| Final Drive Oil | |
+26Meldrew Cosmic_Jumper forkthem2002 GHM-PM rollsroyce250 Dimond pauldeere model28a Silverwing28681 RickV AAAA JeffR_ Ishkatan JamieB arquesf DaveR GaryL MaxB bigbird Slick-Tenn sw2009 honda_silver thomphoto JeffR Cornishman chieninhouston 30 posters |
chieninhouston Scooter Rider
Number of posts : 29 Location : Houston, Texas Points : 5411 Registration date : 2009-09-04
| Subject: Final Drive Oil Sun Sep 06, 2009 12:04 pm | |
| Spent sometimes reading the owner's manual of my 2008 Swing. Not able to find the recommended oil, the changing intervals, and the quantity required for the final drive.
I understand this question may have been asked a lot. But this poor soul really wanted to know. Thank you. |
Cornishman Maxi-Scooter Rider
Number of posts : 181 Age : 70 Location : Wiltshire UK Points : 5728 Registration date : 2009-04-04
| Subject: Re: Final Drive Oil Sun Sep 06, 2009 1:22 pm | |
| Here's a tutorial from the other Silverwing site.
I have no reason to doubt the facts but use it at your own risk!
http://silverwing.org/mwf/attach/85/25485/FinalDriveOilChange.pdf |
Number of posts : 2596 Age : 64 Location : Bay Area, Ca Points : 8474 Registration date : 2008-12-19
| Subject: Re: Final Drive Oil Mon Sep 07, 2009 2:50 am | |
| Hi, I did that Pictorial and it is on this site too. Just make sure you rotate the tire after you drain the oil. I forgot to put that in the Pictorial when I did it. You will be able to get some more oil out of the bike too. |
| Subject: Re: Final Drive Oil Mon Sep 07, 2009 3:18 am | |
| Sorry Jeff I should have checked for availability on here first. |
| Subject: Re: Final Drive Oil Mon Sep 07, 2009 8:58 am | |
| Thank you Jeff,
So either gear oil or engine oil will work? How come I could not find anything in the owner's manual? Strange. |
thomphoto Maxi-Scooter Rider
Number of posts : 188 Age : 87 Location : Owensboro, Kentucky Points : 5689 Registration date : 2009-06-11
| Subject: Re: Final Drive Oil Mon Sep 07, 2009 10:48 am | |
| The reason it's not mentioned in the owners manual is because Honda doesn't want YOU doing it. They want you to take it to the stealership for this simple operation. |
| Subject: Re: Final Drive Oil Mon Sep 07, 2009 11:58 am | |
| - thomphoto wrote:
- The reason it's not mentioned in the owners manual is because Honda doesn't want YOU doing it. They want you to take it to the stealership for this simple operation.
You got the point there. Then they should at least mention that you need to take your ride to stealer at 300 miles, 500 miles, etc. Or the bike is going to blow or something. Without mentioning this anywhere would just lead me to believe that I don't have to do anything to it. If I am not a member of this forum. The final drive oil might just as well be neglected. Wow, I get it. The stealer then can charge an arm and leg to replace the whole unit. Very smart, very smart. |
| Subject: Re: Final Drive Oil Mon Sep 07, 2009 12:16 pm | |
| I only found out about changing the final drive oil after I got on the Silverwing.org forum. Luckily, it was just about 2 years since I got the swing, when it was due to be changed. |
| Subject: Re: Final Drive Oil Mon Sep 07, 2009 12:26 pm | |
| How many miles on the meter? What did you used? Gear oil or motor oil? Got my 2008 last week. 2310 miles on the meter. The previous owner was able to provide receipt for oil and oil filter change. Not the final drive oil change. So I am thinking about changing the final drive oil in the next couple days. Any info will be really appreciated. |
| Subject: Re: Final Drive Oil Mon Sep 07, 2009 1:51 pm | |
| Cornishman, I think I may start a totally seperate topic for "Pictorials" only. That way they will be easier to find for those that want to use them. We have others that have provided pictures and instructions so we could start a library that way. I was looking around for them just to see how easy they are to find here and it isn't as easy as I hoped, when I started the seperate topics when this forum was new. So I think I will do that. |
| Subject: Re: Final Drive Oil Mon Sep 07, 2009 2:03 pm | |
| - JeffR wrote:
- Cornishman,
I think I may start a totally seperate topic for "Pictorials" only. That way they will be easier to find for those that want to use them. We have others that have provided pictures and instructions so we could start a library that way. I was looking around for them just to see how easy they are to find here and it isn't as easy as I hoped, when I started the seperate topics when this forum was new. So I think I will do that. That's a wonderful idea. You are the man Jeff. Thanks. |
| Subject: Re: Final Drive Oil Mon Sep 07, 2009 2:42 pm | |
| Good idea Jeff, I think that's a winner.
