| Non Locking Gas Cap | |
+14cotetoi MikeO Easyrider Mech 1 twa Sidewinder Pilot Scootypuff Snr oldwingguy Meldrew steve_h80 sonuvabug GHM-PM cliffyk Cosmic_Jumper Dale N. 18 posters |
| Subject: Non Locking Gas Cap Sun Jun 03, 2018 5:05 pm | |
| Does anybody know it there's a non locking gas cap for the SWing?
Just curious. |
| Subject: Re: Non Locking Gas Cap Sun Jun 03, 2018 5:46 pm | |
| An Elite or Helix cap fits perfectly.
| Subject: Re: Non Locking Gas Cap Sun Jun 03, 2018 6:24 pm | |
| Thanks Tim! I appreciate it a lot.
I just did a search and found a new one on ebay for $8.95 with free shipping.
Thanks Again. |
cliffyk Maxi-Scooter Rider
Number of posts : 182 Age : 78 Location : Saint Augustine FL Points : 3314 Registration date : 2016-05-15
| Subject: Re: Non Locking Gas Cap Sun Jun 03, 2018 7:15 pm | |
| If you remove the two screws indicated in the photo below the locking tabs can be easily removed--I do not remember the exact procedure however it's pretty obvious once you get "in there"... |
| Subject: Re: Non Locking Gas Cap Sun Jun 03, 2018 9:10 pm | |
| Thanks cliffyk. I'll give that a try too. |
Number of posts : 2622 Age : 72 Location : Bullhead City, AZ Points : 7512 Registration date : 2012-05-17
| Subject: Re: Non Locking Gas Cap Mon Jun 04, 2018 7:10 am | |
| - Dale N. wrote:
- Thanks cliffyk. I'll give that a try too.
The advantage to cliffyk's method is that it will still APPEAR to be a locking cap... |
sonuvabug Silver Wing Expert
Number of posts : 933 Location : Mid-Western Ontario Canada Points : 6199 Registration date : 2010-09-15
| Subject: Re: Non Locking Gas Cap Mon Jun 04, 2018 11:11 am | |
And ... if you save the bits, you can convert it back again in the future. |
| Subject: Re: Non Locking Gas Cap Mon Jun 04, 2018 12:13 pm | |
| I thank you all for the info. I took the locking tab out of the gas cap and it was easier than I thought it would be. I pulled the two screws and took the cap apart and the locking tab more or less just fell out of the cap. I did save the tab for possible future use too. And it only took about a whole 5 minutes to complete. Thanks again everybody! |
steve_h80 Silver Wing Guru
| Subject: Re: Non Locking Gas Cap Mon Jun 04, 2018 3:23 pm | |
| Subject: Re: Non Locking Gas Cap Mon Jun 04, 2018 4:22 pm | |
| Dig around and you'll find another couple of topics about the non locking gas cap. Apart from a few members thinking it's too much effort to spend a few seconds removing the key from the ignition unlocking the cap and a few more locking again after refuelling. There seems to be no creditable reason for doing it, apart from laziness.
Having read through these posts and the other fuel cap topics, all the interest in fitting a replacement non locking cap, or tinkering with the OE one is exclusively American.
In contrast we Brits are much more sensible chaps and like a locking fuel cap.
| Subject: Re: Non Locking Gas Cap Mon Jun 04, 2018 5:32 pm | |
| Well just to answer the question/comments from my perspective.
I've been having trouble getting the key to go in all the way and unlock the cap. I sometimes have to really "play" with it to get it to go in all the way. Luckily it hasn't gotten to the point of locking me out. Yet.
I've sprayed it down a few times with WD-40 but that hasn't helped. I've tried some thin oil with no luck. I don't know, maybe after I get the non-locking cap that I ordered I can put the original in an oil bath and let it sit for a while afterwards to drain off. Time will tell...
I don't leave my SWing in any place unattended for any length of time and it's in my garage when I'm not riding it. Now that I've taken the locking tab out of it it still looks like a locking cap.
So, that's my reason for messing it up and making it a non-locking cap. |
| Subject: Re: Non Locking Gas Cap Mon Jun 04, 2018 6:39 pm | |
| I have severe osteoarthritis, and removing the gas cap is a new experience in pain--even without the key in the way....
