Brake Fluid Service I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Brake Fluid Service I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Brake Fluid Service I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Brake Fluid Service I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Brake Fluid Service I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Brake Fluid Service I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Brake Fluid Service I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Brake Fluid Service I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Brake Fluid Service I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Brake Fluid Service I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
 Brake Fluid Service
3 posters
Number of posts : 1384
Brake Fluid Service Empty
PostSubject: Brake Fluid Service   Brake Fluid Service I_icon_minitimeThu Apr 06, 2017 5:13 pm
I plan on changing brake fluid soon is there any way to cycle ABS pump?
Valves inside ABS can stick if its never engaged or cycled. I don't have an ABS manual.
Is there an ABS connector that can be JUMPED to test operation?
PostSubject: Re: Brake Fluid Service   Brake Fluid Service I_icon_minitimeThu Apr 06, 2017 9:26 pm
The FSM (pg 16-4 to 16-9) lists the following sequence for brake bleeding; front caliper upper bleed valve; rear caliper bleed valve; front caliper lower bleed valve. There is no mention of cycling the ABS Modulator --presumably because in draining, refilling and bleeding the system all the old brake fluid is replaced. HTH
Number of posts : 2621
PostSubject: Re: Brake Fluid Service   Brake Fluid Service I_icon_minitimeThu Apr 06, 2017 9:42 pm
Haven't done mine yet... 5 years old almost, guess I should consider it. Did the coolant last month myself but the brakes will probably go in to be done...
PostSubject: Re: Brake Fluid Service   Brake Fluid Service I_icon_minitimeSun Apr 09, 2017 7:51 pm
OK thanks for help. Bleed system used a bleed tool only allows fluid out when pumping levers.
Simple design spring loaded with a check ball, fluid can only go out.
Changed coolant also took a few minutes to figure out how to remove right pocket, easy once you know.
Tires, fork springs and DR. P sliders next.Tires worn almost 6k now. PA. roads eat them tar and chip.
Weather nice today Allentown to Sunbury PA. today around 200 miles.
SEQ. river is very high. 2 feet below RT. 11 in some places.
Brake Fluid Service
» Brake fluid
» Brake fluid
» Brake Fluid Flushing
» Brake Fluid Replacement??
» Brake fluid seepage