Bob |
Number of posts : 2453 Location : Georgetown, Tx Points : 8183 Registration date : 2008-12-23
| Subject: Re: Final Drive Oil Mon Sep 07, 2009 3:07 pm | |
| - JeffR wrote:
- Cornishman,
I think I may start a totally seperate topic for "Pictorials" only. That way they will be easier to find for those that want to use them. We have others that have provided pictures and instructions so we could start a library that way. I was looking around for them just to see how easy they are to find here and it isn't as easy as I hoped, when I started the seperate topics when this forum was new. So I think I will do that. I have written a couple How-To instructions no pictures (I am waiting for JeffR to add pictures ) ... but the instructions (I hope) are very clear. Could we label it a "How-To" or "Self-maintenance instruction" sections ... just in case someone does not have pictorials?? It would help if the topics would be locked to prevent discussion ... a separate thread would allow discussion ... then if additional "key" maintenance points are later found/determined then it could be added to the very minimal thread ... which would be really short to read? |
| Subject: Re: Final Drive Oil Tue Sep 08, 2009 7:20 am | |
| One more question (sorry ). Now I am pretty confidence to do this SIMPLE project. I have the oil, have the long nose oil can. Now, some said that those 2 washers better to be replaced in the process. I would like to do that if I could. Anybody knows the exact size, and kind. I tried to get info from the online OEM parts fiche without success. Can the regular 8MM washer from the Home Depot or Lowe's do the trick? Thanks. |
| Subject: Re: Final Drive Oil Tue Sep 08, 2009 9:03 am | |
| If you're careful in removing the washers, I don't think you need to replace them every time you change the final drive oil. Same with the rubber o ring when you change the engine oil, it's good for several changes before you need to replace it. |
sw2009 Scooter Rider
Number of posts : 9 Points : 5394 Registration date : 2009-08-25
| Subject: Re: Final Drive Oil Tue Sep 15, 2009 12:51 pm | |
| Final Drive Oil Recommended By Honda:
Recently bought a new 2009 Silverwing.
Page 3-16 or the 2002-2009 Service Manual calls for Pro Honda GN$ 4-stroke oil or equivalent
API service classification SG or higher.
JASO T903 Standard: MA
Viscosity 10W-30.
This information is repeated on Page 3-2 of this same manual.
Jim from Stanwood, WA |
| Subject: Re: Final Drive Oil Tue Sep 15, 2009 4:11 pm | |
| - sw2009 wrote:
- Final Drive Oil Recommended By Honda:
Viscosity 10W-30.
Jim from Stanwood, WA Thank you Jim, I am waiting for my service manual. Looks like a nice manual. You have a good day. |
| Subject: Re: Final Drive Oil Wed Sep 23, 2009 10:47 pm | |
| You don't want to use gear oil unless actual hypoid gears are involved, but I have no idea what's inside there.
I'd suggest 10w30 synthetic. |
Slick-Tenn Scooter Rider
Number of posts : 47 Points : 5108 Registration date : 2010-07-19
| Subject: Re: Final Drive Oil Tue Jul 27, 2010 8:40 pm | |
| - chieninhouston wrote:
- Spent sometimes reading the owner's manual of my 2008 Swing. Not able to find the recommended oil, the changing intervals, and the quantity required for the final drive.
