| Partszilla question | |
Number of posts : 247 Location : Hocking Hills Points : 3846 Registration date : 2015-02-08
| Subject: Partszilla question Wed Nov 04, 2015 7:35 pm | |
| I tried their website and found it shall we say lacking, entered all my scoot info but still ended up looking at multiple brake pad entries but it requires opening each to find out what they fit. Did I miss something going into the site? |
| Subject: Re: Partszilla question Wed Nov 04, 2015 10:12 pm | |
| Partzilla can sometimes be a PITA to navigate. What's your Silverwing year, and ABS or not? I'll post the right Partzilla link for you.
NWSSC Silver Wing Rider
| Subject: Partszilla question Wed Nov 04, 2015 10:34 pm | |
| I think for the most part the difference in brake pads is ABS and none ABS. If you go to there customer service area you will find a phone number for USA and international. Howard |
| Subject: Re: Partszilla question Thu Nov 05, 2015 1:32 am | |
| Thank you both, it's a 2005 non ABS. I want to replace all brake pads and drive belt this winter, new tires also. All fluids and air filter completed as well as cleaning the dive belt housing filter. |
| Subject: Re: Partszilla question Thu Nov 05, 2015 8:00 am | |
| Here is the link to Partzilla's home page for all 2005 Silverwing, FSC600D (non ABS) parts: http://www.partzilla.com/parts/search/Honda/Scooter/2005/FSC600D+AC/parts.html And for Front Caliper parts: http://www.partzilla.com/parts/search/Honda/Scooter/2005/FSC600D+AC/FRONT+BRAKE+CALIPER/parts.html And Rear Caliper parts: http://www.partzilla.com/parts/search/Honda/Scooter/2005/FSC600D+AC/REAR+BRAKE+CALIPER/parts.html
You probably should bookmark that first link for future reference
| Subject: Re: Partszilla question Thu Nov 05, 2015 8:20 am | |
| Roger that Tim and thanks again. That's not the only web site that I've come across that seems disjointed. |
| Subject: Re: Partszilla question Thu Nov 05, 2015 8:34 am | |
| One more question if you will, I'm not really interested in more performance as I'm satisfied with it as is. That being what SEEMS to be a replacement mileage for OEM rollers ect. I figure if I'm in there I might as well get it done now while I'm still able knowing it may be the last time I'll need to do it. |
| Subject: Partszilla question Thu Nov 05, 2015 10:27 am | |
| MY 06 S/W with 55,000 miles, except for the drive belt has all original clutch parts.As you stated the belt area should be thoroughly cleaned along with a sanding of the clutch shoes.There is also a small needle bearing in the clutch hub that should be lubricated. All these items are discussed in the forum. Howard
p.s. A air compressor and a can of brake clean are handy in this area. Try not to breathe the dust. |
