| Touching up panels... | |
Opalsboy Silver Wing Guru
Number of posts : 1288 Age : 80 Location : Rison, Arkansas Points : 7270 Registration date : 2009-01-10
| Subject: Touching up panels... Sat Sep 05, 2009 2:34 pm | |
| I am asking for any advice from someone that has used the color rite pens to touch up scratches. I use to drop my scoot every day just getting on it.. have learned that is not a requirement now... bought the color rite pens 10 months ago and just now taking the time to do the touching up. The instructions that came with the pens gives the steps for different "Stage" colors. One, two and three stage. For my 03, they sent two pens. The base and candy apple red color. I am a little confused (lets all together say "dah!"). The base is a metalic color may dry white. Then the other pen is suppose to be the color of the scoot. Sounds like a two stage color to me. BUT, the instructions refer to a "base" only in the three stage color description. I don't got the clearcoat. The web site for color rite only suggests two applications. No clearcoat is mentioned. I am going to apply the base (20 mins between coats) two coats. Then apply the apple red color. If I am messing up, please stop me. I am going to be grilling some burgers before the red is applied, so I have a little time for you to help me. Thanks again... Gary |
| | | Guest Guest
| Subject: Re: Touching up panels... Sat Sep 05, 2009 5:44 pm | |
| Gary,
That sounds right, but I would try it on something else first, to make sure it works right. Any kind of bare metal should be ok to test on. Let me know how it goes.
Mandy |
| Subject: Re: Touching up panels... Sat Sep 05, 2009 9:24 pm | |
| Well, I followed the instructions and applied the base and color to the scratched panel. I have to say that it doesn't look any worse than it did. But it doesn't look a whole lot better either. I would not recommend this product for deep scratches like I had. The scratches are covered but the coverage is very sloppy looking. My scratches are along the bottom of the panel, so I am hoping they are less noticeable with the reddish color instead of the white plastic showing the deep scratches. The pens might work with slight ones, but I doubt it. I will take my panel to a professional painter soon and get it done right.
Gary |
| | | KurtPerthWA Silver Wing Guru
Number of posts : 1711 Age : 75 Location : Belmont, Perth WA Points : 8157 Registration date : 2009-01-19
| Subject: Re: Touching up panels... Sat Sep 05, 2009 10:45 pm | |
| Gary, from my early days in bikes we only ever repainted entire panels if they were "Candy Apple" colours as they were impossible to match. This developed my tendency to go for black as my friends nicknamed me "Autumn Leaves" for a while. My MZ is a deep shade of metallic green and it fell off the stand and scarred the lower fairing. I found a very close spray touch up paint, but these oxidise/ fade much quicker than the original and now looks yuck. The CA red Vmoto lost value at trade in time on the Swing due to a minor altercation with the asphalt and leaning too hard in the corners. |
| Subject: Re: Touching up panels... Sat Sep 05, 2009 10:52 pm | |
| I have heard of a professional painter just 20 miles from me that I will go see soon. I want one of two colors. To go back to the original 03 Candy Apple Red or the Pearl White. I also want to look at adding the new dash style. This is not going to happen in the next week. May be a few months while I save up some nickels. I am a whole lot less likely to drop my scoot again. Gary |
| Subject: Re: Touching up panels... Sat Sep 05, 2009 11:12 pm | |
| MMMMMMmmmm mmmmmm translucent pearl white... |
| | | Cornishman Maxi-Scooter Rider
Number of posts : 181 Age : 71 Location : Wiltshire UK Points : 5916 Registration date : 2009-04-04
| Subject: Re: Touching up panels... Sun Sep 06, 2009 2:07 am | |
| A tip my dealer mentioned was to get some ladys' nail polish/varnish for the repair. Apparently it comes in just about every conceivable colour. Take your panel/scooter to a nail bar. it's pretty thick stuff and fills deep scratches. |
