carolina wing rider Touring Scooter Rider
Number of posts : 305 Age : 70 Location : Mebane NC Points : 2964 Registration date : 2018-01-22
| Subject: Rainy weather tip Thu Feb 08, 2018 3:45 am | |
| Most of us know the downfalls of riding in the rain and one of the most dangerous situations I have encountered is water flowing (dripping) down on the inside of the face shield. As dangerous as riding on wet pavement is to start with we ALL need to be able to see clearly. Tape the gap along the top and sides of your shield with 3m painter's tape...blue or green. When no longer needed it removes very easily and leaves no glue residue on the shield or the helmet. You might be thinking to yourself...whaaat? Just try it and you will be a believer....a safer one. Ride Often! |
Number of posts : 4218 Location : York, North Yorkshire, England UK Points : 9447 Registration date : 2010-11-16
| Subject: Re: Rainy weather tip Thu Feb 08, 2018 5:13 am | |
| The Arai SZ open face had that problem in rain, moisture forming on the inside of the visor due to the totally inadequate rain seal with the visor closed. Bad enough in daylight, downright hazardous at night, I've used tape to seal it as a desperate measure, but I shouldn't have needed to on a top of the range helmet from Arai.
When choosing a helmet it's always a good idea to look to see if when the visor closes, it pushes down and back against the rain seals. They do on Schuberth helmets. |
| Subject: Rainy weather tip Thu Feb 08, 2018 5:17 am | |
| That is good advice....thanks. |
steve_h80 Silver Wing Guru
Number of posts : 1037 Location : Teesdale, UK Points : 4232 Registration date : 2016-05-15
| Subject: Re: Rainy weather tip Thu Feb 08, 2018 3:08 pm | |
| One of the greatest risks to riding in the rain is mildew ... |
