Rear Axle Nut I_icon_minitimeby landisr Today at 11:03 am
Rear Axle Nut I_icon_minitimeby MikeO Thu Nov 14, 2024 6:23 pm
Rear Axle Nut I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Rear Axle Nut I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Rear Axle Nut I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Rear Axle Nut I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Rear Axle Nut I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Rear Axle Nut I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Rear Axle Nut I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Rear Axle Nut I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
 Rear Axle Nut
4 posters
canhead
Number of posts : 16
Registration date : 2012-06-26
Rear Axle Nut Empty
PostSubject: Rear Axle Nut   Rear Axle Nut I_icon_minitimeTue Jun 16, 2015 10:58 am
Failed to torque rear nut after tire change. Rode probably 200 miles, some at Freeway speeds. Unable to push into garage, put on center stand, checked rear tire and it wobbled. Checked further to find nut completely missing. Removed wheel & found damage to swing arm & brake assembly. Now off to dealership for repair. Don't fail to torque that nut! Just tightening is insufficient!
Rear Axle Nut Empty
PostSubject: Re: Rear Axle Nut   Rear Axle Nut I_icon_minitimeTue Jun 16, 2015 11:27 am
As expensive as this lesson will be for you, I hope that you didn't also trash the the splines in the rear wheel. A dealer-supplied wheel is going to put a big dent in your wallet. Thankfully(?) the rear drive shaft splines are much harder to damage. Good luck with the repair. Please let us know 'the damages'.
NWSSC
NWSSC
Number of posts : 418
Rear Axle Nut Empty
PostSubject: Rear axel nut    Rear Axle Nut I_icon_minitimeTue Jun 16, 2015 11:45 am
Sorry to hear about that. Make sure are sitting down when you get the estimate. If you have done your own maintenance you could probably do this repair with the help of a Honda repair manual.
As for leaving the axle nut loose,remember we crucified the perfect man. Howard
p.s. You might be able to purchase a used complete rear axle assemble including the wheel and brake cheaper.
andyman
Number of posts : 67
Registration date : 2009-10-28
Rear Axle Nut Empty
PostSubject: Re: Rear Axle Nut   Rear Axle Nut I_icon_minitimeTue Jun 16, 2015 7:39 pm
PM me if you need parts. I have a whole swing arm assembly and wheel sitting in the garage. Swing arm came from a bike with 5k on it.
Rear Axle Nut
» Rear axle nut
» Rear axle nut
» Parts Question - Rear Axle
» Rear Axle Nut becoming Loose
» How many lbs to tighten the rear axle nut
