| installing grip puppies | |
+5davidparker DickO matthew Papa Ritch tankyuong 9 posters |
tankyuong Silver Wing Rider
| Subject: installing grip puppies Sat Aug 01, 2009 10:22 pm | |
| Any tricks to installing grip puppies, I installed them today and it was a pain twisting them on anybody trim the excess on the throttle end or leave them alone? |
Papa Ritch Scooter Rider
Number of posts : 31 Age : 83 Location : DAMASCUS, Oregon USA. Points : 5632 Registration date : 2009-07-22
| Subject: Re: installing grip puppies Sun Aug 02, 2009 1:26 am | |
| Soapy water & trim the end. it will take a day or two to dry and set up. Papa Ritch |
| Subject: Re: installing grip puppies Mon Aug 03, 2009 9:18 pm | |
| - Papa Ritch wrote:
- Soapy water & trim the end. it will take a day or two to dry and set up. Papa Ritch
Exactly what I did. Soapy water works like a dream. I did trim about 1/4 - 1/2" as they come 5" which is too long for SW grips. As far as trimming goes, be a little on a conservative side as grip puppies do compress a little. Oh, and I used regular scisors for cutting them down. Thanks. |
| Subject: Re: installing grip puppies Tue Aug 04, 2009 11:55 am | |
| Where is the best place to order them for. DO you have an internet site. |
| Subject: Re: installing grip puppies Tue Aug 04, 2009 6:07 pm | |
| - fournbt wrote:
- Where is the best place to order them for. DO you have an internet site.
http://www.casporttouring.com/store/merchant.mvc?Screen=PROD&Product_Code=GPSMALL&Category_Code=grips |
matthew Touring Scooter Rider
Number of posts : 361 Location : near Santa Fe, NM Points : 6230 Registration date : 2008-12-24
| Subject: Re: installing grip puppies Thu Aug 06, 2009 12:01 pm | |
| Or try DennisB's idea and buy a $1.50 (+/-) length (6') of foam pipe insulation from any hardware store. This'll give you several replacements of grip "puppies" for next to nothing. |
DickO Founding Member
| Subject: Re: installing grip puppies Thu Aug 06, 2009 10:41 pm | |
| I tried DennisB's homemade foam insulation grips and found that, while they are a good, cheap remedy for some of you "big-fisted" folks out there, that they simply made a grip that was too fat for my short stubby hands and fingers. Think I'll try the Grip Puppies that have a wall thickness of only 0.15 inches. Might be easier for me to grip. |
davidparker Scooter Rider
Number of posts : 24 Age : 64 Location : Charleston, South Carolina Points : 4356 Registration date : 2013-01-09
| Subject: Re: installing grip puppies Sun Feb 17, 2013 10:26 am | |
| The last time I installed grip puppies, I did the soapy water trick. But, it took about a day for the water to work it's way out of the grips. So I thought I would try something else, this time. I simply sprayed the inside of the grip and the bars with a household cleaner (409 or Fantastik here in the US). It worked great! I didn't have to hurry and they were "dry" and stuck tight in about 20 minutes...
| Subject: Re: installing grip puppies Mon Feb 18, 2013 8:51 am | |
| Not sure this would work on grip puppies... but when installing grips on motorcycles, I use rubbing alcohol. Clean the bar, throttle slide then slosh some rubbing alcohol inside the grip then it will slide right on. No residue and no waiting. Have done this many times.
Only caveat here is will the alcohol damage the puppies? I don't know for certain. It does NOT hurt rubber grips at all. Good luck.
| Subject: Re: installing grip puppies Mon Feb 18, 2013 12:12 pm | |
| As I've said before on here, Grip Puppies stop the majority of heat reaching your hands if you have heated grips fitted. |
Pastor Ron Silver Wing Rider
Number of posts : 400 Age : 72 Location : Asheville,NC Points : 4767 Registration date : 2013-02-24
| Subject: Re: installing grip puppies Tue Mar 05, 2013 9:08 pm | |
| I have used soapy water before...but THIS time, I used davidparker`s idea of 409...and it worked even better. |
Yaj Scooter Rider
Number of posts : 16 Age : 67 Location : Fort Myers, FL Points : 4668 Registration date : 2012-02-28
| Subject: Re: installing grip puppies Wed Mar 06, 2013 12:34 am | |
| When I put grips or grip puppies on I spray the inside with my wifes hairspray. It helps them slip on and then when dry they are stuck on pretty good. I usually let them sit over night to dry. |
