| 25g Dr Pulley sliders fitted. | |
+3HORNBLOWER phils a winger steve_h80 7 posters |
steve_h80 Silver Wing Guru
Number of posts : 1037 Location : Teesdale, UK Points : 4230 Registration date : 2016-05-15
| Subject: 25g Dr Pulley sliders fitted. Tue Aug 15, 2017 3:27 pm | |
| Deglazed the clutch and fitted 25g sliders yesterday and put the bike back together today. Just been out for quick blatt and all I can say is ... very nice :-) Its pulling like a 600 should now. No vibration on set off, scampers up hills, seems smoother all round. Money and time well spent. |
Number of posts : 179 Location : Lanark, UK Points : 3946 Registration date : 2014-09-27
| Subject: Re: 25g Dr Pulley sliders fitted. Tue Aug 15, 2017 4:14 pm | |
| where did you get the sliders and how much were they ? mine is due a belt (well due one 5000 miles ago!) and probably rollers or sliders, gonna try going for heavier weight to reduce revs/improve economy. |
| Subject: Re: 25g Dr Pulley sliders fitted. Wed Aug 16, 2017 2:50 am | |
| I bought them direct from the Dr Pulley shop in Germany via their website. I bought the sliders and sliding pieces so that the whole of that end of the drive train is refreshed. |
HORNBLOWER Maxi-Scooter Rider
Number of posts : 171 Age : 69 Location : Birmingham UK Points : 4268 Registration date : 2013-10-08
| Subject: Re: 25g Dr Pulley sliders fitted. Wed Aug 16, 2017 3:52 am | |
| When I fitted mine the sliding pieces needed the slots filing a little wider to be able to slide freely.. Did yours fit or did they need adjusting? |
Number of posts : 237 Age : 74 Location : Morecambe, Lancs., UK. Points : 3366 Registration date : 2016-06-03
| Subject: Re: 25g Dr Pulley sliders fitted. Wed Aug 16, 2017 4:56 am | |
| I also bought my 25g sliders from the Dr. Pulley website. I already had some new Honda sliding pieces and used them.
At the same time, I fitted a Gates drivebelt (around £85 off ebay?) which I would recommend.
I've used Gates belts on various vehicles with no problems at all. The Gates belt looks a little different to the Honda OEM but after a hundred miles of bedding in, I'm loving the smoothness and extra pick-up my set up gives. Motorway rpm's are down a few hundred when cruising.
Because I fitted various items at the same time, I cannot definitively say which performed best, but I'm very happy with the result after a few hundred miles now. |
bill tucker Scooter Rider
Number of posts : 37 Age : 58 Location : kansas Points : 2723 Registration date : 2017-07-23
| Subject: Re: 25g Dr Pulley sliders fitted. Wed Aug 16, 2017 2:21 pm | |
| Flyingpanman what is the gates belt part # I was looking for a gates belt with no luck? thanks Bill |
| Subject: Re: 25g Dr Pulley sliders fitted. Wed Aug 16, 2017 3:28 pm | |
| Sliding pieces were a tight fit onto the back plate but are working fine. |
| Subject: Re: 25g Dr Pulley sliders fitted. Wed Aug 16, 2017 5:07 pm | |
| - bill tucker wrote:
- Flyingpanman what is the gates belt part # I was looking for a gates belt with no luck? thanks Bill
Bill, I don't think that the Gates belt is available in North America. If it is I sure would appreciate someone sharing the source info. Meanwhile I've found that the best price for an OEM Honda belt is from Partzilla. I'd be uneasy using anything less than a Honda belt given the high speed, long distance riding I favor. Tim |
| Subject: Re: 25g Dr Pulley sliders fitted. Wed Aug 16, 2017 6:57 pm | |
| I put a Erlandson Kevlar belt made in USA, on about 1200 miles ago it seems to be holding up I was wonting to get a extra belt to have on hand , probably do a Honda belt next time its about $30 more but that's not to bad. thanks for your help. |
Ewightman Scooter Rider
Number of posts : 2 Location : New Woodstock, NY Points : 2654 Registration date : 2017-08-20
| Subject: Re: 25g Dr Pulley sliders fitted. Sun Aug 20, 2017 8:41 am | |
| Steve, can you tell me the part #s or sizes for the sliders and sliding pieces, there are many choices on the website. |
| Subject: Re: 25g Dr Pulley sliders fitted. Sun Aug 20, 2017 11:27 am | |
| - Ewightman wrote:
- Steve, can you tell me the part #s or sizes for the sliders and sliding pieces, there are many choices on the website.
