| Hello from Gig Harbor, WA | |
+6exavid Art Cosmic_Jumper Pastor Ron Easyrider mpdd 10 posters |
mpdd Scooter Rider
Number of posts : 3 Location : Gig Harbor, WA Points : 2797 Registration date : 2017-03-27
| Subject: Hello from Gig Harbor, WA Wed Mar 29, 2017 5:42 am | |
| Hello from Gig Harbor, WA. I've had 46 different motorcycle and 5 Honda Helix over the years. I'm now beginning a brand new adventure on aSilverwing 600.
I just purchased a very low mileage 05' Silverwing, I enjoy the scooter but am very surprised at how much noise the ever juggling body panels make as they scrape and slide against each other. Has any one developed an acceptable method for properly securing the multiple parts. My plan as it has developed is to cut adhesive backed Velcro strips and line all the contact points Incan find. |
Number of posts : 1013 Age : 74 Location : HI Points : 4346 Registration date : 2015-12-19
| Subject: Re: Hello from Gig Harbor, WA Wed Mar 29, 2017 8:51 am | |
| Is that you John? Nah just kidding.
Others have used adhesive foam strips between plastic pieces. And then someone recommended using very small screws to eliminate the noise and vibrations. Your problem is most likely broken plastic tabs that are very easy to break. Use the search function to look for broken tabs. There are several ways to repair the tabs. Your search results should have recommend ways to repair the tabs. Good luck. |
Pastor Ron Silver Wing Rider
Number of posts : 400 Age : 72 Location : Asheville,NC Points : 4767 Registration date : 2013-02-24
| Subject: Re: Hello from Gig Harbor, WA Wed Mar 29, 2017 10:42 am | |
| +1 Easyrider....Welcome aboard mpdd |
| Subject: Re: Hello from Gig Harbor, WA Wed Mar 29, 2017 1:56 pm | |
| [Mod hat ON] I've edited your lengthly subject line and moved your post to Introductions.
Art Super Scooter Rider
Number of posts : 272 Location : Garwood Tx Points : 3532 Registration date : 2015-12-26
| Subject: Re: Hello from Gig Harbor, WA Wed Mar 29, 2017 5:29 pm | |
Number of posts : 2658 Age : 81 Location : Medford, Oregon Points : 8393 Registration date : 2009-07-18
| Subject: Re: Hello from Gig Harbor, WA Thu Mar 30, 2017 12:29 am | |
| Welcome from one who's sailed into your fine harbor many times in the past. They still have good food at the Tides? |
Number of posts : 379 Location : Yuma, AZ Points : 3517 Registration date : 2016-06-02
| Subject: Re: Hello from Gig Harbor, WA Thu Mar 30, 2017 6:47 am | |
| Hello from Lynnwood / Edmonds. |
| Subject: Re: Hello from Gig Harbor, WA Thu Mar 30, 2017 2:41 pm | |
| Welcome from o-HI-o, 05 in house here also. |
Number of posts : 461 Age : 71 Location : Nova Scotia Points : 4589 Registration date : 2013-09-12
| Subject: Re: Hello from Gig Harbor, WA Thu Mar 30, 2017 7:13 pm | |
| Welcome from Nova Scotia. May you have many happy miles on the S'Wing
Foam weather stripping in the cracks that might rattle may work. Mine is an '05 as well. Make sure your tires are not original and are not full of fine "old rubber" cracks. Even with lots of tread left they may be worn out when thinking of shelf life.
If you find a source of touch up paint in that '05 grey titanium that matches ... let us know please.
Mike |
mpdd Scooter Rider
| Subject: Re: Hello from Gig Harbor, WA Sat Apr 01, 2017 7:12 am | |
| my plan now is to remove all the body plastic and paint it red or a dark maroon. |
| Subject: Re: Hello from Gig Harbor, WA Sat Apr 01, 2017 1:21 pm | |
| You might want to have a Plast-aid kit on hand for all the broken tabs and cracks which inevitably appear. https://www.plast-aid.com/collections/all
My 2¢: Red and dark maroon are pretty much standard Honda colors. Why not paint it something more imaginative? Subaru Crosstrek orange; Kermit green; Big Bird yellow...l |
| Subject: Re: Hello from Gig Harbor, WA Sat Apr 01, 2017 10:23 pm | |
| You might consider painting it bright red. After all we all know red is the fastest color. |
| Subject: Re: Hello from Gig Harbor, WA Sun Apr 02, 2017 1:12 pm | |
Mike[/quote]
Try google, Color Rite . com
Titanium Metallic YR 183 N from a touch up pen to a quart.
Riggers Scooter Rider
Number of posts : 60 Location : Hull, England Points : 3471 Registration date : 2015-08-18
| Subject: Re: Hello from Gig Harbor, WA Mon Apr 03, 2017 9:07 am | |
| Best way to silence rattling panels? Ear plugs! |
mpdd Scooter Rider
| Subject: Re: Hello from Gig Harbor, WA Mon Apr 03, 2017 2:25 pm | |
| I used sheets of sound deadener to line the underside of both glove boxes and the fuel door, that worked very well. |
