joebillybobinark Scooter Rider
Number of posts : 82 Location : benton, ar Points : 2872 Registration date : 2017-04-19
| Subject: Hand shields from Givi Mon Oct 29, 2018 3:20 pm | |
| My previous Ctx was bought with handguards already installed. They were the cheapo type from China.. I was less than impressed with them after the mirror support bolt let go at 75mph..
Decided to look for something sturdier for my touring swing.
Remembering the brake reserve/mirror mount of the Ctx, I purchased the Givi 1111 labeled for the nc700x.
Only issue I had with the installation was this. The nc700x has a longer handlebar weight vs the swing.. The bolt going thru the weight and into the handlebar was too long.
According to the Givi paperwork, the bolt was M5 80mm. I measured the bolt at Home Depot and it measured more like 65mm. Figuring what I needed to subtract then find a replacement bolt became much too daunting.. Instead I added three nuts to the bolt.. Installed BEFORE the rest of the Givi hardware. The nuts were then painted black using touch up rust oleum paint pen from auto zone. I also applied this to some areas where the paint was scratched (base of brake reservoir and the mirror mounts) Worked like a charm and I am quite happy with them! I've ordered a second pair to install on my commuting swing.. Pics are on the silver wing 600 FB page. |
bikehiker Silver Wing Rider
Number of posts : 433 Location : New Cumberland PA Points : 3178 Registration date : 2017-09-07
| Subject: Re: Hand shields from Givi Mon Oct 29, 2018 9:04 pm | |
| Good work. Useful info. Now you can extend your riding into colder temps. |
| Subject: Re: Hand shields from Givi Mon Dec 17, 2018 6:45 am | |
| Update: Waited to install these on the other swing until I could figure out the proper bolt length.
I used a m6 50mm bolt and it worked like a charm. Gonna wait for warmer weather to slather some black touch up paint on the ends, in addition to the mirror posts.
I found the longer bolts (see original post) managed to catch the wire from my Gerbings jacket/ gloves.
Both swings now have mirror extenders and Givi handshields.
The handshields do make a difference while riding in 30 degree weather. I can use the 12v wired Gerbings gloves without an outer glove. Easier on the wrists and quicker to don. |
