hankster Maxi-Scooter Rider
Number of posts : 140 Age : 72 Location : Fort Myers FL Points : 3462 Registration date : 2015-11-14
NWSSC Silver Wing Rider
| Subject: Subject: 6mm Handlebar Cover Screw Tue May 24, 2016 5:09 pm | |
| If you are referring to the two screws on top of the cover they are adequate for mounting. I think you may find these unique. You will also find some information on just a bracket in this forum. Howard |
| Subject: Re: 6mm Handlebar Cover Screw Tue May 24, 2016 5:38 pm | |
| You can use M6 Coupling Nuts as risers and either a longish M6 bolt or M6 all-thread to fabricate a mount. Ace Hardware seems to have a decent selection of metric hardware.
| Subject: Re: 6mm Handlebar Cover Screw Tue May 24, 2016 8:53 pm | |
| Thanks for the info. I did see the info on the bracket but the RAM mount is all I should need, will just have to put a small spacer under it to raise it above the plastic. I have a marine supply store locally so was planning on stopping in there to get some stainless bolts. |