Here is a link to Buggy Parts North West's web page for Dr Pulley Sliding weights. https://www.buggypartsnw.com/index.php/dr-pulley-products/dr-pulley-slider-weights/400cc-and-higher/dr-pulley-slider-weight-28x20-for-600cc.html They are available from 28gm down to 21gm. 24gm Sliders will give you pretty damn impressive accelleration. Tim |
| Subject: Re: 25g Dr Pulley sliders fitted. Sun Aug 20, 2017 1:18 pm | |
| did the 24g sliders for 2 days did not like the power of the bike , fills a lot better with the 31g and 21g mix so put back the 21g and 31g and I think for me this is the best fill on this bike. I did have one concern , when I put my aluminum or pot metal cover back on it was hard going on this time ? nothing in the way but felt like something was out of alignment ? has anyone felt this putting cover back on. thanks Bill |
| Subject: Re: 25g Dr Pulley sliders fitted. Sun Aug 20, 2017 3:48 pm | |
- <>I did have one concern , when I put my aluminum or pot metal cover back on it was hard going on this time ? nothing in the way but felt like something was out of alignment ? has anyone felt this putting cover back on. thanks Bill
Could possibly the Driven Pulley trying to fit into the belt case bearing. The O-rings on that outer section do need a thin wipe of grease. You'll know more the next time to try to remove the belt case. If one of those thin O-rings is pinched then the base is going to be difficult to seperate. So maybe you might want to have those O-rings on hand for the next time.mthey're cheap enough. Tim |
| Subject: Re: 25g Dr Pulley sliders fitted. Sun Aug 20, 2017 3:51 pm | |
| thanks Tim , I did notice that there are only 2 of the o rings and 3 slots , are there suppose to be 3 ? and do you have any idea where I can pic some up. thanks Bill |
| Subject: Re: 25g Dr Pulley sliders fitted. Sun Aug 20, 2017 5:58 pm | |
| Only two O-rings required. Partzilla.com is a reliable source for discount OEM Honda parts. But unless you are also ordering other items (brake pads, belt, etc) then the shipping charges might be discouraging. If all you need are those two O-rings than you might order them from your local Honda dealer. Local?...Kansas? Yeah, I get it.
| Subject: Re: 25g Dr Pulley sliders fitted. Sun Aug 20, 2017 6:58 pm | |
| thanks Tim , the closest that might have it is 50 miles from me , not to bad. and what are they actually called, so I know what to ask for. thanks aging. Bill |
| Subject: Re: 25g Dr Pulley sliders fitted. Sun Aug 20, 2017 9:22 pm | |
| 91353-MCT-003, O-Ring (36.5 x 1.0). You'll need two. Partzilla's price is ~$1.62 ea. YMMV |
| Subject: clutch pads. Mon Aug 21, 2017 12:01 pm | |
| thanks for all the help Tim , I bit the bullet and paid for there shipping so basically paid double . its all good. p.s are they really charging $54 per clutch pad? not for all. it says there prices are for 1 part? the O-rings are sold separately. have you purchased clutch pads from them. just checking. Bill |
| Subject: Re: 25g Dr Pulley sliders fitted. Mon Aug 21, 2017 12:32 pm | |
- thanks for all the help Tim , I bit the bullet and paid for there shipping so basically paid double . its all good. p.s are they really charging $54 per clutch pad? not for all. it says there prices are for 1 part? the O-rings are sold separately. have you purchased clutch pads from them. just checking. Bill
If you are referring to item #6 in this illustration: http://www.partzilla.com/parts/search/Honda/Scooter/2009/FSC600D+AC/DRIVEN+FACE/parts.html, that would be for 1 each, set of 5 clutch weights (pads). |
| Subject: Re: 25g Dr Pulley sliders fitted. Mon Aug 21, 2017 7:15 pm | |
| hey Tim just wondering did your 03 wing really have 97,200 miles. that's great. |
| Subject: Re: 25g Dr Pulley sliders fitted. Mon Aug 21, 2017 7:49 pm | |
- hey Tim just wondering did your 03 wing really have 97,200 miles. that's great.
Yes, probably more than those 97,200 miles given that I ran a Darkside Sumitomo tire for 40,000 of those miles --and there was a 5-6% odometer error with that larger tire. I really wanted to top 100,000 miles but fate, in the form of an oil slick on a turn, intervened. The up side was that I 'won' the opportunity to up grade to a 2009 gratis of the offending oil slicker's insurance company. |
| Subject: Re: 25g Dr Pulley sliders fitted. Mon Aug 21, 2017 7:56 pm | |
| so it wasn't that the bike gave up it was in a wreck to the fault of oil in the road. |
