike tires. And comments on insurance and
warranties are in the message as well as explanations why car tires last longer than bike tires
even though they use a softer rubber.
And! it is not more trouble & money than it would be worth when altering the size (or type) of
tire for the rear on a Silverwing 600 bike. Generally speaking, car tires are less expensive than
bike tires and are already known to last far longer than bike tires. (there are reasons for that as
explained in "For Maxi-Scooters The DarkSide (according to bandito2) Part 1 & 2"
Swapping out the wheel for a taller one would not seem to give much, if any advantage and may
have some problems that may be more costly to resolve than it would be worth. But getting a
taller tire may be easier and less expensive to do.
As always, YMMV
