» Rear wheel valve stem
Overheating Silverwing I_icon_minitimeby MikeO Today at 6:19 pm
Overheating Silverwing I_icon_minitimeby COMick Today at 6:13 pm
Overheating Silverwing I_icon_minitimeby xwelder Today at 12:31 pm
Overheating Silverwing I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
Overheating Silverwing I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Overheating Silverwing I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Overheating Silverwing I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Overheating Silverwing I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Overheating Silverwing I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Overheating Silverwing I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Porkie
Ofer Rothmann
Ofer Rothmann
Ofer Rothmann
Number of posts : 48
Registration date : 2013-05-06
Overheating Silverwing Empty
PostSubject: Overheating Silverwing   Overheating Silverwing I_icon_minitimeSun Dec 14, 2014 6:22 am
Hi Guys,
Recently when I'm standing in one place for a long time without driving the Silverwing start overheating.
While driving everything is ok and the engine is cooling down to the normal temp.
I checked the fan and it's working correctly,coolant level is ok but i saw a little bit of green residue between the two peaces of thermostat casing.
I am suspecting that the thermostat is not opening all the way while the engine is hot, and I already bought a new one just to be on the safe side, should i check for anything else?
Thanks,
Ofer Rothmann
PostSubject: Re: Overheating Silverwing   Overheating Silverwing I_icon_minitimeSun Dec 14, 2014 6:37 am
I would say that is normal, with the machine stationary there is no wind passing through the radiator to help dissipate heat, so long as the fans are coming on & taking the temperature back down all will be fine.
Ofer Rothmann
Ofer Rothmann
PostSubject: Re: Overheating Silverwing   Overheating Silverwing I_icon_minitimeSun Dec 14, 2014 6:47 am
Thanks for the reply,
The problem is that when the silverwing is standing and the fans are working, the engine temp continue to climb up and the engine is not cooling down.
PostSubject: Re: Overheating Silverwing   Overheating Silverwing I_icon_minitimeSun Dec 14, 2014 10:02 am
Ahhh I see in that case check/change the 'stat as is possibly the fault, but if it were mine I would first take off the vented plastic panel & thoroughly soak the radiator fins with a hose pipe (not a pressure washer), then give them a clean with a wet soft brush then wash again, any dirt/sand  build up on the fins &/or cores will drastically reduce the efficiency of the fans.
Ofer Rothmann
Ofer Rothmann
PostSubject: Re: Overheating Silverwing   Overheating Silverwing I_icon_minitimeSun Dec 14, 2014 10:32 am
Sorry,
Didn't know what the marks on the right-hand side mean and accidentally pressed the "-", how can i change it?
Ofer Rothmann
Ofer Rothmann
PostSubject: Re: Overheating Silverwing   Overheating Silverwing I_icon_minitimeSun Dec 14, 2014 11:58 am
The Bern wrote:
....but if it were mine I would first take off the vented plastic panel & thoroughly soak the radiator fins with a hose pipe (not a pressure washer), then give them a clean with a wet soft brush then wash again, any dirt/sand  build up on the fins &/or cores will drastically reduce the efficiency of the fans.
My thoughts exactly Laughing
Any reason not to flush the radiator like this guy?
PostSubject: Re: Overheating Silverwing   Overheating Silverwing I_icon_minitimeSun Dec 14, 2014 4:02 pm
Yep, that's a good example Smile
Ofer Rothmann
Ofer Rothmann
PostSubject: Re: Overheating Silverwing   Overheating Silverwing I_icon_minitimeMon Dec 15, 2014 4:35 am
Did you see that he's using vinegar to flush the system? any bad reaction can be caused by using vinegar in an aluminium engine?
Number of posts : 921
PostSubject: Re: Overheating Silverwing   Overheating Silverwing I_icon_minitimeMon Dec 15, 2014 12:18 pm
On my Last Silverwing i had an overheating problem whilst in standing traffic. In my case the lower fan grill had gotten full of dead insects etc. A good power jet of water(from a hosepipe) on the grill cleared bugs and it was okay from then on. Smile
Ofer Rothmann
Ofer Rothmann
PostSubject: Re: Overheating Silverwing   Overheating Silverwing I_icon_minitimeSun Dec 21, 2014 7:33 am
So.. on Friday morning I drained the old coolant, released and took apart the Thermostat housing and I saw that there was a residue of calcium on the inner side of the thermostat, case and O-ring.
It looks like the previous owner filled tap water in the cooling system Shocked .
Because this is an aluminum part I didn't want to scratch by using a sand paper or screwdriver, so i soaked it in hot water with vinegar and citrus salt to remove all the residue.
Then I replaced the thermostat to a new one+O-ring and flushed the system with water and vinegar, then i filled the cooling system with new coolant- now it looks fine. cheers
Number of posts : 2598
PostSubject: Re: Overheating Silverwing   Overheating Silverwing I_icon_minitimeSun Dec 21, 2014 1:53 pm
Ofer,
Congrats on finding the problem and then telling us what how you fixed it. Some here will report a problem but not come back later to tell us what they did. Good news for you.
Porkie
Porkie
Number of posts : 77
Registration date : 2014-12-29
PostSubject: Re: Overheating Silverwing   Overheating Silverwing I_icon_minitimeThu Jan 01, 2015 9:32 am
I looked all over for a 'Hosepipe' and couldn't find one? Smile
Sam:)
http://www.carthageelectronics.com
AlyD
Number of posts : 1
Registration date : 2019-02-12
PostSubject: Re: Overheating Silverwing   Overheating Silverwing I_icon_minitimeMon Feb 18, 2019 5:30 pm
Ofer Rothmann can you please share with us what you did by either a video or photos on what you actually did to overcome the overheating problem ? Feel free to send me a message or email waiting your reply thank you.
PostSubject: Re: Overheating Silverwing   Overheating Silverwing I_icon_minitimeMon Feb 18, 2019 11:16 pm
AlyD, Since you've only 1 post you are not going to be able to send or receive PMs. However, if you read this entire thread I think that you'll understand the steps to take with an overheating problem.
terrier
terrier
Number of posts : 302
PostSubject: Re: Overheating Silverwing   Overheating Silverwing I_icon_minitimeTue Feb 19, 2019 2:19 pm
ALSO, an introduction would be nice before asking for help  Mad Mad Mad
Number of posts : 4218
PostSubject: Re: Overheating Silverwing   Overheating Silverwing I_icon_minitimeTue Feb 19, 2019 2:40 pm
You'll have a long wait, have you not noticed this topic was started way back in December 2014 by Ofer Rothmann, and the last time he logged onto the forum was two years ago.
» 2012 Silverwing One year Riding Impressions
» my silverwing
» SilverWing 250!!!
» Just got my Silverwing
» Silverwing in UK?
