| My 1974 Honda CB750 | |
+4roadrunner oldwingguy Cosmic_Jumper Dale N. 8 posters |
| Subject: My 1974 Honda CB750 Thu Apr 21, 2016 5:29 pm | |
| This might be a little off topic for a SWing forum but I thought I'd throw it out anyway.
My CB750 sat over the winter. I just got done rebuilding the four carbs on it today. When I put it all back together and turned on the gas it started leaking between carbs 3 and 4 where the fuel rail tube feeds gas from the tank to both carbs via the gas line. Between carbs 1 and 2 there's no leaking. I can see the gas coming out of the carb 3 and not the hose but not sure if #4 is leaking also. I don't think so but I could be mistaken.
My question is: Will the O-Rings swell back up after gas hits them? I did a google search and some of the other forums suggested that they would in 24 hours or so. Does this sound logical? They've never leaked before and that's why I'm asking.
Thanks for any info you all might be able to throw my way.
Dale |
| Subject: Re: My 1974 Honda CB750 Thu Apr 21, 2016 7:23 pm | |
| Lemme get this straight; it didn't leak until you fixed it? Tim Sorry Dale I just couldn't resist. |
| Subject: Re: My 1974 Honda CB750 Thu Apr 21, 2016 9:31 pm | |
| FWIW, from what I've seen they won't, my tractor had them and didn't, perhaps a gasket may after the fuel wets them but O rings should be petrol proof. |
| Subject: Re: My 1974 Honda CB750 Thu Apr 21, 2016 9:32 pm | |
- Lemme get this straight; it didn't leak until you fixed it?
Sorry Dale I just couldn't resist. That's right! See how good a job I can do!!! In my defense I didn't have gas in it before I "fixed" it. |
| Subject: Re: My 1974 Honda CB750 Thu Apr 21, 2016 9:34 pm | |
| Thanks oldwingguy. That's kind of what I thought too but some other forums said they should reseal themselves. I guess I'll have to take it all apart tomorrow and put new O-Rings in it. THEN I can terrorize the streets... |
| Subject: Re: My 1974 Honda CB750 Fri Apr 22, 2016 8:04 am | |
| Over the years I've found reusing them is 50/50 at best. One wee nick or a slight misplacement on assembly has caused leaks. Good luck with your's. |
Number of posts : 231 Age : 69 Location : Middleburg FL Points : 5345 Registration date : 2010-12-12
| Subject: Re: My 1974 Honda CB750 Fri Apr 22, 2016 10:33 am | |
| I was a Honda parts manager and service writer in the last seventies. Don't even try to reuse the old o-rings, they won't swell back up once they get hard and dry. |
| Subject: Re: My 1974 Honda CB750 Fri Apr 22, 2016 9:50 pm | |
| Thanks roadrunner. That's kind of what I thought too. No sense taking chances. New is better than old crap. |
Greysilver Silver Wing Rider
Number of posts : 493 Age : 78 Location : Arizona Points : 4413 Registration date : 2014-04-08
| Subject: Re: My 1974 Honda CB750 Thu May 05, 2016 7:53 pm | |
| Hi Dale, Cosmic, I try to "fix" as few things as possible. Remember the old chevy truck creedo ( ford too) "if it ain't broke, don't fix it". |
| Subject: Re: My 1974 Honda CB750 Fri May 06, 2016 7:47 pm | |
| Not quite true, the old Ford motto was: "Fix Or Repair Daily". |
| Subject: Re: My 1974 Honda CB750 Fri May 06, 2016 8:27 pm | |
| - exavid wrote:
- Not quite true, the old Ford motto was: "Fix Or Repair Daily".
OR " Found On Road Dead" |
| Subject: Re: My 1974 Honda CB750 Fri May 06, 2016 8:45 pm | |
| Yep, that's what happened when you didn't fix or repair daily! |
hankster Maxi-Scooter Rider
Number of posts : 140 Age : 72 Location : Fort Myers FL Points : 3462 Registration date : 2015-11-14
| Subject: Re: My 1974 Honda CB750 Fri May 06, 2016 9:01 pm | |
| Or First On Race Day |
| Subject: Re: My 1974 Honda CB750 Fri May 06, 2016 9:39 pm | |
Or, "Found On Reservation Dump" I did pull the carbs apart and put new O-Rings in. I figured better safe than sorry. |
| Subject: Re: My 1974 Honda CB750 Sat May 07, 2016 8:12 am | |
| FORD no mention of Chevrolet, some people shove em, some people just letem lay or Dodge Ram, Dis Really be A Mess |
| Subject: Re: My 1974 Honda CB750 Sat May 07, 2016 9:46 am | |
| CHEVROLET Can Hear Every Valve Rap On Long Extended Trips Cheap, Hardly Efficient, Virtually Runs On Luck Every Time Cracked Heads, Every Valve Rattles, Oil Leaks Every Time Constantly Having Every Vehicle Recalled Over Lousy Engineering Techniques
GMC Garage Man's Companion Gotta Mechanic Coming? Generally Mediocre Cars Gets Mechanics Crazy Gods Mechanical Curse Got More Crap
MOPAR Many Odd Parts Arranged Randomly Miscellaneous Oddball Parts Assembled Ridiculously Most Often Passed At Races Mostly Old Parts And Rust Move Over People Are Racing My Old Pig Ain't Running My Only Problems Are Repairs |
