| Silverwing Bulletproof engine | |
+11Greysilver Mighty Mouse Mech 1 twa Dale N. Toolman john grinsel oldwingguy GHM-PM carolina wing rider bikehiker lloyd193 15 posters |
Number of posts : 327 Age : 84 Location : Orlando Fl. USA Points : 3316 Registration date : 2017-05-13
| Subject: Silverwing Bulletproof engine Tue Mar 13, 2018 4:14 pm | |
| I am posting concerning the Durability and longevity of the Silverwing Engine, Operating this engine in the seven or seventy five hundred RPM's has no detrimental effect on the engine.
This engine is built to be operated at these and above RPM figures, It is truly a great and durable engine, Some of the Florida riders operating without windshields run these engines way above their red line, Some have claimed that they can hide the speedo needle.
I do not recommend this, But after servicing these bikes and hearing the performance stories for years and paying close attention to the condition, Compression and oil consumption on the hot Roders machines, I am convinced this is one of the most durable engines available in any Scooter.
Change your oil regularly with a quality product, Replace the coolant regularly and do not overheat this engine, It will provide you years of exceptional service at any throttle setting you choose.
I recommend a valve adjust by at least Forty thousand on these high output engines.
Happy high way motoring Lloyd 193. |
bikehiker Silver Wing Rider
Number of posts : 433 Location : New Cumberland PA Points : 3182 Registration date : 2017-09-07
| Subject: Re: Silverwing Bulletproof engine Tue Mar 13, 2018 5:17 pm | |
| I love to hear this stuff! |
carolina wing rider Touring Scooter Rider
Number of posts : 305 Age : 70 Location : Mebane NC Points : 2963 Registration date : 2018-01-22
| Subject: Engine Tue Mar 13, 2018 5:30 pm | |
| Yep..........me too. Somehow confidence is restored. Thank you for years of experience and your willing to share Lloyd. |
| Subject: Re: Silverwing Bulletproof engine Wed Mar 14, 2018 8:05 pm | |
| - bikehiker wrote:
- I love to hear this stuff!
Recently before the weather turned cold here in the south, I made a quick trip up to Memphis Tennessee to get a great barbecue sandwich, Actually I had some other business there, But really enjoyed the barbecue. I decided to take the Silverwing, Because all I needed was a change of clothes, Plenty of room for that. The 04 ABS I took up has no Top trunk, Only Hub lights, Added Post office tail light, Air Horns, Throttle lock and a 214 Givi Screen, Air hawk butt saver. No K&N air filter, I use stock paper only in my machines. It is about eight hundred miles to Memphis from Orlando, Once the engine had warmed up I had reached the Florida Turnpike, Put the tack on 7,500 or about that RPM. Ten and a half hours later I passed the Memphis City Limit sign inbound. Completed my business the next day and turned round headed back to Florida, That took eleven hours because I stopped for Dinner. Checked the oil the next day and added 6 ounces to reach the full mark. Wonderful Scooter, Most owners have no idea the real potential of these bikes because they are reluctant to twist that throttle. About twenty two hours at 7,500 Rpm sometime Higher when I could see far ahead, Bullet proof engine, Great Scooter. It seems almost unfair to call a Silverwing a Scooter. I do not recommend these speeds if you do not run Bridgestone Speed rated tires at 30 front and 35 rear cold, Properly balanced. Happy motoring Lloyd 193. |
| Subject: Re: Silverwing Bulletproof engine Wed Mar 14, 2018 8:56 pm | |
| ...and more confidence in this machine. I have always been conservative about high RPMs because I always felt I would break my motors too quickly, thinking that RPMs are like heartbeats: you only get a finite number before you die. Well, now I think this old fart will wear out before his Silver Wing, so rev 'em up! |
Number of posts : 2622 Age : 72 Location : Bullhead City, AZ Points : 7512 Registration date : 2012-05-17
| Subject: Re: Silverwing Bulletproof engine Thu Mar 15, 2018 8:30 am | |
| Having owned motorcycles since 1969 (yeah I AM old) I can say that the Silver Wing is an awesome ride. Very smooth and powerful, I love taking off on road trips with the little beast (solo, Goldwing better for two). Since 2012 it has been bulletproof, I have installed tires, plugs, oil and coolant etc. maintenance items. The only item fixed under warranty was a leaking hose clamp near radiator. I would trust this thing to go almost anywhere! |
| Subject: Re: Silverwing Bulletproof engine Thu Mar 15, 2018 9:01 am | |
My insurance company feels the same way, they call it what it is a motorcycle. |
| Subject: Re: Silverwing Bulletproof engine Thu Mar 15, 2018 11:38 am | |
| agree on engine. Some years ago, I read article in Japan---running one of their engines hard, does little to shorten its life.
Noodle shops in Japan use step thru C series, Cubs, 50-90CC as delivery machine, they start engine in AM, and let them idle in front of shop all day when not delivering----no problems.....and this is with air cooled 4 strokes. End of life they scrap and buy another, probably cheaper than fixing.
Toolman Scooter Rider
Number of posts : 47 Location : So Cal, USA Points : 3083 Registration date : 2016-08-24
| Subject: Re: Silverwing Bulletproof engine Wed May 23, 2018 11:16 pm | |
| I tend to keep the r's around 6k on the open road. That's fast enough for me and it helps with mpg. but I agree, these motors are built tough. |
| Subject: Re: Silverwing Bulletproof engine Thu May 24, 2018 12:27 am | |
| - bikehiker wrote:
- ...and more confidence in this machine. I have always been conservative about high RPMs because I always felt I would break my motors too quickly, thinking that RPMs are like heartbeats: you only get a finite number before you die. Well, now I think this old fart will wear out before his Silver Wing, so rev 'em up!
