valves tapping at 50 mph I_icon_minitimeby zrx212 Yesterday at 4:40 pm
valves tapping at 50 mph I_icon_minitimeby Meldrew Yesterday at 4:37 pm
valves tapping at 50 mph I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
valves tapping at 50 mph I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
valves tapping at 50 mph I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
valves tapping at 50 mph I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
valves tapping at 50 mph I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
valves tapping at 50 mph I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
valves tapping at 50 mph I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
valves tapping at 50 mph I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
micbusathens
rollsroyce250
Pastor Ron
horizontal
buddy19520
Ghost_rider
Ghost_rider
Ghost_rider
Number of posts : 64
Registration date : 2009-01-12
valves tapping at 50 mph Empty
PostSubject: valves tapping at 50 mph   valves tapping at 50 mph I_icon_minitimeSun Jul 07, 2013 2:12 pm
Guys and gals
When I am riding my bike at what the speedo says 55 and I
know the speedo is off a couple of mphs to high. So the real
speed is 50 I would hear the valves clinging BIGTIME. I do
not remember this happening on my 04 swing that I sold.
I have roughly 2.800 miles on it right now so there should
not be that valve noise at a true speed of 50. That is the only
time it does this and I am curious to know IF it is the gas that
I use or what??? I have a 2010 silverwing just for your info
Does anyone else have this sort of problem on there swings??
Ghost rider Greg
Houston tx. usa:SWing: https://2img.net/u/3413/63/00/33/smiles/383825.jpg
buddy19520
buddy19520
Number of posts : 378
PostSubject: Re: valves tapping at 50 mph   valves tapping at 50 mph I_icon_minitimeSun Jul 07, 2013 2:38 pm
29000 miles on my 2003 and no valve noise. I have never had the valves adjusted.
I am surprised you hear it only at one speed. I recently adjusted the valves on my Vespa GTS, and now I can hear the valves tapping, but it happens at all speeds. It is less noticeable at higher speeds than lower speeds. Time to do it again.
Are you sure it is valve noise?
Ghost_rider
Ghost_rider
PostSubject: Re: valves tapping at 50 mph   valves tapping at 50 mph I_icon_minitimeSun Jul 07, 2013 2:46 pm
Yes it is the valves tapping I know the sound.They may not need to be adjusted at all. BUT I am
thinking it could be the gas. I use mostly mid range gas not regular. I have used higher octane
gas but the mpgs are the same as mid range mpgs are.
Still does puzzle me Why would the valves be making that noise only at 50 true speed?????
horizontal
Number of posts : 14
Registration date : 2012-04-28
PostSubject: Re: valves tapping at 50 mph   valves tapping at 50 mph I_icon_minitimeSun Jul 07, 2013 4:26 pm
sounds like pinking,if so could cause damage to piston crowns. I would try higher octane fuel.
Pastor Ron
Number of posts : 400
Registration date : 2013-02-24
PostSubject: Re: valves tapping at 50 mph   valves tapping at 50 mph I_icon_minitimeSun Jul 07, 2013 8:56 pm
Why go to a higher grade....should we not stick with lower grade?
And, yes, I believe it is the gas...if you have filled it with a less known supplier, this may be the problem....I have even heard of (what would be considered) a good grade of gas getting water in their tanks....
I would run it (if the only time you hear it is at 50)....and run it low and then fill it with a different type gas....but...I would use low grade not high.
rollsroyce250
Number of posts : 73
Registration date : 2012-06-21
PostSubject: Re: valves tapping at 50 mph   valves tapping at 50 mph I_icon_minitimeMon Jul 08, 2013 1:22 am
Valves don't make noise at a specific speed, they make noise all the time if they're out of adjustment.   Check the drive train, not the valve train.
horizontal
PostSubject: Re: valves tapping at 50 mph   valves tapping at 50 mph I_icon_minitimeMon Jul 08, 2013 10:07 am
Hello Pastor Ron.
The suggestion to use a higher octane fuel was to try and determine if the fuel was the cause of the problem. I agree there should be no reason to use anything other than what Honda recommends. cheers.
micbusathens
micbusathens
Number of posts : 199
PostSubject: Re: valves tapping at 50 mph   valves tapping at 50 mph I_icon_minitimeMon Jul 08, 2013 12:38 pm
There's no way for valves tapping at certain rpms or mphs.There are some transmition noises that they look like preignition sound but their true source is from roller weights.At that certain speed they are about to fully disengage the "clutch"
micbusathens
micbusathens
PostSubject: Re: valves tapping at 50 mph   valves tapping at 50 mph I_icon_minitimeMon Jul 08, 2013 12:43 pm
By the way .....50 kmiles and valves are in limits.
Ghost-rider
Registration date : 2013-07-25
PostSubject: Re: valves tapping at 50 mph   valves tapping at 50 mph I_icon_minitimeThu Jul 25, 2013 11:37 pm
Guys
Sorry about the delay I was locked out of this forum do to a old email address that I do not have
anymore.I am STILL hearing that noise like a pinging only at 50 mph and I have used other
gas and it still does that pinging. I am going to have to have my brother take it for a ride and
see IF he can determine the noise pinging. He is a motorcycle mechanic on Harleys and he has
done work on my silverwing the old bike I had. I am also going to put it up on the centerstand
and see IF it does the same noise..
