Number of posts : 1936 Location : Hocking Hills U.S.A. Points : 5175 Registration date : 2016-01-29
| Subject: Butt rest to backrest Leroy Beal Sat Apr 22, 2017 1:17 pm | |
| I thought I had posted this earlier today but? I can't find it. My problem is when I try to access the LeRoy Beal link for the backrest modification my PC security blocks it as a risky site. So if anyone has a PDF of the butt to backrest modification with instructions I'd appreciate them. TIA oldwingguy |
| Subject: Re: Butt rest to backrest Leroy Beal Sat Apr 22, 2017 1:44 pm | |
| Can't answer that one. I bought one on Ebay, converts bumper to backrest. Gives you much more room and works great. Made out of metal and easy to install. I like mine. $45 plus shipping. There is another one there too buts its wood. bought that one too, broke first time I used it. Not strong . |
DickO Founding Member
Number of posts : 1018 Age : 79 Location : Atchison, KS Points : 6775 Registration date : 2008-12-23
| Subject: Re: Butt rest to backrest Leroy Beal Sat Apr 22, 2017 2:12 pm | |
| Hi folks... If I'm not to badly mistaken, all of the Leroy Beal info is now defunct... when he passed, someone took his info off the net... at least when I try to access my links that I saved, I get a message saying that site is no longer available... it's a real shame since there were many good items there... if I come across one of them, I'll let you know...
cotetoi Silver Wing Expert
Number of posts : 757 Location : New Brunswick, Canada Points : 4877 Registration date : 2013-06-27
| Subject: Re: Butt rest to backrest Leroy Beal Sat Apr 22, 2017 4:28 pm | |
| I made my own. I had a piece of fairly rigid flat piece of steel, 1" wide. Cut two pieces about 6" in length. I took off that metal plate that's attached to the back of the original butt rest. Those hex screws are the right length to go through the 1/4 " flat metal piece. 4 screws hold the butt rest and the bottom part of the 6" metal plate attaches to the two brackets that slide in. Drill the holes carefully lining everything up. 4 Hardware screws attach the bottom of the plates to the brackets.There is just a 2-5 degree angle to give the back rest a slight forward slant to fit yur back. If you are taller than 5'3", then you adjust the length of the steel accordingly. Mine looks great and fits perfectly. Jay. |
| Subject: Re: Butt rest to backrest Leroy Beal Sat Apr 22, 2017 6:03 pm | |
| cotectoi, that sounds like a darn good start for me, thank you. I saw other that used an auto head rest but I wanted something that used the original butt rest. |
vmaximus Maxi-Scooter Rider
Number of posts : 133 Age : 71 Location : Kirkby in ashfield Nottinghamshire England Points : 4950 Registration date : 2011-04-15
| Subject: Re: Butt rest to backrest Leroy Beal Sun Apr 23, 2017 7:37 am | |
| I made the one using a car head restraint and serves its purpose very well, I also made one in the Leroy Beale style and although comfortable for the rider it is uncomfortable for the pillion passenger and I don't think it looks so good. Just my opinion. Pud. |
| Subject: Re: Butt rest to backrest Leroy Beal | |
