Tool to hold cam chain tensioner? I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Tool to hold cam chain tensioner? I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Tool to hold cam chain tensioner? I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Tool to hold cam chain tensioner? I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Tool to hold cam chain tensioner? I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Tool to hold cam chain tensioner? I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Tool to hold cam chain tensioner? I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Tool to hold cam chain tensioner? I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Tool to hold cam chain tensioner? I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Tool to hold cam chain tensioner? I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
lowkey
Number of posts : 26
Registration date : 2013-09-08
Tool to hold cam chain tensioner? Empty
PostSubject: Tool to hold cam chain tensioner?   Tool to hold cam chain tensioner? I_icon_minitimeTue Aug 05, 2014 4:24 pm
I am likely wasting my time since nobody has
confessed to checking their valve clearances
themselves, but on the outside chance that somebody
actually has and not mentioned it, is there a workaround
for the special tool supposedly needed to hold the cam
chain tensioner?
Thank you.
PostSubject: Re: Tool to hold cam chain tensioner?   Tool to hold cam chain tensioner? I_icon_minitimeTue Aug 05, 2014 4:40 pm
Um...there might be a "template" in the FSM that you can copy then transfer to a piece of thin metal to cut out. IIRC someone mentioned that they cut out that piece from an old license plate. HTH
tinman
Number of posts : 1298
PostSubject: Re: Tool to hold cam chain tensioner?   Tool to hold cam chain tensioner? I_icon_minitimeTue Aug 05, 2014 5:10 pm
Get yourself a piece of 1"metal pipe strap the king to hold a bundle of plywood for shipping and form it to specs to make a key. 8_6 in the service manual 15 mm wide reduce to 8.5 mm,3 mm deep , then 4.5 mm 19mm long  total lenght is 15 mm + 19mm .If you don't have any problems leave it alone, save yourself the trouble until any problems occurs .
Number of posts : 1606
PostSubject: Re: Tool to hold cam chain tensioner?   Tool to hold cam chain tensioner? I_icon_minitimeTue Oct 16, 2018 12:08 pm
I'm reviving an old thread again! Timing Chain. Has anybody had a problem with the timing chain on their SW? There isn't much on the forum so I'm hoping that it is not an issue. My old Hondas in the 70's ( Honda K4, G5, and Dream) used to eat timing chains for breakfast and the tensioners used to break quite regularly. (What was that yellow Honda which was a sporty looking version of the G5?).
The top of this thread talks about checking the SW valve clearances. Why would we need a timing chain tool when checking valve clearances?
I wouldn't mind checking the valve clearances as part of my maintenance but where does the timing chain fit in?
Lots of questions...I'm just curious.
Number of posts : 3313
PostSubject: Re: Tool to hold cam chain tensioner?   Tool to hold cam chain tensioner? I_icon_minitimeTue Oct 16, 2018 1:16 pm
90,000 plus miles with two new SilverWings, 2009 and 2013, and no engine troubles---never bothered to check value clearances----I think waste of time/effort. Ever think what you can screw up going in there? And most SilverWings do not get high miles....as they are not ridden that much.
PostSubject: Re: Tool to hold cam chain tensioner?   Tool to hold cam chain tensioner? I_icon_minitimeThu Oct 18, 2018 3:35 am
Just as I thought. I think I'll leave well alone. bounce
» Oil pump chain replacement?
» What tool is critical in the tool bag
» Hold the driven pulley in place?
» Sprocket and chain
» "Say Hello To My Little Friend", New Tool !!
