Blinkers always on I_icon_minitimeby Terry Smith Today at 6:39 pm
» noise under load
Blinkers always on I_icon_minitimeby COMick Today at 6:04 pm
» Hello from Illinois!
Blinkers always on I_icon_minitimeby DescendingRaven Yesterday at 2:13 pm
» Silverwing Brakes
Blinkers always on I_icon_minitimeby Terry Smith Tue May 14, 2024 11:57 pm
» LF extended back rest
Blinkers always on I_icon_minitimeby Frenchy Mon May 13, 2024 7:57 pm
Blinkers always on I_icon_minitimeby BrianInVA Mon May 13, 2024 12:53 pm
» checking the oil
Blinkers always on I_icon_minitimeby AldusFran Mon May 13, 2024 10:11 am
» Left brake micro-switch
Blinkers always on I_icon_minitimeby Johnboy Fri May 10, 2024 7:57 pm
Blinkers always on I_icon_minitimeby BrianInVA Fri May 10, 2024 5:36 pm
» Greetings from a 'Wing' newbie
Blinkers always on I_icon_minitimeby GHM-PM Fri May 10, 2024 8:11 am
 Blinkers always on
2 posters
badaboum
badaboum
Number of posts : 58
Registration date : 2013-05-23
Blinkers always on Empty
PostSubject: Blinkers always on   Blinkers always on I_icon_minitimeFri Mar 07, 2014 3:53 am
Hey guys
on my SWT I have been installing on the topcase an additionnal amber strip led.
While doing it, I might have made a short cuircuit.
The fuse blow up, and when I installed a new one, the blinkers didn't blink, they are actually always on when I trigger the switch..
I have a custom led relay.
Do you think it is the relay or something else?
Thanks
Blinkers always on 2014307092259-4456ba0
PostSubject: Re: Blinkers always on   Blinkers always on I_icon_minitimeFri Mar 07, 2014 10:20 am
Without seeing the wiring diagram for installing your LED accessories I can only imagine that you've managed to short circuit something. You could always go back to the 1st step and test at each additional step and that way isolate the failing component.
However most of those LED strips are powered by 12Volts. So if all you are trying to accomplish is to add LED turn signals to your top case then why not wire the strips directly to the rear turn signal circuit. The + wire of each LED strip connects to either the orange wire or the light blue (orange = left, light blue = right), while the remaining - wire attaches to the frame or a ground (earth) circuit.
But if you need those LED strips to be both running lights as well as turn signal lights then we're going to need to see that accessory wiring circuit to help with that problem
badaboum
badaboum
PostSubject: Re: Blinkers always on   Blinkers always on I_icon_minitimeMon Mar 10, 2014 6:58 am
Hey tim
Thanks for your mail
I have added the strip in // to the back blinker.
What happened is that I made a wiring mistake that short circuited the fuse and the electronic led relay that I installed
I have changed the fuse and swapped the electronic led relay to the OEM one.
It works fine but I have the fast blinking issue
I re ordered an led relay from ebay for a couple of $$
Does anyone know the wiring color designation for the relay I just want to be sure before replacing the new one
Thanks
badaboum
badaboum
PostSubject: Re: Blinkers always on   Blinkers always on I_icon_minitimeTue Mar 25, 2014 2:37 pm
Confirmed
THe relay was down...
I changed it and it work perfectly
Thanks for your help
Blinkers always on
» 4-Way blinkers
» Electrical problem: back half dead, blinkers really fast
Honda Silver Wing Scooter Forum :: Other Scooters and Motorcycles :: Honda SWT400/SWT600-
