| Front Right Pocket - Remove | |
![MikeO](https://2img.net/u/3413/63/00/33/avatars/308-62.jpg)
Number of posts : 3819 Age : 75 Location : Seaham, Co Durham, UK Points : 9613 Registration date : 2009-06-29
![Front Right Pocket - Remove Empty](https://2img.net/i/empty.gif) | Subject: Front Right Pocket - Remove Tue Sep 22, 2009 12:57 pm | |
| I have 'searched' and skimmed through the threads but can't find how to remove the front right pocket. I read elsewhere that squeezing the sides will do the trick.
There is a small screw at the rider's end of the pocket which I removed but was reluctant to squeeze too hard.
Any tips or hints, please?
Thanks in advance. |
![Front Right Pocket - Remove Empty](https://2img.net/i/empty.gif) | Subject: Re: Front Right Pocket - Remove Tue Sep 22, 2009 1:57 pm | |
| Hi Mike, You got it right. Just remove the screw and press the sides in and walk it on out. That's all there is to it. |
![Front Right Pocket - Remove Empty](https://2img.net/i/empty.gif) | Subject: Re: Front Right Pocket - Remove Tue Sep 22, 2009 1:59 pm | |
| Thank you, Dennis. ![cheers](https://2img.net/i/fa/i/smiles/icon_cheers.png) |
![Front Right Pocket - Remove Empty](https://2img.net/i/empty.gif) | Subject: Re: Front Right Pocket - Remove Tue Sep 22, 2009 3:44 pm | |
| Yes - box, pocket, cubby....the unlockable one. ![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif) |
![Front Right Pocket - Remove Empty](https://2img.net/i/empty.gif) | Subject: Re: Front Right Pocket - Remove Sat Jan 14, 2017 3:22 pm | |
| Update! I referred here because the service manual is NOT clear on right pocket removal and I did not want to break it!!!
Just for information; squeezing the sides and pulling the pocket out to the front worked great!!! Thanks so much, love the info we have on here. I did spend a few minutes looking for a screw at front of pocket. My 2012 does NOT have one.
So for those of you with newer scoots, there is probably NOT a screw!!! |
![Front Right Pocket - Remove Empty](https://2img.net/i/empty.gif) | Subject: Re: Front Right Pocket - Remove Sat Jan 14, 2017 3:41 pm | |
| - GHM-PM wrote:
- Update! I referred here because the service manual is NOT clear on right pocket removal and I did not want to break it!!!
So for those of you with newer scoots, there is probably NOT a screw!!! Glen, My 2013 did have a spade sheet metal screw. Came with my new Swing. My 2002, purchased used, did come with a similar spade sheet metal screw. I have removed that cubby several times to install a toggle switch for my front running lights. I also have my warning light controller installed all the way in the cubby. |
![Front Right Pocket - Remove Empty](https://2img.net/i/empty.gif) | Subject: Re: Front Right Pocket - Remove Sat Jan 14, 2017 7:11 pm | |
So for those of you with newer scoots, there is probably NOT a screw!!! Glen, My 2013 did have a spade sheet metal screw. Came with my new Swing. My 2002, purchased used, did come with a similar spade sheet metal screw. I have removed that cubby several times to install a toggle switch for my front running lights. I also have my warning light controller installed all the way in the cubby. Strange. Mine did not and I have not had pocket out. But dealer did tighten some coolant hoses at one point; perhaps they removed pocket and left screw out? Can't really see a need for it. |
![Front Right Pocket - Remove Empty](https://2img.net/i/empty.gif) | Subject: Re: Front Right Pocket - Remove Sun Jan 15, 2017 12:11 am | |
| The two SWs I had one had a screw and one didn't. I really think they all did originally but people didn't bother to replace them after removing the box to check coolant. There really isn't much need for the screw as the box won't move once it's snapped back in. I did replace the missing one on my second SW, but then I'm that way. |
![Siataukreg](https://2img.net/u/3413/63/00/33/avatars/3657-55.jpg)
Number of posts : 221 Age : 70 Location : uk saddleworth Points : 3957 Registration date : 2014-08-24
![Front Right Pocket - Remove Empty](https://2img.net/i/empty.gif) | Subject: Re: Front Right Pocket - Remove Sun Jan 15, 2017 6:17 pm | |
| I found that without the screw I got a high pitch buzz from the box screw replaced no buzz |
![Front Right Pocket - Remove Empty](https://2img.net/i/empty.gif) | Subject: Re: Front Right Pocket - Remove Mon Jan 16, 2017 8:23 am | |
| - siataukreg wrote:
- I found that without the screw I got a high pitch buzz from the box screw replaced no buzz
Interesting, mine has either never had one or it has been gone a long time and I have never noticed a buzz. Of course I keep a few things in that pocket... My 2012 is right at 20K miles now. |
![Front Right Pocket - Remove Empty](https://2img.net/i/empty.gif) | Subject: Re: Front Right Pocket - Remove Tue Jan 17, 2017 4:14 am | |
| All three of mine have had the screw in place. My latest Silverwing, ColinB's ex, is not yet four years old and came with the screw. |
SteveSilverWing Maxi-Scooter Rider
![SteveSilverWing](https://2img.net/u/3413/63/00/33/avatars/3890-58.png)
Number of posts : 133 Age : 69 Location : Los Angeles, California Points : 3601 Registration date : 2015-04-17
![Front Right Pocket - Remove Empty](https://2img.net/i/empty.gif) | Subject: Re: Front Right Pocket - Remove Thu Sep 07, 2017 1:22 pm | |
| Just pulled my right-side pocket out of the dash panel. There was no screw on mine but could see the metal bracket it would have screwed into. Like Silver Wing Guru, I will replace the screw. |
