- gunars wrote:
- Did you also enable accelerator pump utility?
Did any modifications there?
I'm not really sure what that is. Can you explain it to me please?
I just filled up today so this is my first time I've filled up with the power commander. I went for a nice ride where my average speed was 45-65 actual, and I went 55.2 miles before the first mark on the gas gauge went out. That is usually what my mileage works out to be, when the first mark disappears. So if this is the case when I do have to fill up then I should avg about 55 mpg. Riding like this I would avg 48-49 mpg, and that is when the first mark would also disappear, so I should get at least a 5 mpg improvement with the Euro map in the Power Commander.
After a couple of tanks I'm then going to install Bill's map and I will give my avg then too. I said once that the first 2 mods that I would do on the SWing would be the:
1) Taller windshield
2) J. Costa variator
Now I would have to say that my new choice would be:
2) Power Commander
The PC just makes the ride smoother and I feel the mileage is a good improvement. Even though I haven't went a full tank I can already see that the mpg's are going to be improved a good amount. But I will get back to you all after I get a couple of more tanks and will record the mpg's.
