| Center stand | |
+11Meldrew steve_h80 SteveSilverWing janitorj1 cotetoi The Bern Easyrider Cosmic_Jumper Dale N. Jolly Bodger lewjayjr 15 posters |
lewjayjr Scooter Rider
Number of posts : 35 Location : Warm Springs, Ga. Points : 2621 Registration date : 2017-11-02
| Subject: Center stand Wed Dec 20, 2017 8:42 pm | |
| My previous bike was a 94 Honda Pacific Coast and I could get it up on the center stand fairly easy. Have tried to get the Swing up and can't quite get it up. I have the trunk on mine but when I'm trying to hold the stand down with one foot, balance on the other and pull up on the side grips, I can't quite get up up and back. Any hints on doing this. I'm leary of getting over balanced and dropping the bike. Thanks for any help and Merry Christmas! |
Jolly Bodger Maxi-Scooter Rider
Number of posts : 105 Age : 71 Location : Lancashire, UK. Points : 3106 Registration date : 2016-10-05
| Subject: Re: Center stand Wed Dec 20, 2017 10:41 pm | |
| My way (I'm only 5' 3") - Left hand on handlebar right hand on passenger grip, right foot on centre stand. Push centre stand down making sure both centre stand legs are touching the ground, move left hand to passenger grip while keeping the majority of your weight on your right foot. Now pull up with both hands and put your full weight on the right foot and that should be enough to lift it onto the stand.
The only bit you need to be careful with is when you move your left hand to the passenger grip but provided you keep enough weight on your right foot it wont over balance.
Hope that helps.
JB |
| Subject: Re: Center stand Wed Dec 20, 2017 10:46 pm | |
| I do the same but keep my hand on the handlebar. I don't trust myself enough to let go and grab the passenger grip. I push down hard on the passenger grip and sort of bounce it up. Sometimes it takes one or two tries but I do get it up. |
| Subject: Re: Center stand Wed Dec 20, 2017 11:39 pm | |
| Some Silverwings seem noticeably more difficult to put up on the centerstand. My '03 was easy, my '09 is a bear --and I am no lightweight. There doesn't seem to be any physical reason why one would be easy while another is difficult. There is no change in the frame or centerstand.
The only way I'm able to get my Silverwing up on the stand is to "rock" it back a couple of times once both centerstand legs are contacting the ground. The momentum seems to do the trick for me. YMMV
| Subject: Re: Center stand Thu Dec 21, 2017 2:19 am | |
| I am 5ft 6in and 140lbs, yet I have no problems lifting it on the center stand. I first put the bike on the side stand, straighten the handlebars with my left hand. Balance the bike while stepping on the arm of the center stand. Find the balance point where both legs of the center stand are touching the ground. Now holding the passenger bar, push down on the arm of the center stand. Do not try to lift the bike. Use the passenger bar to apply pressure to the arm of the center stand. The bike will slide backwards about 8 inches and settle on the center stand. I have lifted 2002, 2004, 2009, and 2013 Swings with no problems. Good luck!
The Bern Silver Wing Expert
| Subject: Re: Center stand Thu Dec 21, 2017 4:38 am | |
| Mine became a LOT easier to raise after taking the stand off, cleaning the surface rust of the pivot points & greasing them. |
cotetoi Silver Wing Expert
| Subject: Re: Center stand Thu Dec 21, 2017 11:02 am | |
| Until I learned the proper technique I felt like I was wrestling a bear, and losing every time. I am 5'3" and 155 lbs, and I thought this task was beyond me. There is one thing I learned: do not attempt to lift the bike in your slippers or flip flops. Your riding boots will do, sneakers are iffy. If you want more secure purchase on the foot hold, get a 2" square of 1/4" steel welded on. Your right foot will thank you. Jay. |
| Subject: Re: Center stand Thu Dec 21, 2017 11:29 am | |
| Thanks all for the hints. I'll just have to try again.
janitorj1 Maxi-Scooter Rider
Number of posts : 104 Age : 71 Location : Folkston, GA Points : 3855 Registration date : 2014-09-07
| Subject: Re: Center stand Thu Dec 21, 2017 11:38 am | |
| Love the 2" square of 1/4 steel welded on. I'm off to the shop.
Jon |
SteveSilverWing Maxi-Scooter Rider
Number of posts : 133 Age : 69 Location : Los Angeles, California Points : 3671 Registration date : 2015-04-17
| Subject: Re: Center stand Thu Dec 21, 2017 1:58 pm | |
| Hi lewjayjr Me method is very similar to Easyrider's. Here's how I do it: When not riding and parked, I usually leave my Swing on the side stand. 1) When I'm ready to leave and want to warm the engine, I'll put the key in the ignition and turn clockwise one click to release the front fork lock. 2) Then, while the side stand is still down (just in case), I'll straighten the steering with both handlebars. 3) From there, I'll let go of the right handlebar and and grab the left passenger grip all the while balancing the Swing. 4) I'll then use my right foot to lower the center stand making sure that both legs touch the ground still keeping my right foot in place. 5) Then, making sure I'm NOT holding the left handlebar brake, I'll pull back, and voila, it's on the center stand. Early on, I occasionally made the mistake of slightly holding the left handlebar brake (rear) which makes putting my Swing on the center stand next to impossible. Hope that helps. Merry Christmas! Steve PS I had to go out there and perform this center stand task to get all the steps right since it is now automatic muscle memory that takes control. |
steve_h80 Silver Wing Guru
| Subject: Re: Center stand Thu Dec 21, 2017 3:49 pm | |
| As above, and once both sides of the stand are on the ground I transfer all my weight onto the stand and up she comes, sometimes with a gentle right hand tug on the pillion seat.
