| Panel removal to get to right hand cluster connections | |
+2Cosmic_Jumper Edhothersall 6 posters |
Edhothersall Scooter Rider
Number of posts : 3 Location : Uk Points : 2340 Registration date : 2018-06-29
| Subject: Panel removal to get to right hand cluster connections Fri Jun 29, 2018 5:21 pm | |
| Hi all, my beloved 2008 silverwing has a dodgy starter button so it’s be decided to replace the whole right hand switch cluster- how do I get to the connector below the handlebars and behind the headlight, any ideas welcome, thanks |
| Subject: Re: Panel removal to get to right hand cluster connections Fri Jun 29, 2018 5:58 pm | |
| IIRC First remove the handlebar covers. Then remove the Windshield Garnish (the W-shaped panel below the windshield). You may also want to remove the right cubby pocket. With that access you should be able to disconnect the switch harness plug. There are also two screws on the underside of the switch & throttle assembly which need to be removed so that the switch separates. Then you may also need to disconnect the throttle cable so the the throttle tube, switch assembly and wire harness can be slid off the handlebar as one piece.
If that doesn't work you'll need to remove the entire Front Cover, i.e. front body.
Have you tried spritzing the start switch contacts with some sort of electrinic contact cleaner?
How to remove the Front Cover video: https://m.youtube.com/watch?v=5uv2qyxA-AA
Last edited by Cosmic_Jumper on Sat Jun 30, 2018 9:19 am; edited 1 time in total |
The Bern Silver Wing Expert
| Subject: Re: Panel removal to get to right hand cluster connections Fri Jun 29, 2018 6:34 pm | |
| Have you checked for clean & tight electrical connections (particularly earth)?
Starter relay takes a heavier load so is more likely to fail than the sspush button switch.
Can you hear the relay clicking ? |
| Subject: Re: Panel removal to get to right hand cluster connections Sat Jun 30, 2018 7:07 am | |
| I believe in simple repairs, at least at first. Spray the switch and gaps around it it with WD-40 or something similiar. Switch should then work. This method always worked for me. |
dekare Maxi-Scooter Rider
Number of posts : 125 Location : MN Points : 3159 Registration date : 2016-08-09
| Subject: Re: Panel removal to get to right hand cluster connections Sat Jun 30, 2018 8:59 am | |
| - john grinsel wrote:
- I believe in simple repairs, at least at first. Spray the switch and gaps around it it with WD-40 or something similiar. Switch should then work. This method always worked for me.
What John says. However, WD-40 could attract dust/dirt. I would use a contact cleaner. |
| Subject: Re: Panel removal to get to right hand cluster connections Sat Jun 30, 2018 12:04 pm | |
| Sometimes, switches botton or rocker just needs a little lube---contact cleaner not lube. Ride a lot and bottons usually continue to work. |
| Subject: Re: Panel removal to get to right hand cluster connections Sat Jun 30, 2018 1:50 pm | |
| Was this an introduction from a new member? |
| Subject: Re: Panel removal to get to right hand cluster connections Sat Jun 30, 2018 4:25 pm | |
| Thanks all for the info, front headlight removed and new cluster fitted! |
