steve_h80 Silver Wing Guru
| Subject: front lifting point Sun Aug 14, 2016 3:11 pm | |
| I need to get the front wheel off for a tyre change. What's the easiest way of lifting the front off the ground? I've got assorted jacks but no paddock stand, wheres the best jacking point that wont wreck the plastic? |
The Bern Silver Wing Expert
| Subject: Re: front lifting point Sun Aug 14, 2016 3:30 pm | |
| Get it onto the centre stand & look under the belly pan, ahead of the oil filter there is a frame cross tube, easiest is a 'scissor' jack. The tube may not be immediately obvious as it has a piece of rubber (water deflector) fixed to it, it's about 2" behind the end of the plastic
| Subject: Re: front lifting point Sun Aug 14, 2016 3:33 pm | |
| A scissors jack with a flat board, to distribute the weight, under the fuel tank. There's a flat, louvered panel there which serves as the bottom of the scoot. IIRC a good point of balance is directly below the fuel fill.
The weight is supported by the sub frame where that louvered panel mounts.
If you first remove the fender you'll only need to raise the wheel off the floor an inch, but with the fender still mounted you'll need several inches for the wheel to clear.
Last edited by Cosmic_Jumper on Sun Aug 14, 2016 3:39 pm; edited 2 times in total |
| Subject: Re: front lifting point Sun Aug 14, 2016 3:37 pm | |
| Thanks guys. I love this forum :-) |