Errrr, have I just said to get it up give it a gentle right hand tug??? Am I about to get banned :-)
| Subject: Re: Center stand Thu Dec 21, 2017 6:47 pm | |
| Steve h80, the ban is not applied for technical information. Getting it up is definitely technical. As for getting off, I mean getting the SWing off the centerstand, leave rear the brake lever alone until that split second when the bike has totally rolled off the stand. If you apply the brake too soon, it engages the front brake which prevents the front wheel from rolling and you have a bike that's hung up. You'll have to time it just right and DON'T give the SWing any room to roll or else..... Jay. |
| Subject: Re: Center stand Fri Dec 22, 2017 4:56 am | |
| The topic of hauling a Silver Wing onto it's centre/center stand has been discussed many times before.
In fact there's a list of previous topics going way back to 2009. A quick Search for topics with the word 'stand' and quite a long list appears. It covers both the centre and side stand, that old chestnut about the pros and cons of disabling the side stand cut out switch, and other stand related matters.
| Subject: Re: Center stand Fri Dec 22, 2017 9:04 am | |
| Thank you for that outstanding information, Uncle Meldrew |
| Subject: Re: Center stand Fri Dec 22, 2017 9:14 am | |
| I've NEVER had any trouble putting my SWing on the side stand...
Sorry, I couldn't help myself. |
| Subject: Re: Center stand Fri Dec 22, 2017 11:09 am | |
- Thank you for that outstanding information, Uncle Meldrew
That's OK, I don't have a problem with my Silver Wing even with a fully loaded top box, tunnel bag and soft luggage. Mind you I did have two years of lifting a big lardass 650 Burgman on and off it's centre stand. |
ItBeMe Maxi-Scooter Rider
Number of posts : 169 Age : 77 Location : Carrollton, GA Points : 2820 Registration date : 2017-09-29
| Subject: Re: Center stand Fri Dec 22, 2017 5:46 pm | |
| I have no problem, I just get off. The rear wheels are my stand. |
| Subject: Re: Center stand Fri Dec 22, 2017 10:31 pm | |
| - ItBeMe wrote:
- I have no problem, I just get off. The rear wheels are my stand.
Do you have a trike? What kit do you have on it? I'm still waiting to get mine back from the shop with a Motor Trike Kit on it. How do you like it compared to two wheels? |
| Subject: Re: Center stand Sat Dec 23, 2017 1:48 am | |
| I've had a few bikes including a Goldwing that were difficult to get up on the centerstand. A bit of cleaning up the pivots on the stand and giving them a good shot of lubricant reduces the effort signifcantly. My GT won't allow one to keep the sidestand down while going up or down from the centerstand. When the sidestand is down it puts on the parking brake. Handy to prevent a bike from rolling forward off the stand but not a big help when using the centerstand. My Silver Wings were also easier to get up on the centerstand, they are a good bit lighter than the GT. |
| Subject: Re: Center stand Sat Dec 23, 2017 6:43 am | |
Yes I have a trike and love it. Do to health it was trike or no ride. At this age a trike is the only way to go. I would post a picture but I don't have a Harvard degree. But there are pictures on this site some where. |
2wheelgal Scooter Rider
Number of posts : 74 Age : 79 Location : Southeast full time 12/25/17 :) Points : 3107 Registration date : 2016-08-20
| Subject: Re: Center stand Sat Dec 23, 2017 6:01 pm | |
| Subject: Re: Center stand Sat Dec 23, 2017 7:34 pm | |
| Very impressive conversion, 2WheelGal! Great color, too! Thanks for sharing it.
Steve |
| Subject: Re: Center stand Sun Dec 24, 2017 8:54 am | |
| I can't wait to get my SWing Trike conversion back from the shop so I can at least look at it and sit on it and go Vroom Vroom and wait for warm weather.
Very nice looking SWing 2WheelGal! Thanks for the photo. |
Old Limey Silver Wing Expert
| Subject: Re: Center stand Mon Dec 25, 2017 10:42 am | |
| ItBeMe, at 73 I beg to differ "at this age trike is the only way to go". I was out yesterday as weather was not too bad, just seventy odd miles but, a bit of rain never bothered me. I was the only one on two wheels apart from two other bikes I saw. |
| Subject: Re: Center stand Mon Dec 25, 2017 1:20 pm | |
I would post a picture but I don't have a Harvard degree. But there are pictures on this site some where. You don't really need a Harvard degree. A Yale degree will work just fine... Sorry, I couldn't help it. |
| Center stand | |