| Subject: Re: Non Locking Gas Cap Mon Jun 04, 2018 9:08 pm | |
| I've sprayed it down a few times with WD-40 but that hasn't helped. I've tried some thin oil with no luck. I don't know, maybe after I get the non-locking cap that I ordered I can put the original in an oil bath and let it sit for a while afterwards to drain off. Time will tell... <<<>> JMHO but adding oil = collecting dirt / dust, perhaps a good cleaning with a spray cleaner then after a good drying out a light dry graphite powder or Teflon spray. My ignition lock AND my gas cap both do this from time to time but not every time. |
| Subject: Re: Non Locking Gas Cap Mon Jun 04, 2018 9:58 pm | |
| Thanks oldwingguy, I'll give that a try. |
| Subject: Re: Non Locking Gas Cap Mon Jun 04, 2018 10:15 pm | |
| I use thin smear of PTFE (Teflon) grease--wont't damage the rubber seal either: |
| Subject: Re: Non Locking Gas Cap Mon Jun 04, 2018 10:52 pm | |
| - Meldrew wrote:
- Dig around and you'll find another couple of topics about the non locking gas cap. Apart from a few members thinking it's too much effort to spend a few seconds removing the key from the ignition unlocking the cap and a few more locking again after refuelling. There seems to be no creditable reason for doing it, apart from laziness.
Self-righteous bunch too. BTW, my mum was a "Brit", war bride from Sweffling, Suffolk... |
| Subject: Re: Non Locking Gas Cap Tue Jun 05, 2018 2:23 am | |
| - cliffyk wrote:
- Self-righteous bunch too.
Rather harsh there cliffy, referring there to the rest of my fellow countrymen and Silver Wing enthusiasts as a 'self-righteous bunch' for something I posted. A previous topic on the non locking filling cap was started by someone who thought the simple act of reaching down and unlocking the filler cap was a PITA. Now to me as a sanctimonious old git, it's rather like that other practice carried out by some of disabling an important safety feature like the side stand ignition cut out switch. Simply because they consider using the main stand a PITA too. |
Number of posts : 230 Location : France & UK Points : 3017 Registration date : 2017-04-21
| Subject: Re: Non Locking Gas Cap Tue Jun 05, 2018 7:30 am | |
| OK folks. Rather than use WD40 or other wet products that catch dust and grit (especially with the position of the silverwing cap) which when keys are inserted makes a grinding paste bot dissimilar to the chain use graphite powder. Can't get any then buy a pencil (or pinch one from IKEA in the UK/Europe) and draw the pencil over the key shaft.
It's safe works and doesn't freeze in winter |
| Subject: Re: Non Locking Gas Cap Tue Jun 05, 2018 3:51 pm | |
| I'd love to be a sanctimonious old git... but not sure I can spell it without the help of a spellchecker. :-) |
Number of posts : 200 Location : Ocala, FL Points : 3688 Registration date : 2015-05-21
| Subject: Re: Non Locking Gas Cap Tue Jun 05, 2018 8:31 pm | |
| Actually, I want to take the laziness to it's logical conclusion and replace the locking cap with the type that has a trap door to insert the nozzle, eliminating the need to remove the cap altogether! Does anyone know of an automobile make and model that has a compatible cap? |
| Subject: Re: Non Locking Gas Cap Tue Jun 05, 2018 9:18 pm | |
| Go back about 30 years 1988 Honda Civic should fit. Not sure . Doubt if anyone makes it with a door.
| Subject: Re: Non Locking Gas Cap Wed Jun 06, 2018 1:57 am | |
| I did bypass my side stand switch, but still use my key to unlock the gas cap. I even cable lock my Swing to my garage post through the rear wheel. I have had two vehicles stolen, fishing gear taken from my boat, and attempted break into my storage unit.My home got broken into and items were stolen. Someone once asked why bother. No one wants a Swing. My truck was stolen by theives for a joy ride. They did so much damage that the insurance company totalled it and gave me $12k. I would rather be safe than sorry. |
| Subject: Re: Non Locking Gas Cap Wed Jun 06, 2018 10:53 am | |
| Oy vey! Such malevolence in paradise. |
| Subject: Re: Non Locking Gas Cap Wed Jun 06, 2018 1:57 pm | |
| Apart from the fact that a locking cap deters thieves it also serves to prevent one leaving the cap on the petrol pump by mistake since one has to put it back on the filler to get the key out. |
| Subject: Re: Non Locking Gas Cap Wed Jun 06, 2018 2:54 pm | |
| The only reason I started this thread was to ask about a non-locking gas cap. I didn't think it would turn into what it has. Sorry.
I just didn't want to get locked out of my tank.
I never put the gas cap on the gas/petrol pump. I stick it on the running board and put it back on when filled. |
| Subject: Re: Non Locking Gas Cap Wed Jun 06, 2018 9:42 pm | |
| Nothing to be sorry about. Its a good question and others will learn from it. I'm going to unlock mine soon now that i know how. |
| Subject: Re: Non Locking Gas Cap Thu Jun 07, 2018 1:42 am | |
| Tim, That is the problem here with tourist. They feel that they are in paradise and let their guard down. Oahu has the same problems the big cities have. - MikeO wrote:
- Apart from the fact that a locking cap deters thieves it also serves to prevent one leaving the cap on the petrol pump by mistake since one has to put it back on the filler to get the key out.
