Grips,remove throttle sleeve I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Grips,remove throttle sleeve I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Grips,remove throttle sleeve I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Grips,remove throttle sleeve I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Grips,remove throttle sleeve I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Grips,remove throttle sleeve I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Grips,remove throttle sleeve I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Grips,remove throttle sleeve I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Grips,remove throttle sleeve I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Grips,remove throttle sleeve I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
Flyingpanman
HORNBLOWER
NWSSC
Modernman1953
Cookie
Oneeye
13 posters
Oneeye
Number of posts : 3
Registration date : 2016-12-13
Grips,remove throttle sleeve Empty
PostSubject: Grips,remove throttle sleeve   Grips,remove throttle sleeve I_icon_minitimeFri Dec 16, 2016 10:40 pm
What do have to do to change grips with integral throttle sleeve.
Cookie
Cookie
Number of posts : 233
PostSubject: Re: Grips,remove throttle sleeve   Grips,remove throttle sleeve I_icon_minitimeSat Dec 17, 2016 5:38 am
Hi Oneeye, The grip on the throttle side should just be pushed on over the throttle tube so should be easy enough to get off. It may well be held on with glue though so you'll have to poke around to free it off.
Are you fitting heated grips or just fitting some better grips. I find the standard Honda grips too small a diameter - but then I have quite big hands.
Good luck.
Oneeye
Number of posts : 3
PostSubject: Re: Grips,remove throttle sleeve   Grips,remove throttle sleeve I_icon_minitimeSat Dec 17, 2016 8:34 am
Thx,cookie. I want to replace the entire tube and grip,taking the cables loose would be involved I think.
Modernman1953
Number of posts : 379
PostSubject: Re: Grips,remove throttle sleeve   Grips,remove throttle sleeve I_icon_minitimeSun Dec 18, 2016 10:57 pm
Do you have the service manual? Welcome to the forum.
NWSSC
NWSSC
Number of posts : 418
PostSubject: Grips,remove throttle sleeve    Grips,remove throttle sleeve I_icon_minitimeSun Dec 18, 2016 11:39 pm
Hello Oneeye. Not sure why you want to change the throttle tube.You might be asking for a major piece of work if in fact
it is a separate replaceable item. I have replaced several grips with
larger softer ones. Maybe I have been lucky but I use a small nozzle and apply air pressure between the grip and the shaft. They usually
come off in one or two treys. Yes you have to remove the end caps
first. I start the larger diameter grips on the shaft and then use air pressure to expand them and they usually go on in one or two tries.
The larger and softer grips help greatly especially on long rides.
Hope this helps. Howard
Modernman1953
PostSubject: Re: Grips,remove throttle sleeve   Grips,remove throttle sleeve I_icon_minitimeMon Dec 19, 2016 2:55 am
I cut the stock ones with a razor knife and pulled them off and used dish soap to lubricate the new grips and slid them on. 10 minute job.
HORNBLOWER
Number of posts : 171
PostSubject: Re: Grips,remove throttle sleeve   Grips,remove throttle sleeve I_icon_minitimeMon Dec 19, 2016 3:19 am
Just slide a very long small bladed screwdriver between the grip and tube, then spray a little oil into the gap you can then work the screwdriver round the grip.
When you replace the grip make sure the oil is cleaned off and glue the new on with either grip cement or hair spray!
Number of posts : 1036
PostSubject: Re: Grips,remove throttle sleeve   Grips,remove throttle sleeve I_icon_minitimeMon Dec 19, 2016 2:18 pm
Yep, as above. WD40 using the squirty tube gets the oil in there to loosen the exizting glue, then a long thing screwdriver or similar, repeat as necessary. Easy job.
Flyingpanman
Flyingpanman
Number of posts : 237
PostSubject: Re: Grips,remove throttle sleeve   Grips,remove throttle sleeve I_icon_minitimeTue Dec 20, 2016 8:57 pm
I use wallpaper paste to stick them back on. It slips and slides when easing the new grips on and dries out to hold them in place. Only a little is needed.
PostSubject: Re: Grips,remove throttle sleeve   Grips,remove throttle sleeve I_icon_minitimeTue Dec 20, 2016 11:18 pm
I also use compressed air to get grips off. Normally they pop right off without damaging the grip or the sleeve. You can put them back on with a bit of air pressure too, just push them back on while hitting them with air. One popular stick'em to put grips on securely while still allowing them to be easily removed is hair spray. It works fine, holds them snugly but still easy to remove just shoot a bit down the grip and slip it on.