I think of my SWing as a Hummingbird. Their hearts beat at over 1,200 beats per minute. So, as long as my little hummingbird's heart keeps beating I won't worry. |
| Subject: Re: Silverwing Bulletproof engine Thu May 24, 2018 7:34 pm | |
| Honda always made great engines. Keep fresh oil in there will last a long time. Found the top speed today with 26g sliders 106 mph. 8500 rpm's GPS - speedo 105. going down hill had no more. That's really nothing 600 cc sport bikes rev to 14-15 thousand. |
Mighty Mouse Maxi-Scooter Rider
Number of posts : 117 Location : South Africa Points : 2905 Registration date : 2017-05-03
| Subject: Re: Silverwing Bulletproof engine Wed Jul 11, 2018 8:06 am | |
| 4 years of riding my 2012 Swing and 70 000 happy smiles, I decided to replace her with.....another 2012 Swing! I found one with less than 5 000 miles on the clock, barely run in! I've made sure to run the old Swing up to max revs only once when I got her (testing her out you understand? LOL). Since then I mostly breeze along at 6000rpm (Dr Pulley sliders) on the open road. Bullet proof she is. I'm delighted to be able to buy another to keep me company for another 5 years. |
Greysilver Silver Wing Rider
Number of posts : 493 Age : 78 Location : Arizona Points : 4418 Registration date : 2014-04-08
| Subject: Re: Silverwing Bulletproof engine Thu Jul 12, 2018 1:28 pm | |
| - lloyd193 wrote:
- I am posting concerning the Durability and longevity of the Silverwing Engine.
Happy high way motoring Lloyd 193. Hi Lloyd, this is way more miles over recommended. It would save a bunch of money though. |
| Subject: hi tool Thu Jul 12, 2018 1:34 pm | |
| - Toolman wrote:
- I tend to keep the r's around 6k on the open road. That's fast enough for me and it helps with mpg. but I agree, these motors are built tough.
Hi Toolman, When I cruise its at 6K ( 75mph ) . This is the freeway speed limit in Arizona. |
| Subject: Re: Silverwing Bulletproof engine Thu Jul 12, 2018 5:19 pm | |
| I've been a Silverwing owner since 2003 and have been a participant in all Silverwing forums since then as well. I perform my own service and maintenance as well as on SW's owned by two friends during this period. In all that time I don't recall anyone ever posting that they have needed valves adjusted on any SW.
That said, if you feel anxious in not having your valve adjustment checked then by all means please follow up with a competent shop.
| Subject: Re: Silverwing Bulletproof engine Thu Jul 12, 2018 6:57 pm | |
| Two new SilverWings, each ridden to almost 50,000 miles each. Never bothered or needed to look at or adjust valves. |
SilverCellist Scooter Rider
Number of posts : 6 Age : 67 Location : Southern Illinois Points : 2311 Registration date : 2018-08-09
| Subject: Re: Silverwing Bulletproof engine Sat Aug 11, 2018 11:34 am | |
| As a new owner Lloyd, that's most reassuring. I'm getting ready for my first initial oil change and filter on my 2004, and have a strict preference for full synthetic (Mobil 1). Any problems with this choice? |
| Subject: Re: Silverwing Bulletproof engine Sat Aug 11, 2018 11:39 am | |
| Why waste money----WalMart house brand 10-40 works fine. Oil changes often are the trick---worked for me the last 500,000 2 wheel miles. |
| Subject: Re: Silverwing Bulletproof engine Mon Aug 13, 2018 11:54 am | |
| - SilverCellist wrote:
- As a new owner Lloyd, that's most reassuring. I'm getting ready for my first initial oil change and filter on my 2004, and have a strict preference for full synthetic (Mobil 1). Any problems with this choice?
I advise you to use what you are happy with and what YOU pay for! Read the posts and pictorials here on oil changes and you should be fine. |
| Subject: Re: Silverwing Bulletproof engine Mon Aug 13, 2018 1:10 pm | |
| Here's my 2¢: If you are of the John Grinsel persuasion and change oil every ~2500 miles then go with Wal-Mart oil & Filter. The frequent supply of fresh oil will keep your engine happy.
On the other hand; if you appreciate Honda-quality engineering as well as the benefits of modern petrochemical engineering you might want to go with a full synthetic, name brand, oil and a quality oil filter. So if full synth oil claims an 8-10,000 mile change interval IMHO the engine will be better off.
Nothing wrong with frequent oil changes, but if you're not going to follow thru with that then go with the good stuff.
| Subject: Re: Silverwing Bulletproof engine Mon Aug 13, 2018 11:07 pm | |
| I use a good quality synthetic or synthetic blend and a high end filter and then run between 5-7K miles prior to changing. If I have a slow mileage year then once a year works for me. My 2012 has 22K on it and runs fantastic so no valve checks for me at least not yet. |
Michel Vachon Maxi-Scooter Rider
Number of posts : 142 Age : 67 Location : Granby, Québec, Canada Points : 2219 Registration date : 2019-03-26
| Subject: Re: Silverwing Bulletproof engine Tue Apr 09, 2019 7:16 pm | |
- I've been a Silverwing owner since 2003 and have been a participant in all Silverwing forums since then as well. I perform my own service and maintenance as well as on SW's owned by two friends during this period. In all that time I don't recall anyone ever posting that they have needed valves adjusted on any SW.
Tim Hello Cosmic Jumper. Can you please contact me true pm... Thank's Michel |
| Subject: Re: Silverwing Bulletproof engine Wed Apr 10, 2019 8:31 am | |
| - Michel Vachon wrote:
- Hello Cosmic Jumper. Can you please contact me true pm... Thank's Michel
Hello Michel. I emailed you at your address of record. Tim |
