Number of posts : 85 Age : 68 Location : Arkansas Points : 2889 Registration date : 2017-04-23
Subject: Starter switch problems Wed May 03, 2017 1:17 pm
Right side switch, includes throttle cable, and starter switch, kill switch.
Issue am having is the starter switch seams to be sticky of wore out.
Symptoms: lights wont come back on after engine starts.
Attempted fix: sprayed inside the housing with dielectric cleaner.
Scenario: The switch is a micro switch cant get inside the micro switch. sprayed with dielectric cleaner as best as could working the switch.
Tech: the Micro switch when engaging the starter will kill the lights so as to send most battery power to starter, and when released the lights come back on,
ONLY problem am having is lights wont come back on, BUT all i have to do is nudge the switch and they work.
anyone else had this issue? i cant seam to fine a replacement part. google just finds used parts anyone know the part number? cant find it in the manual.
Dave Weller Scooter Rider
Number of posts : 85 Location : Chatham Kent UK Points : 4857 Registration date : 2011-11-09
Its a common problem on the CBF600 and CBF1000 models, I got mine working again by pulling the starter switch back and the headlight come back on, then sprayed some ACF50 on the switch. Its been now working fine on my CBF600 When I initially pulled the switch lever back it sounded like a bit of grit was crunched, guess they are a bit exposed. Some say the wire in the switch heats up and the solder melts. Regards Dave PS. The Parking light Micro switch on the handbrake of my Silverwing was fixed using ACF50 which is a good penetrating oil and metal preservative.
RazorbackUofA Scooter Rider
Number of posts : 222 Age : 70 Location : uk saddleworth Points : 4031 Registration date : 2014-08-24
Subject: Re: Starter switch problems Mon May 15, 2017 3:50 am
if its the same switch assy. as used in uk i have one compete from a 2003 scoot that i have broken up for spares
Subject: Re: Starter switch problems Mon May 15, 2017 11:13 am
Do the FJS models have an "extra" switch on the right side? Our FSC models only have the Run/Stop switch as well as the Start switch on the throttle side. However there is a blank spot between those two switches on that housing which might be intended for a 3rd switch.
If the FJS models have a 3rd switch at that location I'd be curious about the availability a throttle side switch housing & switch assy.
The blank place is for a lights switch early ones had off,side,headlamp switch i only found out because i just broke up a 2001 fjs600 and there it is
Dave you can save that starter switch by using the following procedure when starting, Turn on your key switch, Press the start button on the right handlebar, Holding it down. Then press the rear brake handle. The start Electrical arc is moved from the start switch to the brake light switch, An easy thing to replace, However, They very seldom fail and this system has worked for years on dozens of silver wings with millions of starts and very few failures. Disassembling the right handlebar switch to get that headlight working and stop the starter spinning in the dark is no fun. Practice the method I have explained and it will soon become automatic. I realize Honda does not write this procedure up in their publications, Some of us old timers have developed many things that Honda did not write up. Happy Motoring lloyd 193.
Number of posts : 327 Age : 84 Location : Orlando Fl. USA Points : 3312 Registration date : 2017-05-13
See my response to Dave Weller. Happy motoring lloyd 193.
bikehiker Silver Wing Rider
Number of posts : 433 Location : New Cumberland PA Points : 3178 Registration date : 2017-09-07