I understand this question may have been asked a lot. But this poor soul really wanted to know. Thank you. 7/27/10 Bought an 03 recently and called my local Honda Service Dept. He said they use "Honda Gear Oil" - whatever that is. Smell the stuff that you drain out - gear oil has a distinctive smell. |
Number of posts : 2387 Location : Winnipeg Points : 7718 Registration date : 2010-05-02
| Subject: Re: Final Drive Oil Wed Jul 28, 2010 12:15 am | |
MaxB Touring Scooter Rider
Number of posts : 302 Age : 72 Location : Indiana Points : 5697 Registration date : 2009-10-06
| Subject: Re: Final Drive Oil Wed Jul 28, 2010 8:51 am | |
| - mickey wrote:
- You don't want to use gear oil unless actual hypoid gears are involved, but I have no idea what's inside there.
I'd suggest 10w30 synthetic. The gears in the final drive are strait cut gears. and thus would be in the gear oil category. (from 35 yrs of Industrial maintenance perspective) I use synthetic 75w90 oil in mine. When looking into this swap, I found that the specs (pour viscosity) for gear oils and motor oils are a different chart. but in one article it showed that when comapred side by side that the 75w90 gear oil has slmost the same specs as 10w40 motor oil. So is compatible as far as wear protection. Also gear oil doesn't have an additive (brain freeze) that is detrimental to brass based thrust washers. So it is better for gears. Edit: do a search for "gear oil vs. motoroil" and you can find it for yourself. Hope this helps. MaxB ( who lost a lot of esoteric data when PC died recently) |
| Subject: Re: Final Drive Oil Wed Jul 28, 2010 9:02 am | |
| I have a opinion that Honda did the 10w30 motor oil recommendation, for people that may not have gear oil available. But they do have that little extra motor oil left from changing the engine oil. it only takes like 3-4 oz. to do the tranny. And we all have that much left after an oil change on the engine. What do you think???? MaxB (who is thinking too much) |
GaryL Super Scooter Rider
Number of posts : 237 Age : 71 Location : Casa Grande, Arizona Points : 5319 Registration date : 2010-07-09
| Subject: Re: Final Drive Oil Wed Jul 28, 2010 2:03 pm | |
| Another one of my 'For what it's worth' comments... I had a 1988 Honda Accord with a manual transmission. You were supposed to replace the transmission oil every 30k miles. Guess what the replacement recommendation was? 10W-30 motor oil... the same stuff that went into the crankcase. I put in 10W-30 Synthetic oil (Mobile 1), and it stayed in there for the balance of 200,000 miles. Never had a problem, and that was the smoothest shifting transmission I ever had. I don't think that the service manual recommendation for the final drive oil is an accident. |
DaveR Silver Wing Rider
Number of posts : 440 Age : 87 Location : Scottsbluff, Nebraska U.S.A Points : 6018 Registration date : 2009-02-19
| Subject: Re: Final Drive Oil Mon Jan 03, 2011 6:23 pm | |
| I use Honda 30 oil in my final drive it is a 2005 as recommended in the service book. I have changed mine two times and just turned 16000 miles. To fill mine I use a bottle made of nylon plastic material like you dispense catsup or mustard. It holds a cup and one half when full... Old Dave |
| Subject: Re: Final Drive Oil Tue Jan 04, 2011 3:37 pm | |
| I use Amsoil (synthetic; that's all they make) 10-40 and a pump type oil can. Seems to work alright. |
arquesf Scooter Rider
Number of posts : 5 Points : 4886 Registration date : 2011-01-09
| Subject: Re: Final Drive Oil Wed Jan 12, 2011 10:08 am | |
| First, hi everybody from Spain (EUROPE).I have a SW400 (I think in EEUU SW only 600).AT the Spanish SW400 2006 owner manual (european I think)recommended 10w40 synthetic oil: https://i.servimg.com/u/f37/16/07/39/53/image011.jpg
JamieB Super Scooter Rider
Number of posts : 223 Age : 47 Location : North West UK Points : 5177 Registration date : 2011-02-01
| Subject: Final drive oil Tue Mar 01, 2011 4:07 pm | |
| Hi Everyone,
Been reading the final drive oil recommendation thread with great interest.
