dash connection I_icon_minitimeby JohnyC Today at 5:39 am
dash connection I_icon_minitimeby JohnyC Yesterday at 10:04 am
dash connection I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
dash connection I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
dash connection I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
dash connection I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
dash connection I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
dash connection I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
dash connection I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
dash connection I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 dash connection
3 posters
echris108
Number of posts : 27
Registration date : 2013-10-05
dash connection Empty
PostSubject: dash connection   dash connection I_icon_minitimeWed Feb 26, 2014 12:14 am
hi,anyone here has a picture of the speedometer with the connectors on.?
i broke one of the connectors to my speedo so i need a picture to tell me when which wire goes to.
thanks a lot
email:echris108@yahoo.com.sg
PostSubject: Re: dash connection   dash connection I_icon_minitimeWed Feb 26, 2014 10:06 am
There are two connectors at the speedo; 16 pin and 12 pin. The 16 pin connector is the upper one. However if you actually need to determine which wire goes to which terminal then you'll have to check the wiring diagram in the Factory Service Manual.
echris108
PostSubject: Re: dash connection   dash connection I_icon_minitimeWed Feb 26, 2014 10:48 am
mine 12 pin plug broke into pieces when i tried to pull out the plug.so i need to figure out which wire goes to which pin on the speedo.
read the electrical diagram,but it didnt show the position of the wiring at the plug.
i was trying to check out the smd led on the speedo. having problems getting the needles off so gave up before further damage to the unit.
PostSubject: Re: dash connection   dash connection I_icon_minitimeWed Feb 26, 2014 11:47 am
Chris, The 12 Pin terminal has two vertical tracks of male terminals. They are numbered; 1 at the lower left with terminal 6 at the upper left; and terminal 7 at the lower right and 12 at the top right.
Assuming that the 1 terminal is at the bottom of the illustration of that combined 12P/16P connection on the wire harness diagram in the FSM (for a 2003 non-ABS model), the terminal connections by color code, from the bottom up, are:
1-N/C; 2-P/O; 3-R/Bl; 4-)Bu/Bl; 5- W/Bl; 6-N/C;
7-N/C; 8-W/Bu: 9-N/C; 10-Bu/R; 11-Bu;12-Y/G.
Of course N/C = No Connection
ScooterBJ
Number of posts : 170
Registration date : 2013-11-14
PostSubject: Re: dash connection   dash connection I_icon_minitimeWed Feb 26, 2014 1:14 pm
Since I have my SWing mostly stripped at this time, I can take a photo or 2 if it will help? Let me know.
echris108
PostSubject: Re: dash connection   dash connection I_icon_minitimeWed Feb 26, 2014 11:27 pm
That will be every nice of you.thank you.
echris108
PostSubject: Re: dash connection   dash connection I_icon_minitimeWed Feb 26, 2014 11:30 pm
Hi tim,
Thanks for yr time.
but it seems that the wires i have are kinda different.
white/blue
white/black
blue
blue/black
grey x 2
black/green x 2
green/black
PostSubject: Re: dash connection   dash connection I_icon_minitimeThu Feb 27, 2014 10:39 am
Well, given that we've identified the terminal numbers, then possibly you can get someone from the Singapore forum to post a picture of that 16P/12P connection for your model. Then use those color codes and positions to repair your connection.
ScooterBJ
PostSubject: Re: dash connection   dash connection I_icon_minitimeThu Feb 27, 2014 6:20 pm
i hope this helps. One shot from the front and one fro the back.
dash connection 2014-02-27%2016.07.55-1
dash connection 2014-02-27%2016.08.54
echris108
PostSubject: Re: dash connection   dash connection I_icon_minitimeThu Feb 27, 2014 9:42 pm
thank you BJ.yr picture reali says a thousand words!
would u mind if i post the pictures at singapore bike forum just to share the knowledge around and would really helps if this accident is to happen to some other silverwingers.
ScooterBJ
PostSubject: Re: dash connection   dash connection I_icon_minitimeFri Feb 28, 2014 7:32 am
I do not mind, you may post it elsewhere. I am happy it is helpful.
dash connection
» Rain on Dash
» Easy gps connection to brake switch
» Ooops... Fast charge wrong connection...
» Dash conversion information
» Dash light change
