Number of posts : 58 Location : Paris Points : 4210 Registration date : 2013-05-23
Subject: Seat damper upgrade? Fri Dec 06, 2013 9:20 am
Hey,
On my Burgman 400, I had found on a forum a mod that consisted in changing the damper to a model that allowed almost a 90° opening.
No change to the hoist point, just a swap of the damper
Does anyboby tried that on the Silverwing?
Cheers
Honda damper is 83590-MCT-003
Subject: Re: Seat damper upgrade? Sat Dec 07, 2013 10:09 am
Umm, No, but would you happen to know the sizes of the OEM and that 90° seat lift for the Burgy? I agree that it sure would be nice to have the seat open a lot further than is does.
Old Limey Silver Wing Expert
Number of posts : 921 Age : 80 Location : BOLTON LANCASHIRE ENGLAND Points : 6221 Registration date : 2010-06-09
Subject: Re: Seat damper upgrade? Sat Dec 07, 2013 12:11 pm
Somebody did change the seat damper,( they did pictures) I changed mine as well. It must be somewhere in the achives
Subject: Re: Seat damper upgrade? Sat Dec 07, 2013 6:06 pm
You may be thinking of Hotwings' eBay seat strut upgrade, or HondaSilver's post about seat strut he got from McMaster-Carr. But none of those aftermarket struts raise up anywhere near 90°.
Does anyone have any further info on that high rise strut?
hotwings Silver Wing Expert
Number of posts : 876 Age : 54 Location : Ontario Points : 5491 Registration date : 2012-04-29
Subject: Re: Seat damper upgrade? Sun Dec 08, 2013 6:26 am
I dont think getting the seat to raise to 90° could be easily done! The strut length is limited by the distance between the mounting points! I did change the oem strut, but only because it was weakening and would just barely keep the seat opened. Personally the opened seat seems adequate to access anything stored below!
woodworker Maxi-Scooter Rider
Number of posts : 129 Location : Oxford u.k. Points : 4164 Registration date : 2013-09-19
Subject: Re: Seat damper upgrade? Sun Dec 08, 2013 7:35 am
Never known why most scooter seats including the silverwing do not open sideways ,like on the Honda swing 125cc. Much better access to all your gear .
badaboum Scooter Rider
Subject: Re: Seat damper upgrade? Sun Dec 08, 2013 3:43 pm
Sorry for the delay
Here is the link to the french forum where I found my upgrade of the 400 burgman to a ''longer'' damper that allowed almost a 90° opening
The damper was exact same size when ''retracted'' but goes a bit more when extracted
It's a swap task, no tools needed
Subject: Re: Seat damper upgrade? Sun Dec 08, 2013 6:16 pm
Thanks for the link. Unfortunately it looks as if you've got to be a forum member, as well as be conversant in French, to view any of the information there.
Subject: Re: Seat damper upgrade? Mon Dec 09, 2013 5:42 am
I can extract the data if you need..
Subject: Re: Seat damper upgrade? Mon Dec 09, 2013 9:42 am
Yes, thank you. Manufacturer's name, part number, size measurement, and a link to purchase would be very helpful.
Subject: Re: Seat damper upgrade? Mon Dec 09, 2013 9:56 am
ON the burgman here is a picture of the old and new damper
I am wondering if we could not do the same upgrade on the Silverwing.
If I have the OEM data such a : length, course, force and diameter I can pick us a new one that has a stronger force and a longer course...
What do you think?
Subject: Re: Seat damper upgrade? Mon Dec 09, 2013 11:45 am
Sounds like a covert affair. Best way to extract the required documentation is to infiltrate their ranks! If that doesnt work use the cover of darkness at night!
My Reflex is that way, much better.
How far will the seat open with out the damper? If it get up close to 90 deg. , remove the damper and uses a stick.
Subject: Re: Seat damper upgrade? Wed Dec 11, 2013 7:52 am
Yeah but the stick is realy not good for day to day use.
It's not that bad for maintenance work, but for day to day..
Anyone has an idea how to get all the dimensions and force of the damper?
Subject: Re: Seat damper upgrade? Wed Dec 11, 2013 10:49 am
The seat strut body is 15MM diameter and 165 MM long (from eyelet center), the shaft extends 12MM from the strut body end to the eyelet center, the total extended length is 280MM from eyelet to eyelet centers. All measurements are approximate. I also read somewhere that the total force of the strut is 5kg.