I am going to perform this task very soon, can someone tell me please the amount of 10w-30 oil needed?
| Subject: Re: Final Drive Oil Tue Mar 01, 2011 4:08 pm | |
| Just keeping filling it until it starts to seep out of the hole where you fill it with oil. The amount is 10oz but just keep filling it up until it drips out. |
| Subject: Re: Final Drive Oil Tue Mar 01, 2011 4:11 pm | |
Ishkatan Super Scooter Rider
Number of posts : 203 Age : 69 Location : Monrovia, Md Points : 5165 Registration date : 2010-11-16
| Subject: Re: Final Drive Oil Sun May 29, 2011 6:34 pm | |
| I have a few pictures in my motorcycle album showing the Oil holes with the plastic covers off. https://picasaweb.google.com/Safier/Motorcycles#
I had a level check question but it was answered by the link that appeared earlier but I just saw. I'm in cluding it because it is so useful https://i.servimg.com/u/f37/16/07/39/53/image011.jpg
JeffR_ Site Admin
Number of posts : 1103 Age : 64 Location : Bay Area, Ca Points : 8886 Registration date : 2010-05-12
| Subject: Re: Final Drive Oil Sun May 29, 2011 6:37 pm | |
| The final drive holds 10 oz of oil. Just keep filling it until it starts to seep back out and you know you have just enough. |
AAAA Silver Wing Rider
Number of posts : 442 Points : 5461 Registration date : 2010-11-14
| Subject: Re: Final Drive Oil Sun May 29, 2011 8:07 pm | |
| My manual transmission Ford Ranger 5 speed takes, wait for it . . . . . . . . . . . . . automatic transmission fluid. Because its thinner than gear oil, and does the same thing. I made the mistake of putting gear oil in it and it was sluggish, it was taking to much of what little power it had to slog through the molasses of the thick oil. Im guessing that is why Honda wants you to use motor oil, makes sense to me.
I put amsoil 10/40 synth in the gear case, and i will probably never have to mess with it again. |
| Subject: Re: Final Drive Oil Sun Sep 04, 2011 5:11 pm | |
I understand this question may have been asked a lot. But this poor soul really wanted to know. Thank you. Sorry! Honda just won't convince me that 10W30 motor oil will do the job lubricating gears! I use nothing but Amsoil 80W90 synthetic gear oil. Your transmission will thank you! |
| Subject: Re: Final Drive Oil Sun Sep 04, 2011 5:17 pm | |
| Subject: Re: Final Drive Oil Mon Sep 05, 2011 11:16 am | |
| Subject: Re: Final Drive Oil Thu Sep 22, 2011 6:53 pm | |
| Subject: Re: Final Drive Oil Thu Sep 22, 2011 11:03 pm | |
| Never doubt what Honda tells us to do in the owners manual and maintenance manual. They know what they are doing so don't try to second guess them with all of your own ideas. It will only lead to problems and costly ones at that. Old Dave in Western Nebraska |
RickV Maxi-Scooter Rider
Number of posts : 100 Age : 78 Location : MN Points : 5033 Registration date : 2010-11-28
| Subject: Re: Final Drive Oil Sun Nov 06, 2011 1:39 pm | |
| Just a note on my drive oil experience.
My 2002 SW Service Manual recommends the Honda GN-4 10W-40 - pg 3-16 - no surprise there.
My 2002 SW has experienced vibration starting out and the corresponding plastic vibration - new belt and 16K service performed at 12K this Spring and given clean bill of health.
After reading this post of drive oil, took off covers and looked at belt and such - almost no dust inside from this years riding and all looked OK -decided to check the drive oil and it didn't look right to me [changed last year and used Honda GN-4 10W-40 - about 3k miles ago]. Drained the oil and it appeared like it had broken down - following Big Bird I used my Shell Rotella T 15W-40 JASO-MA oil for the refill.
Can't explain it but the vibration has all but disappeared and much much smoother starting out - will monitor next Spring again because riding will end shortly here. I do intend to shorten my drive oil maintenance intervals which is listed as every 2 years.
I am much happier with my SW and been riding it more than my Scarabeo now.
