» Rear wheel valve stem
K & N Oil Filter Failure I_icon_minitimeby MikeO Today at 6:19 pm
K & N Oil Filter Failure I_icon_minitimeby COMick Today at 6:13 pm
K & N Oil Filter Failure I_icon_minitimeby xwelder Today at 12:31 pm
K & N Oil Filter Failure I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
K & N Oil Filter Failure I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
K & N Oil Filter Failure I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
K & N Oil Filter Failure I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
K & N Oil Filter Failure I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
K & N Oil Filter Failure I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
K & N Oil Filter Failure I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
silverwing2008
Number of posts : 13
Registration date : 2017-09-08
K & N Oil Filter Failure Empty
PostSubject: K & N Oil Filter Failure   K & N Oil Filter Failure I_icon_minitimeTue Sep 26, 2017 5:52 pm
Has anyone had this happen to them.
After enjoyed a nice Saturday afternoon ride I parked and stretched my legs for about 15 minuets. Started bike up then rolled backwards.putting the front wheel right thru a nice pool of oil. Turned motor off put bike on center stand and look underneath. I found the oil filter (K & N) with the nut on the end had failed where the nut attached to the filter housing. Was due an (8,000 mile) oil change in another 50 miles or so all was good there.
Fortune was smiling that day because there was an Auto zone very near by.
Number of posts : 2624
PostSubject: Re: K & N Oil Filter Failure   K & N Oil Filter Failure I_icon_minitimeWed Sep 27, 2017 8:22 am
Thankfully this could have been MUCH worse! I personally have never used a K&N oil filter; a bit spendy for my taste.
Number of posts : 1935
PostSubject: Re: K & N Oil Filter Failure   K & N Oil Filter Failure I_icon_minitimeWed Sep 27, 2017 12:36 pm
So what area failed? case cracked, gasket failed, nut weld failed? Very few filters fail in this manner.
silverwing2008
PostSubject: Re: K & N Oil Filter Failure   K & N Oil Filter Failure I_icon_minitimeWed Sep 27, 2017 8:52 pm
The filter was installed before i purchased the scoot.
The filter has a nut style head on the end, it failed where the nut was made up to the housing.
cliffyk
cliffyk
Number of posts : 182
PostSubject: Re: K & N Oil Filter Failure   K & N Oil Filter Failure I_icon_minitimeWed Sep 27, 2017 11:58 pm
K&N has a much higher opinion of their products than I have ever had--here's a rant I made 13 years ago re: their air filters--nothing has changed since then...
PostSubject: Re: K & N Oil Filter Failure   K & N Oil Filter Failure I_icon_minitimeThu Sep 28, 2017 8:15 am
Impressive rant, Cliff. Thank you for not opening that can of worms here.
Dare I ask whether you may have also editorialized on oil filters?
cliffyk
cliffyk
PostSubject: Re: K & N Oil Filter Failure   K & N Oil Filter Failure I_icon_minitimeThu Sep 28, 2017 4:03 pm
In 2002/03 I dissected a number of oil filters for the 1st generation Miatas after having a very poor experience with Bosch and Fram filters--here's a link to that report.
With respect to K&N's oil filters most detailed analyses I have read have found them to be average or arguably a bit better than Purolator--generally my "go-to" filter, though I do use Motorcraft filters from Walmart on both of our Toyotas, my wife's '03 V6 Highlander and my '09 V6 Tacoma.
I use a Purolator L14612 filter on the S'Wing, it has the same 20 μm filtering and 14 psi bypass pressure as the Honda 15410-MFJ-D01. It does have a bit more filter area as it is 11 mm taller than the OEM filter...
» Brake Failure????
» Battery Failure
» Battery Failure
» Sudden electrical failure
» Tire failure