PostSubject: Re: Grips,remove throttle sleeve   Grips,remove throttle sleeve I_icon_minitimeWed Dec 21, 2016 9:25 am
Wallpaper paste?  Sounds like the hook line of an old joke.
Hey, did ya hear the one about the newlyweds who confused wallpaper paste and Vaseline?
What a Face All their wallpaper slid off.
cue the vaudeville rim shot & cymbals
PostSubject: Re: Grips,remove throttle sleeve   Grips,remove throttle sleeve I_icon_minitimeWed Dec 21, 2016 3:54 pm
Flyingpanman
Flyingpanman
PostSubject: Re: Grips,remove throttle sleeve   Grips,remove throttle sleeve I_icon_minitimeWed Dec 21, 2016 5:56 pm
Well, you don't expect me - a single fella with a Kojak type hairstyle - to go into a shop to buy hairspray, do you?
PostSubject: Re: Grips,remove throttle sleeve   Grips,remove throttle sleeve I_icon_minitimeWed Dec 21, 2016 7:13 pm
Well... You could put on some eye liner and wear a trench coat when you take that can of hairspray to the counter. Who'd think any the less of a guy doing that? Rolling Eyes
Err, um... maybe you should go to the next town over to do that though.
PostSubject: Re: Grips,remove throttle sleeve   Grips,remove throttle sleeve I_icon_minitimeThu Dec 22, 2016 12:41 am
I don't remember but be careful cutting off the throttle grip. One scooter I took the grip off of had a plastic throttle sleeve. I don't remember what type scooter it was though. It looked like it wouldn't be too hard to cut that sleeve lengthwise while cutting off the grip. It might have been a Chinese scooter but I don't remember for sure.
Modernman1953
PostSubject: Re: Grips,remove throttle sleeve   Grips,remove throttle sleeve I_icon_minitimeThu Dec 22, 2016 12:56 am
I didn't cut all the way through the grip. I got one end of the grip started after cutting through and a good swift pull and the rest of the grip just pulled apart.
Dish soap dries like glue. We used to put foam grips on bicycles with it and they never came loose even soaking wet. For an experiment, pour a little on the counter and let it dry. Now try to scrap it off. Pour some water on it and it won't absorb the water either. I like the idea of hairspray. I might use that on the ends of the grip even after install.
Winger61
Winger61
Number of posts : 452
PostSubject: Re: Grips,remove throttle sleeve   Grips,remove throttle sleeve I_icon_minitimeThu Dec 22, 2016 6:27 am
Now how do you know he doesn't dress like that anyway??!! Laughing
Number of posts : 4218
PostSubject: Re: Grips,remove throttle sleeve   Grips,remove throttle sleeve I_icon_minitimeThu Dec 22, 2016 8:30 am
It's bad enough buying personal hygiene products in some places;
Woman in white coat. "Can I help you sir?"
Me.                          "I'd like some deodorant"
Woman in white coat. "Ball or aerosol?"
Me. scratch             "Neither, it's for under me arms!"
janitorj1
Number of posts : 104
Registration date : 2014-09-07
PostSubject: Re: Grips,remove throttle sleeve   Grips,remove throttle sleeve I_icon_minitimeThu Dec 22, 2016 11:30 pm
Finally, some humor from Meldrew. Who, was in Orlando this past summer, and who could have let us know, so that those of us closer to that place might have enjoyed meeting this enigmatic member of our forum - had he so chosen - I was only 3 hours away - we could of all learned quite a bit.
Very good joke by the way - I suspect I need to work on my pronunciation of aerosol though.
I have visited your country - but only briefly - a port stop in Portsmouth, I think. It was a long time ago. Wherever your submarine base is. Stayed for a few days - enjoyed it immensely. Stopped in Bremerhaven too - less impressive.
Anyway happy holidays, and all that PC stuff to all you folks here at the forum.
Jon
PostSubject: Re: Grips,remove throttle sleeve   Grips,remove throttle sleeve I_icon_minitimeFri Dec 23, 2016 1:34 am
ARS OL
DonH
Number of posts : 19
Registration date : 2013-10-12
PostSubject: Re: Grips,remove throttle sleeve   Grips,remove throttle sleeve I_icon_minitimeFri Dec 23, 2016 8:35 am
Aha! Now I get it. Laughing
» how to remove a throttle restrictor ?
» Q: Remove flywheel
» Crampbuster
» Remove fairings
» how to remove the glove box
