| rear wheel removal | |
+3Old Limey ericclapham steve_h80 7 posters |
steve_h80 Silver Wing Guru
| Subject: rear wheel removal Thu Jun 09, 2016 3:44 pm | |
| Well thanks to hints, tip and links here I've got the rear wheel out, surprisingly easy really. Jeez the tyre looks square though, almost darkside lol. It explains why it was dancing over white lines I suppose. The next stage will be putting it all back together. Any ideas on torque settings? I've done the "tighter, tighter, bugger" bit and prefer some precision now :-) |
Number of posts : 106 Age : 81 Location : Adelaide,Sth.Australia Points : 4080 Registration date : 2014-01-30
| Subject: Re: rear wheel removal Thu Jun 09, 2016 6:50 pm | |
| Rear axle nut: 102lb/ft. Shock upper: 16ib/ft. Lower: 29ib/ft RH swing-arm Torx: 25ib/ft. Rear brake &park brake calipers: 22ib/ft These are from the Service manual. |
| Subject: Re: rear wheel removal Fri Jun 10, 2016 1:27 am | |
Old Limey Silver Wing Expert
| Subject: Re: rear wheel removal Fri Jun 10, 2016 4:05 am | |
| When tightening the rear wheel nut, use the handbrake, if correctly adjusted wheel will not move. |
| Subject: Re: rear wheel removal Mon Jun 13, 2016 12:34 pm | |
| New tyre fitted and it's reassembled nicely. It's not such a huge job after all, just a matter of the a few little jobs in the right sequence. I've had more bother with some regular bikes, the triumph sprint 955 springs to mind :-) |
Bob in WI Scooter Rider
Number of posts : 5 Location : Fox Valley Points : 3071 Registration date : 2016-06-30
| Subject: So glad I found this sight! Thu Jun 30, 2016 10:23 pm | |
| After getting my 03 SW last year and enjoying it over a 250cc Helix Clone, the rear tire was in need of a changing. Straight forward and simple thanks to the tips of fellow riders. |
Reg Maxi-Scooter Rider
Number of posts : 101 Age : 71 Location : Brockville Ont. Canada Points : 3137 Registration date : 2016-08-07
| Subject: Re: rear wheel removal Fri Aug 12, 2016 8:03 am | |
| Does one have to remove the exhaust? |
| Subject: Re: rear wheel removal Fri Aug 12, 2016 8:39 am | |
| Yes, the exhaust needs to come off. |
terrier Touring Scooter Rider
Number of posts : 302 Age : 75 Location : Northumberland, UK Points : 3726 Registration date : 2015-08-12
| Subject: Re: rear wheel removal Fri Aug 12, 2016 2:13 pm | |
| Reg.....Have a look at this https://www.youtube.com/watch?v=XsyncE3VXGM it'll give you a better idea what's needed to remove the rear wheel. This is Italian but it's all self explanatory. This guy also has several good videos on working on the Silverwing. Den |
| Subject: Re: rear wheel removal Fri Aug 12, 2016 9:05 pm | |
| Great post Terrier. I wish I saw that before I started mine. Reg, it really is that easy. The only thing that wasn't shown is the use of the parking brake to hold the wheel while you loosen the big axle nut. Helps to use it as well when you torque it during re-installation. |
| Subject: Re: rear wheel removal Sat Aug 13, 2016 4:12 am | |
| I did mention that Bob in WI |
| Subject: Re: rear wheel removal Mon Aug 15, 2016 9:03 am | |
| Sorry Limey. I didn't scroll up through the post to see that you mentioned that. |
Number of posts : 222 Age : 70 Location : uk saddleworth Points : 4030 Registration date : 2014-08-24
| Subject: Re: rear wheel removal Tue Aug 16, 2016 5:54 pm | |
| when you get used to doing them takes approx twenty min to remove wheel