Thanks for your help
Ghost rider Greg
Houston tx. usa
Number of posts : 3313
PostSubject: Re: valves tapping at 50 mph   valves tapping at 50 mph I_icon_minitimeFri Jul 26, 2013 6:36 am
First 2010 with 2800 miles? Valve noise usually at all engine speeds. Don't screw around, take it to a Honda dealer. Doubt is anything wrong.
Ghost-rider
PostSubject: Re: valves tapping at 50 mph   valves tapping at 50 mph I_icon_minitimeSun Aug 11, 2013 11:40 pm
Guys
I have been listening to he noise and it is not the valves tapping thank GOD. From what a
couple of you riders have said it could be thee transmission which does sound correct. I did
put the bike on the centerstand and and got it up to 50 and there was no noise at all. I did
not get to talk with my brother about this yet but I am going to do so hopefully this week
and let him take it for a ride. Because I do not want to take it to a dealer and they charge
you a arm and a leg. So is this noise pinging a lot at 50 a thing to worry about? IF anyone else
has heard of this noise on there swing. It sounds like ball bearing in a can at that speed all
grinding together..
Ghost rider Greg
RazorbackUofA
RazorbackUofA
Number of posts : 85
Registration date : 2017-04-23
PostSubject: Re: valves tapping at 50 mph   valves tapping at 50 mph I_icon_minitimeMon Oct 02, 2017 12:13 am
seams like i only come here when there's a problem with my SW ........ having same issue with Lifters that am unsure about.   sounds like "Ping" lifter noise, and noticeable  just when you start to load the engine. watched a few youtube vids ... and looks like those shims would not make the lifter noise you would think......  the shims are spacers that sit in small buckets
not a SW but concept is the same.
dont look like anything i would want to tackle on my SW
BUT the Lifter noise or pop noise .. it dont look like those shims would make it? i am familiar with traditional lifers being noise .. but dont know what shim noise is unless thats what i am hearing now  DUH
also am going to see if changing oil and using engine cleaner to try to flush the whole enin with something like sea foam marvel, stp or other engine cleaner will affect the shims, could also be gasoline, an ignition issue.
RazorbackUofA
RazorbackUofA
PostSubject: Re: valves tapping at 50 mph   valves tapping at 50 mph I_icon_minitimeMon Oct 02, 2017 10:06 am
https://i.servimg.com/u/f11/19/67/90/44/22197610.jpg
will see what this doesvalves tapping at 50 mph 22197611
lloyd193
lloyd193
Number of posts : 327
Registration date : 2017-05-13
PostSubject: Re: valves tapping at 50 mph   valves tapping at 50 mph I_icon_minitimeMon Oct 02, 2017 3:05 pm
You do not state how many miles are on your Silverwing, Honda recommends periodic valve adjustment.
A broken cord in a drive belt striking the belt case sounds like a valve tappet, Check your drive belt and replace it by 25,000 miles.
Happy motoring Lloyd 193.
lloyd193
lloyd193
PostSubject: Re: valves tapping at 50 mph   valves tapping at 50 mph I_icon_minitimeMon Oct 02, 2017 7:30 pm
May be belt slap---my second SilverWing 2013 leftover, near 50,000 miles, has always had belt slap noise at 40mph with new or old belt, my first 2009 did not have this noise.
As I ride alot/have ridden a lot with these rubber band drive scooters....near 400,000 miles with 9 new ones----based on this experience, change belts at Honda recommended intervals with OEM belt, period.
My reasoning=walking sucks, breakdowns on trip can be expensive! My record=one broken belt on trip with Helix near end of service life of belt. I always carry spare belt. Dealers will never have one in stock, delays are expensive!
Put reg gas in bike, WalMart house brand 10-40 works great---do not baby. Both my SilverWings went near 50,000 miles with no valve adjustment or funny valve train noises....and no engine trouble.
RazorbackUofA
RazorbackUofA
PostSubject: Re: valves tapping at 50 mph   valves tapping at 50 mph I_icon_minitimeThu Oct 05, 2017 8:41 am
TY Loyd and John
the sea foam did help with the noise but not much i could tell the engine liked the new clothes .... BUT after reading your comments and the noise still there 70% i did some better paying attention with my ears and u are correct the noise is defiantly belt slap originating from that area not up front where the valves are located or a frayed belt but slap is likely.
i change the belt every 12-16k miles last time was at 45k it currently has 52k so will be taking a look at the belt but will probably order a new one to replace while an takeing a look.
NOTE: the sea foam / new oil, helped what it does is re-energize's the oil loc inside the valve buckets and hard to get to places for the oil.
PRICE for a Valve adjustment according to my Honda dealer: 5-12 hours at $100.00 an H. shim kit costs less than 50 bucs.
» Tapping noise from rear drive unit when cold...
» valves adjustment
» Checking valves
» Tire Valves and Stems - what do I need to know
» Service Costs
