| 21g rollers | |
john&lesley Scooter Rider
Number of posts : 50 Location : bristol uk Points : 3967 Registration date : 2014-03-29
| Subject: 21g rollers Sat Mar 29, 2014 5:05 pm | |
| Putting mallossi 21g rollers on her tomorrow what is the torque setting onthe variator holdIng nut and clutch nut in nm please as thats what my torque wrench is .can I also mix 21g with 28g would this un balance the variator thanks for any info |
Mudnman Super Scooter Rider
Number of posts : 218 Location : Florida Points : 4201 Registration date : 2014-01-15
| Subject: Re: 21g rollers Sat Mar 29, 2014 5:59 pm | |
| 76 ft lbs on varo nut =xx nm? Yes mix the rollers evenly.Give me a minute . https://2img.net/h/s15.postimg.cc/l4sdhvgqj/image.jpg |
| Subject: Re: 21g rollers Sat Mar 29, 2014 7:57 pm | |
| John,
AS Mudnman said, place the rollers evenly in the variator. In other words, place a 21g than a 28gr and then a 21 gr and so forth. This way the variator will be balanced. I tried the 21 gr Dr Pulley sliders and it was a bit too high of rpms for me on the SWing. I should have just bought the 24 gr. But since you have both sets of weighted rollers I would combine them. My rpm's just seemed to high, at least for me. But I have to say, with the 21gr sliders the SWing was very, very quick. |
Number of posts : 106 Age : 81 Location : Adelaide,Sth.Australia Points : 4080 Registration date : 2014-01-30
| Subject: 21g rollers Sat Mar 29, 2014 8:05 pm | |
| Variator nut = 104N-m. Clutch=54N-m.Ensure you lubricate the variator nut thread and mating surfaces with engine oil to achieve the correct torque. |
kerdomoto Scooter Rider
Number of posts : 4 Location : Somerset, UK & Morbihan, France Points : 3891 Registration date : 2014-03-30
| Subject: Re: 21g rollers Sun Mar 30, 2014 2:58 pm | |
| So, forgive my newbie ignorance but what is the standard weight of the variator rollers? I'm not seeking rapid acceleration, more of a long-legged touring feel so what weight would be suitable? |
| Subject: Re: 21g rollers Sun Mar 30, 2014 3:42 pm | |
| The standard weight of each roller is 28grams. So the 21 grams will give you lots of acceleration. |
DickO Founding Member
| Subject: Re: 21g rollers Sun Mar 30, 2014 3:49 pm | |
| Hi "Kerdmoto", First of all, welcome to this site. It's certainly the right place to be for everything 'Silver Wing'. Secondly, I'm not the expert here but believe I've learned from from the other knowledgeable folks that the 28gr units are "standard". So that 'long legged' feel you're looking for will probably come easily from the 'sliders'. Smoothness is suppose to be their strong suit from what I've read. Personally, I'm considering getting the 24's; a good compromise if all is true. Good Luck. (I see JEFFR's already informed you of the same info) |
jmaslak Super Scooter Rider
Number of posts : 252 Location : Golden, CO, USA Points : 4805 Registration date : 2012-06-15
| Subject: Re: 21g rollers Sun Mar 30, 2014 7:41 pm | |
| At speed, any weight works like any other weight. It only affects acceleration. At highway cruise speeds, the variator is at it's maximum opening (with the exception of blipping the throttle, but most of that is due to the big spring on the clutch pulleys and the helix for those pullies, not weight of the rollers/sliders - at least at speed).
Regarding long-legged touring...if you are trying to lower RPMs at cruise, weight won't matter. Sliders are supposed to have a slightly lower high speed RPM due to shape, but it's slight and you're not going to cruise along the highway at 1500 RPM or something no matter what you are doing. It's supposed to have high RPM at cruise and can run forever that way. |
| Subject: Re: 21g rollers Mon Mar 31, 2014 6:13 am | |
| Gentlemen,
Many thanks for the above - I've got a lot to learn about CVTs and scoots in general.
Had a Vespa back in the early 60's and a Lambretta in mid-70's but that is the limit of my scooter experience and neither has much to do with modern kit (although both would be worth a small fortune now). |
| Subject: Re: 21g rollers Mon Mar 31, 2014 6:54 am | |
| Hi all thanks for the info I found some 24 g rollers as well so ive mixed 21 then 24 alternatively I coulnt get the clutch nut of so I looked behind with a little mirror on a extended bar and a light looks like plenty left on it ive got the honda holding tool for the variator so thanks all for the torque setting now on to my leaking fork seal :-( |
| 21g rollers | |
