| Is it me or my side stand and center stand making marks or d | |
+5dickie MikeO billc. Cosmic_Jumper tankyuong 9 posters |
tankyuong Silver Wing Rider
| Subject: Side Stand & Center Stand Make Marks on Concrete of Garage Floor Sat Apr 10, 2010 9:57 pm | |
| Is there any way to prevent this? |
| Subject: Re: Is it me or my side stand and center stand making marks or d Sat Apr 10, 2010 10:16 pm | |
| Now that you've brought up this topic, I've got the same 'problem'. Two definite gouges in the cement right at the center stand position. Occasionally I'll pivot the scoot, a few inches, on the center stand. But not frequently enough to be the sole cause of as much damage as is present though. You could always park your scoot in a neighbors garage. That'll stop the problem from getting any worse. Tim |
billc. Maxi-Scooter Rider
Number of posts : 189 Age : 76 Location : Atlanta, Ga. Points : 5609 Registration date : 2010-02-19
| Subject: Re: Is it me or my side stand and center stand making marks or d Sat Apr 10, 2010 10:26 pm | |
| I use a narrow "runner" carpet rug with a rubber back to park my bike on the centerstand on in my garage and it works great. You can get these at most Walmarts or similar stores. billc. |
| Subject: Re: Is it me or my side stand and center stand making marks or d Sun Apr 11, 2010 5:18 am | |
| "I use a narrow "runner" carpet rug with a rubber back". Same here although they're sold as door-mats. We have one for each bike. Apart from protecting the (tiled) floor they make sure the bikes are parked in the same, convenient place every time. |
dickie Super Scooter Rider
Number of posts : 240 Age : 79 Location : Virginia Points : 6015 Registration date : 2008-12-24
| Subject: Re: Is it me or my side stand and center stand making marks or d Sun Apr 11, 2010 2:33 pm | |
| billc and MikeO....Great idea on the door mat carpet. My workshop has wooden floors so does get chipped up a bit from center stands. I was considering replacing a section with diamond plate aluminum for the stands but will give the carpet a go before that route...Dick |
| Subject: Re: Is it me or my side stand and center stand making marks or d Sun Apr 11, 2010 7:33 pm | |
| The diamond plate would probably scratch, and the carpet will grip the centerstand better as it "gives" slightly when the stand contacts its. Also won't slip on the rubber backed carpet strip...billc. |
| Subject: Re: Is it me or my side stand and center stand making marks or d Mon Apr 12, 2010 7:49 pm | |
| Is it possible to get some of the "rubber insulation" that comes in liquid form in a can? I have used this before with tools. You just dip the handles, of the tools, in the can and when you remove it the "liquid rubber" will harden and give insulation for electrical work. You may want to try this by dipping the stand in the can, or some other container a few times. Just let it dry really good in between coats.
I'm not sure if this will work but I don't see why it wouldn't. Although if you use your center stand a lot you may have to do this a few times a year. If anyone trys this please keep us informed, or if you try another method. I don't really see marks on my concrete floor but I don't really use my center stand much in the garage. http://www.caswellplating.com/aids/plastidip.html |
| Subject: Re: Is it me or my side stand and center stand making marks or d Tue Apr 13, 2010 9:21 am | |
| How about the truck liner spray? |
joncallihan Silver Wing Guru
Number of posts : 1025 Age : 86 Location : Lafayette, Colorado, USA Points : 6927 Registration date : 2009-02-16
| Subject: Re: Is it me or my side stand and center stand making marks or d Tue Apr 13, 2010 9:38 am | |
| - tankyuong wrote:
- Is there any way to prevent this?
Do what I do -- have a 40 year old garage with the original concrete floor. Concrete continues to harden forever. The older it gets, the harder it gets. Not a mark one, from 2 BMW's and a Silverwing, all three parked on the centerstand exclusively. |
| Subject: Re: Is it me or my side stand and center stand making marks or d Tue Apr 13, 2010 1:53 pm | |
| Why not use a pice of 1/2 or 3/4" plywood say 10X24" under the stands. If or when the plywood get's chewed up just replace. |
| Subject: Re: Is it me or my side stand and center stand making marks or d Tue Apr 13, 2010 10:52 pm | |
| justputzn, That would be too easy. I say we go to Jon's house, cut out his concrete floor and divide it up between all of us so our garage floors don't get scraped up. Jon, how many sqft is your floor. |
| Subject: Re: Is it me or my side stand and center stand making marks or d Wed Apr 14, 2010 9:53 am | |
| Jeff, about 500 +/- sq ft. And about 4 to 6 inches thick. It would take a really big masonry saw to do the job, so come on over. I have a project that needs doing that requires just that saw. I have a pedestal made of 2 inch thick flag stones stacked to 26 inches high -- the edges all need to be trimmed about an inch and this big saw would make my life a lot easier (especially if all 500 of you each cut an edge for me). |
| Subject: Re: Is it me or my side stand and center stand making marks or d Thu Apr 15, 2010 1:00 pm | |
| That looks nice Jon, did you do that? Wes |
| Subject: Re: Is it me or my side stand and center stand making marks or d Thu Apr 15, 2010 6:24 pm | |
| Sure did, Wes.
It is the introductory page on my personal gallery web site.
http://www.joncallihan.com |
| Subject: Re: Is it me or my side stand and center stand making marks or d Fri Apr 16, 2010 7:20 am | |
| I use side stand supports. Plastic oval shapes that protect the ground and also help when parking on softer ground such as grass.
http://www.busters-accessories.co.uk/products/list/Bike-Care/Side-Stand-Supports
When placing on centre stand my wife assists in getting them centrally placed. (Her idea I use them to protect our paving.) |
| Subject: Re: Is it me or my side stand and center stand making marks or d Fri Apr 16, 2010 12:41 pm | |
| i'll try to find that on ebay |
WingMan02 Super Scooter Rider
Number of posts : 287 Location : Honolulu Points : 5020 Registration date : 2012-01-19
| Subject: Re: Is it me or my side stand and center stand making marks or d Thu Nov 01, 2012 7:23 pm | |
| I park on concrete tiles laid out on a bed of sand. To prevent the tiles from cracking when using my side stand, I use a piece of plywood about 1/4 inch by 12inX12in. This way I can use my feet to position the board when lowering the bike onto the side stand. The plywood looks as it did when I first started using it 11 months ago. |