Rick V |
| Subject: Re: Final Drive Oil Sun Nov 06, 2011 1:49 pm | |
| Subject: Re: Final Drive Oil Sun Nov 06, 2011 2:06 pm | |
| Big Bird, I agree totally - changing the drive oil should not have changed anything with the clutch or belt - I did take off the aluminum drive cover to expose the belt and have done so about 4 times before - there is evidence of belt slap on the bottom of that cover and was the first time so don't know if new belt is flexing that much - I was slightly surprised that there was virtually no belt dust inside. Put everything back together as I have in the past. Also, performed oil and filter change - replaced Castrol 10W-40 Synthetic with Valvoline 10W-40 4T Motorcycle oil which has the JASO-MA standard. The Castrol was the previous owners recommendation but always thought there was a little excessive engine noise though no oil usage. Believe the engine has quieted down a bit so happy there and about having better high rpm valve protection.
BTW, still riding here in MN - in 50's yesterday; was out last Saturday with morning temp at 30 but with sunshine. Not ready to put the scoots away just yet.
Rick V
Silverwing28681 Scooter Rider
Number of posts : 94 Location : Taylorsville, NC Points : 4400 Registration date : 2012-08-16
| Subject: Re: Final Drive Oil Sat Aug 18, 2012 1:35 pm | |
| I was out today and went to my local Honda shop. I asked about changing the final drive oil in my Silverwing, They said to use 80w-90 hypoid gear oil. I got a quart it was $12.99. It is Bel-Ray brand, It does not seem to be much thicker then 10-40 or so motor oil.
Any thoughts ? Thanks ! |
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7369 Registration date : 2010-02-03
| Subject: Re: Final Drive Oil Sat Aug 18, 2012 3:49 pm | |
| The Silverwing takes the same oil for the final drive as the engine takes. In fact it will use just about what is left of the third quart after an oil change. |
pauldeere Scooter Rider
Number of posts : 19 Location : SW ohio Points : 3918 Registration date : 2013-09-19
| Subject: Re: Final Drive Oil Mon Sep 23, 2013 7:50 am | |
| After changing the final drive oil and useing 75-90 gear oil I noticed foaming, so I switched back to 10w30 motor oil, absolutely no foam |
Dimond Silver Wing Expert
Number of posts : 540 Age : 79 Location : San Francisco Bay Area Points : 5344 Registration date : 2011-08-07
| Subject: Re: Final Drive Oil Mon Sep 23, 2013 4:53 pm | |
| - pauldeere wrote:
- ... I noticed foaming...
How did you NOTICE foaming? Open the fill port and see foam oozing out? |
| Subject: Re: Final Drive Oil Mon Sep 23, 2013 5:52 pm | |
| Took the side cover off to clean the air intake filter that I had forgot, thought I would recheck the final drive oil that I had changed the day before, taking out the high point fill plug the oil oozed out I immediately noticed that the oil was FOAMY..........The gear oil that I used was 75-90 Rotella non synthetic....... |
rollsroyce250 Scooter Rider
Number of posts : 73 Location : Florida Points : 4423 Registration date : 2012-06-21
| Subject: Re: Final Drive Oil Mon Sep 23, 2013 7:37 pm | |
| - pauldeere wrote:
- taking out the high point fill plug the oil oozed out I immediately noticed that the oil was FOAMY..........The gear oil that I used was 75-90 Rotella non synthetic.......
Because you overfilled the final drive, not because it was gear oil. |
| Subject: Re: Final Drive Oil Tue Sep 24, 2013 4:12 am | |
| Subject: Re: Final Drive Oil Tue Sep 24, 2013 9:26 am | |
| - pauldeere wrote:
- Whatever..........
You're welcome. |
Number of posts : 2566 Age : 71 Location : Bullhead City, AZ Points : 7255 Registration date : 2012-05-17
| Subject: Re: Final Drive Oil Tue Sep 24, 2013 3:23 pm | |
| - rollsroyce250 wrote:
Because you overfilled the final drive, not because it was gear oil. Um, just a question. If you fill the final drive until oil weeps out the filler hole...how do you overfill it? |
| Subject: Re: Final Drive Oil Tue Sep 24, 2013 3:27 pm | |
| - GHM-PM wrote:
Um, just a question. If you fill the final drive until oil weeps out the filler hole...how do you overfill it? That's an easy one. You can add oil into the hole a lot faster than the oil can drain out. How do you fill the final drive? Not by gravity, but by pressure. How does the oil drain out? By gravity. Make sense? |
| Subject: Re: Final Drive Oil | |
| Final Drive Oil | |
