» Fun times ahead
J Costa  Variator I_icon_minitimeby Loosemarbles Today at 3:49 pm
» Dashboard Square
J Costa  Variator I_icon_minitimeby MikeO Today at 4:11 am
» Hello From MD
J Costa  Variator I_icon_minitimeby GHM-PM Yesterday at 7:15 am
» LED Headlights
J Costa  Variator I_icon_minitimeby landisr Mon Oct 28, 2024 11:35 pm
J Costa  Variator I_icon_minitimeby DescendingRaven Mon Oct 28, 2024 5:15 pm
» Ignition Switch
J Costa  Variator I_icon_minitimeby POCAHONTAS Sun Oct 27, 2024 9:07 pm
» Lift Without A Lift
J Costa  Variator I_icon_minitimeby landisr Sat Oct 26, 2024 5:25 pm
J Costa  Variator I_icon_minitimeby xwelder Sat Oct 26, 2024 3:18 pm
J Costa  Variator I_icon_minitimeby xwelder Fri Oct 25, 2024 5:00 am
» Handlebar Holder Recall
J Costa  Variator I_icon_minitimeby xwelder Thu Oct 24, 2024 9:12 am
 J Costa Variator
4 posters
gorana
Number of posts : 6
Registration date : 2014-09-25
J Costa  Variator Empty
PostSubject: J Costa Variator   J Costa  Variator I_icon_minitimeMon Sep 29, 2014 9:41 am
Hi everybody,
I'm a new member as well as new owner of the fantastic SW.
I'm planning on buying the J Costa Variator. Apparently there are some different versions available. So far I have found the Evo2 and Evo3 versions.
Does anybody now the difference between different versions. On Costas web site I can only find the Evo3 version. Maybe the Evo3 is a newer version but it would be good to know the differences, as the Evo2 is cheaper.
Cheers,
gorana
PostSubject: Re: J Costa Variator   J Costa  Variator I_icon_minitimeMon Sep 29, 2014 10:36 am
As far as we here know the J Costa variator gave outstanding performance but the pin life has been abysmal. With several folks here needing to replace those pins in the 5000 to 8000 mile intervals -while the belt (officially) needs replacement at 16000 mile intervals, but lasts far longer.
Because of the dismal pin wear factor everyone removed the J Costa once their 2nd set of pins wore out and reverted to the OEM variator with many switching to Dr Pulley sliding weights. Soon J Costa seemed to cease production.
So now maybe J Costa has finally addressed that pin wear problem and has released a new version of their product. If that's the case then please feel free the be the test monkey for this forum and give us some feedback about the product and longevity. There are lots of guys here who were thrilled with the J Costa variator but were burned by the short life of the pins. Once burnt, twice shy.
JeffR_
JeffR_
Number of posts : 1103
PostSubject: Re: J Costa Variator   J Costa  Variator I_icon_minitimeMon Sep 29, 2014 11:08 am
Hi,
As Tim said...the pins wear out quckly. I changed mine about every 8,000 miles and then finally just removed it. You might be better off just using the 24 gram Dr Pulley sliders instead. The J. Costa was very nice but the first couple of years I was putting 10,000 miles a year on my bike. And it cost approx $60 with shipping to get new pins.
Number of posts : 2008
PostSubject: Re: J Costa Variator   J Costa  Variator I_icon_minitimeMon Sep 29, 2014 2:06 pm
JCosta Distributor in Sweden.
You should ask them the difference.
•SKOOTERTRIM.SE
•Liding – Sweden
•+46(0)8 6219065
•www.SkooterTrim.se
•Info@SkooterTrim.se
jc645FS EVO3 is the right one I believe.
gorana
Number of posts : 6
PostSubject: Re: J Costa Variator   J Costa  Variator I_icon_minitimeMon Sep 29, 2014 3:06 pm
Hi and thanks everybody for quick and comprehensive replies.
I have mailed J Costa about this. We have a resaler in Sweden (Skootertrim (meaning scooter tuning)) but they could not answer my questions.
I'll get back to this forum as soon as I have a reply.
I believe I'm a monkey to be;)
Cheers,
gorana
gorana
Number of posts : 6
PostSubject: Differences between J Costa Evo2 and Evo3   J Costa  Variator I_icon_minitimeWed Oct 01, 2014 4:52 am
Hi,
I just got the answer from J Costa, about the differences between the Evo2 and Evo3 versions.
Here is their reply, google translated from Spanish to English:
"The main difference is that the EVO 2, predecessor model is made ​​of aluminum.
The Model EVO 3 is ceramic coated aluminum, which makes it more durable over time."
(In Spanish: La principal diferencia es que el modelo EVO 2, es anterior modelo fabricado en aluminio.
El Modelo EVO 3 es de aluminio con recubrimiento cerámico, lo que hace que sea mas duradero en el tiempo.)
I don't know, but maybe they have tried to address the problems users have experienced regarding "pin" durability.
Anyhow, I will order one to find out how it works. I also plan to use an accelerometer to find out the difference in acceleration and top speed between the original setup and with the J Costa.
Cheers,
gorana
J Costa Variator
» J. Costa Variator
» J Costa Variator
» J Costa variator question
» J. Costa Variator Online
» Removed the J-Costa Variator
