| Confusion about tire pressures | |
+2Meldrew carolina wing rider 6 posters |
carolina wing rider Touring Scooter Rider
Number of posts : 305 Age : 70 Location : Mebane NC Points : 2888 Registration date : 2018-01-22
![Confusion about tire pressures Empty](https://2img.net/i/empty.gif) | Subject: Confusion about tire pressures Mon Feb 05, 2018 3:00 pm | |
| I am currently running Pirelli Diablo tires on my Wing. The owners manual suggests 27 front and 31 rear. I have asked several local riders what they think and I get a different answer every time. I feel like these pressures are a little low. What do you run in your tires? |
![Confusion about tire pressures Empty](https://2img.net/i/empty.gif) | Subject: Re: Confusion about tire pressures Mon Feb 05, 2018 3:17 pm | |
| It doesn't say that in my Owners Manual, or the Tyre Information label on the tunnel. For up to 200lb it's 29 psi Front and 33psi Rear. Maximum Load is 29psi Front and 36 psi Rear. I've no doubt a later poster will rubbish Honda's recommended tyre pressures and suggest higher front and rear pressures. |
![Confusion about tire pressures Empty](https://2img.net/i/empty.gif) | Subject: Re: Confusion about tire pressures Mon Feb 05, 2018 3:23 pm | |
| I tip the scale at about 230 and I carry a fair amount of stuff so I guess I fall into that "MAXIMUM LOAD" situation. |
The Bern Silver Wing Expert
![The Bern](https://2img.net/u/3413/63/00/33/avatars/3758-23.gif)
Number of posts : 897 Location : Telford, UK Points : 4556 Registration date : 2014-11-20
![Confusion about tire pressures Empty](https://2img.net/i/empty.gif) | |
Jolly Bodger Maxi-Scooter Rider
Number of posts : 105 Age : 71 Location : Lancashire, UK. Points : 3036 Registration date : 2016-10-05
![Confusion about tire pressures Empty](https://2img.net/i/empty.gif) | Subject: Re: Confusion about tire pressures Mon Feb 05, 2018 4:18 pm | |
| I have Pirelli Diablos and I run 30psi front and 35psi rear. Works ok for me!
JB |
![Confusion about tire pressures Empty](https://2img.net/i/empty.gif) | Subject: Re: Confusion about tire pressures Mon Feb 05, 2018 4:31 pm | |
| I just had a look at the Pirelli fitment list they say 2 bar in the front & 2.5 in the rear, so they agree with the Honda rating. I suggest go for 29 & 36 as per the plate & 'fine tune' with the shock settings
Also how accurate is your pressure gauge ? it might be worth trying a few & get an average reading ? |
![lloyd193](https://2img.net/u/3413/63/00/33/avatars/4745-73.jpg)
Number of posts : 327 Age : 84 Location : Orlando Fl. USA Points : 3241 Registration date : 2017-05-13
![Confusion about tire pressures Empty](https://2img.net/i/empty.gif) | Subject: Re: Confusion about tire pressures Mon Feb 05, 2018 4:45 pm | |
| - carolina wing rider wrote:
- I am currently running Pirelli Diablo tires on my Wing. The owners manual suggests 27 front and 31 rear. I have asked several local riders what they think and I get a different answer every time. I feel like these pressures are a little low. What do you run in your tires?
30 front, 35 rear has proved to be the best all round tire pressure, These pressures maintain roundness of your tires and prevents scalloping. Of course there are exceptions. When I do the 129 and the 165 in North Carolina-Tennessee, I increase those pressures to 40-40, Smaller tire contact patch with Higher PSI and no Squirming of the tread for absolutely precise handling. I also use a 1/2 light weight helmet when I do these roads with the Crotch Rockets. Enjoy your bike. Lloyd 193. |
![Confusion about tire pressures Empty](https://2img.net/i/empty.gif) | Subject: Tire pressures Fri Feb 09, 2018 7:39 pm | |
| Thank all of you for the informative information about "real life" Silverwing tire pressures. I value all of your opinions. |
![micbusathens](https://2img.net/u/3413/63/00/33/avatars/2052-87.jpg)
Number of posts : 199 Age : 62 Location : Athens Greece Points : 4768 Registration date : 2012-04-05
![Confusion about tire pressures Empty](https://2img.net/i/empty.gif) | Subject: Re: Confusion about tire pressures Tue Feb 13, 2018 5:25 pm | |