Subject: Re: Seat damper upgrade? Wed Dec 11, 2013 10:57 am
Your interpretation is correct. The shaft diameter is 6 mm, the strut body is 145 mm long without the eye, and the eye diameter is 8 mm
I could be wrong about the 9 kg lifting weight for the OEM seat strut. The markings on the strut are "SHOWA 5 k 09" --if that helps.
Subject: Re: Seat damper upgrade? Thu Dec 12, 2013 1:36 am
ok, and the total extended lenght is 280 (eye to eye)?
About the Force, we need to dig more..
Thanks
Subject: Re: Seat damper upgrade? Thu Dec 12, 2013 8:41 am
Yes, approximately 280 mm, eye to eye. Regarding the lift force; as far as I know it's either 5 kg or 9 kg. But which ever it is it is insufficient to support the seat if the seat has any upgrades --like a raised butt rest-- or if a butterfly should land on it.
I can't see how another seat strut could mount at the same locations and raise the seat higher unless the rod has multiple sections --like an umbrella handle.
Subject: Re: Seat damper upgrade? Thu Dec 12, 2013 9:44 am
I need to be sure about the ''course'' of the strut
It needs to be measured from the top of the body till the begining of the eye of the rod..
Cheers
Subject: Re: Seat damper upgrade? Thu Dec 12, 2013 9:47 am
simple fix= take damper off----use paint mixing stick to prop up seat at just about any angle you want---works great if you have added junk to make stock seat weigh more
Subject: Re: Seat damper upgrade? Thu Dec 12, 2013 10:09 am
badaboum wrote:
I need to be sure about the ''course'' of the strut It needs to be measured from the top of the body till the begining of the eye of the rod..Cheers
As above, 115 mm +\- 2%
Subject: Re: Seat damper upgrade? Thu Dec 12, 2013 10:27 am
Ok then there is no change we found a strut that has the same body size and a longer rod extension..
Shame..
Here are the only one that are close
Pm5 Course = 100 Body = 285
Pm6 Course = 120 Body = 325
wobble Scooter Rider
Number of posts : 8 Location : Milngavie, E Dunbartonshire Points : 4384 Registration date : 2012-09-17
Subject: Re: Seat damper upgrade? Fri Jan 24, 2014 7:10 am
Just replaced mine with one from China: a11093000ux0431 20kg Force Gas Strut Shock Spring Lift Support Rod 11.4
Purchased from www.sourcingmap.com £8 delivered in 10 days. % minute replacement job. Well chuffed.
Subject: Re: Seat damper upgrade? Fri Jan 24, 2014 8:59 am
Did you had an improvement in seat openning range?
No difference in opening range, merely replacing worn out item. As others have said, I doubt you can open seat further due to mounting points, but then I've always found opening large enough.
jenisaswnut Scooter Rider
Number of posts : 2 Age : 58 Location : San Diego Points : 3856 Registration date : 2014-02-21
Thank you, wobble, for posting the site that has the damper/opener. I came really close to paying $30 for the OEM part...but now, I am thinking of going to the place where you got yours. They only want $13.29 for their part. How is it holding up for you? Are you happy with the damper? Would you buy it again or would you go OEM for twice the money? Thanks for your advise. Sincerely, jenisaswnut
Subject: Re: Seat damper upgrade? Sat Feb 22, 2014 2:25 pm
Probably better than OEM to be honest.
Subject: Re: Seat damper upgrade? Sun Feb 23, 2014 8:09 am
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7483 Registration date : 2010-02-03
Subject: Re: Seat damper upgrade? Sun Feb 23, 2014 11:40 am
Thanks Glenn that link goes in my favorites.
oli18 Scooter Rider
Number of posts : 14 Location : London, UK Points : 4914 Registration date : 2011-04-16
Subject: Re: Seat damper upgrade? Wed May 07, 2014 2:10 am
Just wanted to give this a bump after I just replaced mine - good fast service and a really strong bit of force - more than I expected!
Thanks Wobble!
Oli
HORNBLOWER Maxi-Scooter Rider
Number of posts : 171 Age : 69 Location : Birmingham UK Points : 4194 Registration date : 2013-10-08
Subject: Re: Seat damper upgrade? Sun Jul 20, 2014 4:21 am
Thanks for posting this Wobble! I ordered one and it has just turned up. It looks good but the chrome on the shaft was a little rough so I polished it and it is now smooth so hopefully won't rub the seals and wear out quickly. The only problem was it took 2 ½ months to turn up!!! But seeing as the scooter has been off the road most of that time due to hitting a massive pothole it wasn't a problem. I guess I will be able to put my trunk light bulb back in now coz the seat will lift rather than staying down but unlocked and flatten the battery.
