| Oxford heated grips | |
Crustycrutch Scooter Rider
Number of posts : 76 Age : 64 Location : UK Points : 3346 Registration date : 2016-01-07
| Subject: Oxford heated grips Fri Apr 08, 2016 1:28 pm | |
| Hi people, can anyone tell me exactly which model of Oxford grips fits the Swing please? There seem to bne loads of different models available online and i don't want to get it wrong. Thanks in advance. |
Old Limey Silver Wing Expert
| Subject: Re: Oxford heated grips Fri Apr 08, 2016 1:42 pm | |
| When I got my New Silverwing in 2014 I asked for heated grips to be fitted. They fitted Oxford grips that has a low and high setting. On the leaflet with the grips it just says "Original Commuter Heated Grips" It does have a product code of OF771. Hope this helps. As an all year round rider I have had them more or less on "low" all winter, as they are wired to the ignition they can't be left on to drain the battery. |
terrier Touring Scooter Rider
Number of posts : 302 Age : 75 Location : Northumberland, UK Points : 3730 Registration date : 2015-08-12
| Subject: Re: Oxford heated grips Fri Apr 08, 2016 2:21 pm | |
| Crustycrutch.....I've fitted the Oxford Premium Grips OF 691. They are fitted directly to the battery so no need to wire through an ignition source making the wiring a bit easier. The built in electronics prevent the battery from becoming discharged.
Den |
| Subject: Re: Oxford heated grips Fri Apr 08, 2016 2:27 pm | |
| Many thanks for the speedy replies gentlemen! |
HORNBLOWER Maxi-Scooter Rider
Number of posts : 171 Age : 69 Location : Birmingham UK Points : 4268 Registration date : 2013-10-08
| Subject: Re: Oxford heated grips Fri Apr 08, 2016 7:21 pm | |
| - terrier wrote:
- Crustycrutch.....I've fitted the Oxford Premium Grips OF 691. They are fitted directly to the battery so no need to wire through an ignition source making the wiring a bit easier. The built in electronics prevent the battery from becoming discharged.
Den I used the same ones they are brilliant. I really like the way they sense if the bike is running or not, so you can wire directly to the battery and when you switch the bike off the grips turn off too! |
| Subject: Re: Oxford heated grips Sat Apr 09, 2016 2:42 am | |
| Thanks Den. No issues with fitting or anything to look out for? |
| Subject: Re: Oxford heated grips Sat Apr 09, 2016 8:41 am | |
| - Crustycrutch wrote:
- Thanks Den. No issues with fitting or anything to look out for?
No, just the usual stuff having to remove tupperware and feed the wiring through. You also have to remove the handlebar shrouding as well and make sure you have enough slack for when turning the bars from side to side. I think I did mine in an afternoon and that wasn't hurrying. Well worth the effort. Den |
| Subject: Re: Oxford heated grips Sat Apr 09, 2016 8:54 am | |
| If you are looking for a set these seem the cheapest available!
http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/101831 |
| Subject: Re: Oxford heated grips Sat Apr 09, 2016 9:03 am | |
| Yes that's a good price, but those are the sports ones. You'll need the touring ones for the silverwing, they have a more cushioned grip http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/101830
Den |
| Subject: Re: Oxford heated grips Sat Apr 09, 2016 9:42 am | |
| I've ordered a set - many thanks for advice |
