sw2009 Scooter Rider
Number of posts : 9 Points : 5582 Registration date : 2009-08-25
| Subject: Premature belt wear info Thu Sep 03, 2009 8:42 pm | |
| Premature belt wear info.
Service manager (via Honda tech support) indicates that the true drive belt tolerance is 26 mm for a new belt (standard). The minimum tolerance (service limit) was quoted as "when the V indicator comes on".
Stated the tolerances given on Page 10-1 of the 2009 Service Manual are incorrect. This Honda tech fellow reportedly rides a Silverwing and should know the right stuff.
Jim Stanwood, Washington |
DickO Founding Member
| Subject: Re: Premature belt wear info Fri Sep 04, 2009 12:44 am | |
| Well... how about that... wonder if there will be a notification to other dealers and us "common folk" one of these days. I would normally say that "everyone makes mistakes now and then" but they pay people good money to guard against such mistakes. |
| Subject: Re: Premature belt wear info Fri Sep 04, 2009 5:49 am | |
| Honda are not alone - Piaggio decided that service intervals on certain of the newer engines could be increased from 4000 to 6000 miles but didn't publish it. As a result of posts on the X9 forum, it did become public knowledge. This forum/club undoubtedly performs the same service, thank goodness! Is it possible to have a special place to put information like this? - I'm still not completely familiar with the site so there may be one already. |
| Subject: Re: Premature belt wear info Fri Sep 04, 2009 12:27 pm | |
| Premature belt wear -
I wonder if the Honda dealers ever receive technical bulletins or service bulletins from Honda, and then read and understand them? Anyone know?
Jim
| Subject: Re: Premature belt wear info Fri Sep 04, 2009 2:21 pm | |
| - sw2009 wrote:
- Premature belt wear -
Jim
Stanwood, Washington The answer must be no to one of the above ... the Service Manager had to contact the Honda Tech Support. |
| Subject: Re: Premature belt wear info Fri Sep 04, 2009 10:57 pm | |
| So if Honda sez the 'V' Light coming on prematurely indicates the belt needs to be replaced before the 16000 mile interval; what is indicated if you reset the 'V' Light and it doesn't come back on again? If it continues to come back on I agree that there is "an issue" somewhere, but if the light stays off, then I think there probably isn't a problem. The belt slipping, or the rpms rising higher (for a given speed) then 'normal' is what triggers the 'V' Light. Just my 2 cents worth... |
