Looking for a power outlet? I_icon_minitimeby Hop Today at 7:04 pm
» Rear wheel valve stem
Looking for a power outlet? I_icon_minitimeby GHM-PM Today at 6:43 am
Looking for a power outlet? I_icon_minitimeby COMick Fri Nov 22, 2024 6:13 pm
Looking for a power outlet? I_icon_minitimeby xwelder Fri Nov 22, 2024 12:31 pm
Looking for a power outlet? I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Looking for a power outlet? I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Looking for a power outlet? I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Looking for a power outlet? I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Looking for a power outlet? I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Looking for a power outlet? I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
4 posters
KurtPerthWA
KurtPerthWA
Number of posts : 1711
Looking for a power outlet? Empty
PostSubject: Looking for a power outlet?   Looking for a power outlet? I_icon_minitimeSun Jan 11, 2015 10:47 pm
http://www.gearbest.com/car-gadgets/pp_120174.html
Spotted this today. If you plumb it in with a fuse directly to battery, you can also charge the battery via a cig lighter plug and cable from the charger.
I have the in dash OEM socket, but it is only 1 amp and charging through this or exceed the amps could be hazardous to the electronics.
I have a STD stainless steel cig. lighter socket mounted under the tupperware wired directly to the battery. It was the 1st mod done when I got the scoot. Great for the air pump.
PS I have also incorporated a main batt on/ off switch for when I do charge via the plug to prevent spikes and surges from the charger or solar panel damaging the electrics.
I have also modified the battery compartment to take the cheaper 12 volt 9 AH battery which fits my other bikes as well. The Bikes and scoot all have 50 amp anderson plugs so I only need 1 healthy battery between them. Works well and saves money on battery replacement. As my scoot sits idle for long periods it is necessary to charge the batt regularly and disconnect it as well.
vader1701
vader1701
Number of posts : 106
Registration date : 2015-01-07
PostSubject: Re: Looking for a power outlet?   Looking for a power outlet? I_icon_minitimeThu Jan 15, 2015 9:33 pm
Ordered me one, this was pretty cool thanx for the link and it's a great price too
Ayjayroy
Registration date : 2014-09-11
PostSubject: Re: Looking for a power outlet?   Looking for a power outlet? I_icon_minitimeTue Jan 20, 2015 1:59 pm
Great idea: I was looking for an easy accessory plug for my GPS: just ordered one!!
Thanks for the info! Cool
PostSubject: Re: Looking for a power outlet?   Looking for a power outlet? I_icon_minitimeTue Jan 20, 2015 4:33 pm
Spotted this today. If you plumb it in with a fuse directly to battery, you can also charge the battery via a cig lighter plug and cable from the charger. <>
Kurt,
That looks to be a great add-on, but it appears to mount on the handlebar. Where did you mount this on your SW?
KurtPerthWA
KurtPerthWA
PostSubject: Re: Looking for a power outlet?   Looking for a power outlet? I_icon_minitimeWed Jan 21, 2015 12:53 am
This one separates from the handlebar mount and can be mounted on a flat surface. Someone was asking recently, and I remembered seeing it on a web site.
I wish one of these was available when I did all my wiring work some time ago.
KurtPerthWA
KurtPerthWA
PostSubject: Re: Looking for a power outlet?   Looking for a power outlet? I_icon_minitimeWed Jan 21, 2015 8:48 am
Here is another site with some good products. Go to Automotive and Motordcycle field.
http://www.banggood.com/
» Power Outlet, ended up removing the tuperware
» Power Outlet, So Easy I Could Do It
» power supply outlet
» OEM FJS/FSC600 Power Outlet
» cigar lighter socket
