Tourezrick Scooter Rider
Number of posts : 83 Age : 76 Location : Orland Park, Illinois Points : 3753 Registration date : 2014-09-12
![Pitted, cloudy windshield Empty](https://2img.net/i/empty.gif) | Subject: Pitted, cloudy windshield Sun Oct 05, 2014 2:40 pm | |
| My 2002 had a really pitted, scratched windshield and clouded turn signal lenses. Used "Mother's" Headlight Cleaner kit, which is a blue sponge ball mounted on a mandrel and a bottle of very fine rubbing compound. Big difference in the transparency of the turn signal lenses, but the change in the windshield was PHENOMENAL! I can see! Highly recommended! |
![model28a](https://2img.net/u/3413/63/00/33/avatars/494-23.jpg)
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7483 Registration date : 2010-02-03
![Pitted, cloudy windshield Empty](https://2img.net/i/empty.gif) | Subject: Re: Pitted, cloudy windshield Sun Oct 05, 2014 3:41 pm | |
| Tourezrick, thanks for the information. ![Pitted, cloudy windshield Icon14](https://2img.net/h/burgmanusa.com/forums/images/icons/icon14.gif) |
![Pitted, cloudy windshield Empty](https://2img.net/i/empty.gif) | Subject: Re: Pitted, cloudy windshield Sun Oct 05, 2014 5:33 pm | |
| You should probably use some kind of a sealer on that windshield now that you've abraded the original finish (along with the hazing) off of it. Those headlight polishing kits usually advise you to do that, so that same advise would hold true for your windshield as well.
![Pitted, cloudy windshield Empty](https://2img.net/i/empty.gif) | Subject: Did it! Tue Oct 07, 2014 11:35 am | |
- You should probably use some kind of a sealer on that windshield now that you've abraded the original finish (along with the hazing) off of it. Those headlight polishing kits usually advise you to do that, so that same advise would hold true for your windshield as well.
Tim Thanks, Tim! Just forgot to mention it! Old age! Rick |
![Pitted, cloudy windshield Empty](https://2img.net/i/empty.gif) | Subject: Re: Pitted, cloudy windshield Fri Oct 10, 2014 3:48 pm | |
| And having used what was left of the bottle of glaze (sealer), I went looking for more. None to be found in 'Cycle Gear', 'Auto Zone', 'Pep Boys', but ChiTown H-D had a shelf full! Took off my "Will Race Harley's For Titles" tee shirt before I entered the store! Just common sense self preservation kicking in! |
