Ze'ev Scooter Rider
Number of posts : 24 Location : Israel Points : 3577 Registration date : 2015-03-14
| Subject: can castrol GTX ultraclean 10w-40 a3/b4 be used as final drive oil? Fri May 25, 2018 6:52 am | |
| Hey everybody, I'm planning to change my gear oil. please help me figure out if this oil fits our swing thanks! castrol GTX ultraclean 10w-40 a3/b4 these are the specs: SPECIFICATIONS SAE 10W-40 ACEA A3/B3, A3/B4 API SL/CF MB-Approval 229.1 VW 501 01/ 505 00 Meets Fiat 9.55535-D2/G2 |
| Subject: Re: can castrol GTX ultraclean 10w-40 a3/b4 be used as final drive oil? Fri May 25, 2018 7:04 am | |
| Yes. The Honda Factory Service Manual (FSM) says that you use the same oil as you'd put in your engine. So I'd interpret that to mean, if it's a good quality motor oil then, yes, you can use it in the final drive.
Number of posts : 2622 Age : 72 Location : Bullhead City, AZ Points : 7512 Registration date : 2012-05-17
| Subject: Re: can castrol GTX ultraclean 10w-40 a3/b4 be used as final drive oil? Fri May 25, 2018 8:14 am | |
| There is no wet clutch on these machines so you can use automotive oil if you like. Does not have to be motorcycle specific oil. Crankcase takes appx 2.5 qts and final drive about a pint or less. So buy 3 quarts and do both jobs at the same time. That is what I do. Good luck. |
