Muffler damaged, need measurement I_icon_minitimeby john grinsel Today at 4:14 pm
» Rear wheel valve stem
Muffler damaged, need measurement I_icon_minitimeby JohnyC Today at 11:53 am
Muffler damaged, need measurement I_icon_minitimeby COMick Yesterday at 6:13 pm
Muffler damaged, need measurement I_icon_minitimeby xwelder Yesterday at 12:31 pm
Muffler damaged, need measurement I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Muffler damaged, need measurement I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Muffler damaged, need measurement I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Muffler damaged, need measurement I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Muffler damaged, need measurement I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Muffler damaged, need measurement I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Muffler damaged, need measurement Empty
PostSubject: Muffler damaged, need measurement   Muffler damaged, need measurement I_icon_minitimeMon Sep 14, 2015 11:21 pm
I had an untimely get off the other day due to an oil spill on a turn. It was caused when a municipal street sweeper vehicle blew a hydraulic line several minutes before I arrived. Thankfully I wasn't going fast, but there is a lot of road rash on the right side, unseen though is all the tupperware tabs which have broken. The muffler cover got mashed in too. Which leads to this request.
It appears that the muffler got pushed in enough so that it barely clears the coils or the rear shock. Can someone please measure the clearance between the shock coil spring and the muffler. Right now I can't get my finger to fit between the two without forcing it. Not super tight, but I think that there should be more clearance that what's there now.
I did get down and visually inspect the headers and the muffler joint for any bends or kinks, but I can't see any indications there.
I'm waiting for an insurance appraiser to show up to inspect the damages, so I can't start disassembling things until he has a look at it.
NWSSC
NWSSC
Number of posts : 418
PostSubject: Muffler damaged, need measurement Today at 11:21 pm    Muffler damaged, need measurement I_icon_minitimeTue Sep 15, 2015 12:05 am
Sorry about that Tim.Lucky for you It is only scooter parts.The distance is 1 1/2 inches from the lowest coil to the muffler. I imagine the bracket that is attached to the muffler is bent causing the close tolerance. I would suggest removing the bolt going through the bracket and see if you can pull the muffler away from the rear spring. If the bracket is bent and you are lucky you will have to remove the muffler assembly, heat the bracket and and reline the exhaust.As you are aware there is always a little more when a accident happens and Tupperware is expensive. Howard
PostSubject: Re: Muffler damaged, need measurement   Muffler damaged, need measurement I_icon_minitimeTue Sep 15, 2015 8:39 am
One and one half inches clearance between the muffler and the (closest) coil spring. Thanks Howard.
AldusFran
Number of posts : 210
PostSubject: Re: Muffler damaged, need measurement   Muffler damaged, need measurement I_icon_minitimeTue Sep 15, 2015 11:12 am
Tim, I got about 5/8 inch on mine,measured to the closest spring coil. Also I have about 3/8 inch from muffler hanger to nearest spring coil. I wish you could remove the rubber washer from the tire side of hanger but it's not a good idea. Good luck...Al
PostSubject: Re: Muffler damaged, need measurement   Muffler damaged, need measurement I_icon_minitimeTue Sep 15, 2015 11:33 am
Hmm... 5/8 seems much closer to what I have.
The hanger on the muffler may need to be heated and tweaked, but that frame hanger doesnt look like it's about to move anywhere. Pretty sturdy piece there.
Thanks Al
Muffler damaged, need measurement 510-80
PostSubject: Re: Muffler damaged, need measurement   Muffler damaged, need measurement I_icon_minitimeTue Sep 15, 2015 7:15 pm
That's about the same as mine and I don't see a need for more.
Glad you're concerned about the scoot and not the rider. cheers
HORNBLOWER
Number of posts : 171
PostSubject: Re: Muffler damaged, need measurement   Muffler damaged, need measurement I_icon_minitimeFri Sep 18, 2015 3:03 am
Sorry to hear of your off, doesn't sound like much fun. Did you get lots of pictures and have you contacted the owner of the vehicle that caused it. Had they put up any warnings? I think you could have either of these measurements depending on which side of the hanger your muffler is fixed. Mine was on the outside and stick out just under two inches but having moved it to the inside it is now about 5/8ths. Which side is yours mounted on.
PostSubject: Re: Muffler damaged, need measurement   Muffler damaged, need measurement I_icon_minitimeFri Sep 18, 2015 9:46 am
No warnings, no photos, just an Oh $hit! get off. While I did get some sore ribs (probably cracked) I never went for medical treatment. The Insurance adjuster was here the other day and declared that the scoot was totaled. Think Humpty Dumpty. Now I'm waiting for them to contact me with a settlement figure.
Meanwhile after applying judicious quantities of Duct Tape  (the handy man's secret weapon) I'm able to ride it locally. So my Cosmic Jumper at 971200 miles has now become cosmic debris.
NWSSC
NWSSC
PostSubject: Muffler damaged, need measurement    Muffler damaged, need measurement I_icon_minitimeFri Sep 18, 2015 10:57 am
If you have not already done so, make sure you make it known about any up grades and have receipts. It may not be to late to see
a doctor. Howard
» Givi AF214 damaged
» Damaged Key for Honda FJS600 Silverwing
» Help please: Frame measurement needed
» Drive Belt measurement
» Drive Belt service limit measurement
