steve Scooter Rider
Number of posts : 11 Points : 5609 Registration date : 2009-07-02
| Subject: rpm when cvt engages Wed Jul 08, 2009 10:43 pm | |
| I seem to be close to 2500 rpm before the swing starts moving. Dosn't this seem high? and how do you adjust...tks |
MikeH Scooter Rider
Number of posts : 74 Location : Eden, Utah Points : 5732 Registration date : 2009-05-02
| Subject: Re: rpm when cvt engages Thu Jul 09, 2009 12:03 am | |
| That is the normal RPM for clutch engagement. It takes that much rpm for the clutch to overcome the force of the clutch springs. The only way to adjust it is to change out the clutch springs.....or go to an aftermarket clutch. |
steve Scooter Rider
| Subject: Re: rpm when cvt engages Thu Jul 09, 2009 3:17 pm | |
| mike - a friend down the street has an 09 and he says his comes on below 2000. My 07 burgman 650 comes on below 1500. I am so confused....steve |
| Subject: Re: rpm when cvt engages Thu Jul 09, 2009 3:51 pm | |
MikeH Scooter Rider
| Subject: Re: rpm when cvt engages Fri Jul 10, 2009 1:40 pm | |
| - steve wrote:
- mike - a friend down the street has an 09 and he says his comes on below 2000. My 07 burgman 650 comes on below 1500. I am so confused....steve
Steve, From what I read on various forums, 2200 - 2500 is a normal range for clutch engagement on the S'Wing. Mine engages at 2500 when I use a very slow acceleration to try and pinpoint the exact engagement. However, if I give it full throttle, it probably engages around 2000 RPM (hard to tell exactly because the tach needle is moving rapidly). You friend's '09 could be engaging at a lower RPM for several reasons. 1) It is a newer belt with less wear. 2) He could be measuring his clutch engagement at WOT instead of very slow acceleration. 3) He could have a different clutch spring or clutch shoe springs, 4) He could have different variator weights. There is no use comparing the S'Wing clutch engagement RPM to the Burgman. They are two different animals with two different designs and two different sets of components. |
steve Scooter Rider
| Subject: Re: rpm when cvt engages Fri Jul 10, 2009 4:13 pm | |
| mikeh - you are 100% right - my friend may not be accurate - he only has 600 miles - and yes I cannot compare the burgman - when coming to a stop on the suzuki - there is some type of grabbing and engine slowing all the way to stop. much different animals - I will have to go back to using the brake with rpms up when making a U turn...tks...steve |
