WHINING REAR DRIVE I_icon_minitimeby xwelder Today at 3:57 am
WHINING REAR DRIVE I_icon_minitimeby sonuvabug Yesterday at 4:19 pm
WHINING REAR DRIVE I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
WHINING REAR DRIVE I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
WHINING REAR DRIVE I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
WHINING REAR DRIVE I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
WHINING REAR DRIVE I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
WHINING REAR DRIVE I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
WHINING REAR DRIVE I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
WHINING REAR DRIVE I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 WHINING REAR DRIVE
tinman
NWSSC
bikemad
8 posters
bikemad
Number of posts : 3
Registration date : 2015-07-14
WHINING REAR DRIVE Empty
PostSubject: WHINING REAR DRIVE   WHINING REAR DRIVE I_icon_minitimeTue Jul 14, 2015 10:23 am
I bought my 2014 Silverwing 600.from a dealer, about three months ago. the bike
is still under warranty untill Oct 2015. I have begun to notice a high pitched
whine coming I beleive from the rear drive, and get more noticable when
thottling up and down in slow moving traffic at about 40 mph. I would value
anybody`s comments please. Thank You. Bikemad.
PostSubject: Re: WHINING REAR DRIVE   WHINING REAR DRIVE I_icon_minitimeTue Jul 14, 2015 10:58 am
You may have a bad beaing in the final drive. Lucky you, you are still covered by a warranty. Take it back to the dealer for repair. While a defective final drive is extremely unusual, at least your complaint will be on-record if the dealer tries to brush your complaint off and the problem remains unresolved.
Ahem...You did check the final drive oil, haven't you?
NWSSC
NWSSC
Number of posts : 418
PostSubject: WHINING REAR DRIVE    WHINING REAR DRIVE I_icon_minitimeTue Jul 14, 2015 11:27 am
Interesting question. Being in the automotive service business and
going for many road tests,listing to the question, can you hear that I took it upon my self to completely dissemble the final drive (56K) this spring on my 06 silverwing. I was never quite satisfied with the noise from the final drive. Going right to the answer, I found no reason for concern.The final drive is quite simple by design.
A input shaft, a counter shaft(to change direction)and a output shaft to deliver power to the rear wheel. None of the bearings require to be preloading so as not be a concern. I would suggest on your next ride you slightly apply the left brake and see if the noise changes or disappears.Disk brake pads can cause some mysterious noise. Next I would change the final drive lube,although I do not think this will do anything but give piece of mind.The next step would be to service the belt area including lubrication of the small inner clutch bearing.After that the next step is to ride it.
If any one else has a question I will try to do my best. Howard
p.s. If there is a achilles heal it is the left support bearing mounted in the left outer cover.This is the reason for the insulation in the cover.
tinman
Number of posts : 1298
PostSubject: Re: WHINING REAR DRIVE   WHINING REAR DRIVE I_icon_minitimeTue Jul 14, 2015 7:45 pm
The small inner clutch bearing was dry from the factory on my 09 .Remove the clutch pad assembly and look deep inside you will find the dry bearing.
NWSSC
NWSSC
PostSubject: WHINING REAR DRIVE    WHINING REAR DRIVE I_icon_minitimeTue Jul 14, 2015 9:10 pm
Although the small bearing has been a source of concern it is only noticeable on start up and turns with the clutch assembly. When the clutch assembly is completely locked up, about 3-5 mph it is not the source of any noise. But it should be lubed. Howard
bikemad
Number of posts : 3
PostSubject: Re: WHINING REAR DRIVE   WHINING REAR DRIVE I_icon_minitimeWed Jul 15, 2015 3:39 am
Thanks you all, for your informative information. !! I think a trip to the dealers first, would be the best thing. Give them a chance to sought the problem. !! Ken. ( Bikemad )
WHINING REAR DRIVE 510-80
PostSubject: Re: WHINING REAR DRIVE   WHINING REAR DRIVE I_icon_minitimeWed Jul 15, 2015 11:05 am
Also gives you a chance to see how the dealership operates. cheers
PostSubject: Re: WHINING REAR DRIVE   WHINING REAR DRIVE I_icon_minitimeThu Jul 16, 2015 8:50 am
Actually, for a while I did get a good bit of whining from the rear. But then it all went away when I stopped bringing her along...   (cue rim-shot)
dwintersnz
Registration date : 2013-05-28
PostSubject: Re: WHINING REAR DRIVE   WHINING REAR DRIVE I_icon_minitimeThu Feb 14, 2019 2:22 am
I have wondered if a manual gearbox and diff treatment additive would help with the final drive whine.
Number of posts : 1935
PostSubject: Re: WHINING REAR DRIVE   WHINING REAR DRIVE I_icon_minitimeThu Feb 14, 2019 8:48 am
MAYBE, but it could cover up a more serious problem, the trip to the dealership is the first step. GETTING THEIR written answer is another important step, a verbal answer gets you NOWHERE when the problem persists. BTDT
PostSubject: Re: WHINING REAR DRIVE   WHINING REAR DRIVE I_icon_minitimeThu Feb 14, 2019 3:06 pm
The original post was made in 2015 and the poster, Bikemad, hasn't visited this forum since July of 2015. One can reasonably assume that the "Whining" issue has been resolved one way or another.
Number of posts : 4218
PostSubject: Re: WHINING REAR DRIVE   WHINING REAR DRIVE I_icon_minitimeThu Feb 14, 2019 3:45 pm
Look at bikemad's posts more closely, he made his Intro post, asked about his scooters rear wheel drive problem, got a few answers then made his third and final post, then disappeared all within a day or so of joining.
Picking the forums brain for info was probably all he joined for.
WHINING REAR DRIVE
» Rear Drive Oil Change
» Tapping noise from rear drive unit when cold...
» Recent rear 150/70-13 rear tire experience
» Drive belt
» drive belts