MikeO, Not sure if my cap is defective, but I am able to remove my key with the cap off. I fill my gas at home and use my fuel gauge to determine when the level is almost to the bar in the filler neck. I then remove the micro filter and top off the gas. I use a pump that requires two-D size batteries. |
| Subject: Re: Non Locking Gas Cap Thu Jun 07, 2018 4:17 am | |
| Oh yes, I can take the key out if I turn the cap to the 'locked' position, too, but it serves as another aide memoire, more of which I need as time passes! |
cotetoi Silver Wing Expert
Number of posts : 757 Location : New Brunswick, Canada Points : 5064 Registration date : 2013-06-27
| Subject: Re: Non Locking Gas Cap Thu Jun 07, 2018 7:46 am | |
| Everyone figures out what works for them !
Jay. |
| Subject: Re: Non Locking Gas Cap Thu Jun 07, 2018 9:16 am | |
| Doesn't Helix cap work, non-locking |
| Subject: Re: Non Locking Gas Cap Thu Jun 07, 2018 9:33 am | |
| - cotetoi wrote:
- Everyone figures out what works for them !
Do they? If they did or could, then they wouldn't start a topic on here and get a variety of different views and opinions. |
| Subject: Re: Non Locking Gas Cap Thu Jun 07, 2018 4:43 pm | |
| Gee Meldrew, I'm really sorry I started this topic. Can you ever forgive me for asking a question? |
| Subject: Re: Non Locking Gas Cap Thu Jun 07, 2018 5:32 pm | |
| Yes. |
| Subject: Re: Non Locking Gas Cap Thu Jun 07, 2018 9:13 pm | |
| Yes, the very reason they figure out what works for them is by asking the question and getting answers from the gurus.
Jay. |
DickO Founding Member
| Subject: Re: Non Locking Gas Cap Fri Jun 08, 2018 1:33 am | |
| Subject: Re: Non Locking Gas Cap Fri Jun 08, 2018 8:15 am | |
ItBeMe Maxi-Scooter Rider
Number of posts : 169 Age : 77 Location : Carrollton, GA Points : 2825 Registration date : 2017-09-29
| Subject: Re: Non Locking Gas Cap Sun Jun 10, 2018 11:16 am | |
| Boy Dale that was a very dumb move, Now when your not looking someone can steal all 60 gals of gas out of your bike. Me I lock mine and have a armed guard stand by mine at all times. |
| Subject: Re: Non Locking Gas Cap Sun Jun 10, 2018 5:42 pm | |
| Oh shoot i can't afford to fill that 60 gal. tank. I'll have to trade her in on a smaller scoot.
Unlocked mine today its easy. |
| Subject: Re: Non Locking Gas Cap Mon Jun 11, 2018 2:43 am | |
| With the price of petrol here at roughly $7.00 per US gallon (considerably more at Motorway Service areas), locking petrol caps make sense. P.S. Even if my calculations are a bit awry, petrol here is very expensive! |
| Subject: Re: Non Locking Gas Cap Mon Jun 11, 2018 8:30 am | |
| - MikeO wrote:
- With the price of petrol here at roughly $7.00 per US gallon (considerably more at Motorway Service areas), locking petrol caps make sense.
P.S. Even if my calculations are a bit awry, petrol here is very expensive! I see your point at $7.00 a gal. But here in the good ol USA a lot of us carry guns and at $2.25 to $3.50 a gal very few are that are dumb enough to get shot for a few gals of gas. Thank God for guns. |
| Subject: Re: Non Locking Gas Cap Mon Jun 11, 2018 11:29 am | |
| Subject: Re: Non Locking Gas Cap Mon Jun 11, 2018 12:17 pm | |
| - ItBeMe wrote:
- Thank God for guns.
I'll remind you of that quote next time someone with so called 'mental health problems' goes on a random killing spree with an assault rifle in their local high school, college, shopping mall or whatever. |
| Subject: Re: Non Locking Gas Cap Mon Jun 11, 2018 12:31 pm | |
| - Meldrew wrote:
I'll remind you of that quote next time someone with so called 'mental health problems' goes on a random killing spree with an assault rifle in their local high school, college, shopping mall or whatever. Ok that will work for me. |
| Subject: Re: Non Locking Gas Cap Mon Jun 11, 2018 3:42 pm | |
| Yep, not a lot of us Yanks will get on our knees and suck for $5 worth of gas...
Jolly Bodger Maxi-Scooter Rider
Number of posts : 105 Age : 71 Location : Lancashire, UK. Points : 3111 Registration date : 2016-10-05
| Subject: Re: Non Locking Gas Cap Mon Jun 11, 2018 7:11 pm | |
| - Sidewinder Pilot wrote:
- Yep, not a lot of us Yanks will get on our knees and suck for $5 worth of gas...
I believe a lot will do it for less JB |
